Don Quixote
Banned
Everything posted by Don Quixote
  1. I like this a lot better. Some kinda optical illusion at play aft... They're nice too. *I* think!
  2. See page one to see how bad I trashed the transoms. They were WAY off outta the kit and I didn't think of adding/subtracting to make them work, so thinking I could resurrect my balsa wood talents of my youth, I made my own. bad idea, BAD idea! So all things considered, I'm happy with the way things turned out here.
  3. Sounds like you have a smart phone. Mine hasn't helped me one bit. Get it? Bit? bits, bytes, megabits, megabytes, terabi... Never mind...
  4. I sure do appreciate the support around here. It's interesting to see my log build, but it's also gratifying to see the interest grow. Not sure what I love more, building the ship or the camaraderie. HA! Building the ship, don't flatter yourselves.
  5. I agree. On a ship like this with so many different sizes of the planking and as a novice, it not only breaks it down to a manageable project, but helped me identify fairing issues I thought I had dealt with. Later when I get bigger ball-"bearing"s I might take more liberties.
  6. Amen! 3 months tops to build that engine. I got this ship for Christmas.
  7. We had to use the block at the factory I worked at years ago. For the purposes of this project it occurred to me and just now confirmed that the wood isn't even consistent in the same strip. In one spot a strip is .095, and another on the same strip is .092. Should be .09375 or 3/32" And, I just though. I need to taper a 1/8" strip to 1/16" I'm sure what I'll end up with is a tooth pick. Real question was, can't I make up for any discrepancies with the garboard plank? Can't I adjust the width of that?
  8. Nice. My 3rd of 4th will look a lot cleaner than this one... I keep taking the plans too literally. The diagram where they show stem/stern side beside, I measured like crazy to discover the planks that are supposed to be 1/8" wide (as per labelled) are wrong on the plans. I mean according to the text on the plans they're supposed to be 1/8", but if I take my callipers to the plan they're not. Band "B" at BHD H should be 1". 8 - 1/8" planks. I measure from the plans and it's off 3/64. I might be too literal. When you bore and engine out it better be 30 thousandths. 30 thousandths is 30 thousandths, is 30 thousandths. Adding a hobby. Steal and precision vs. Problem solving. No problem solving with cars. Pontiac 455. Buy an Edlebrock performance plus cam, intake manifold and 750 carb for that engine of a given year and it bolts up. Torque wrench, correct order and boom. I've had to tested. 630 H.P. Should get a good 20 gallons per mile.
  9. Thanks y'all. The callipers that were (I thought) giving me trouble, were not the digital, rather, my very old callipers I got from my dad after he passed. I went and spent $150 on the digital, and after receiving them started measuring everything in site with both callipers. Always came up with the exact same answer. NOW, WTF? They can't both be off the exact same amount, so I'm thinking I'm missing something in the design of a calliper. I even measured the distance between an inch on my big table saw. It was... An inch. Google told me about this phenomenon called the Vernier scale. Sounds kinda familiar now... Brandon Years ago I worked at a factory and we always used digital callipers, and never manual. Trust me, our tolerances were sometimes 1/64" We learned to zero out every freaking time we used them.
  10. What the heck am I doing wrong here? Those battens lay as naturally as can be! I'm happy with the battens aft. And yes, I know I have some fairing to do. That's as far as I got in fairing when I said ??? Some of that is shadow (the BHD's are actually white) and too much is me.
  11. What the heck am I doing wrong here? Those battens lay as naturally as can be! I'm happy with the battens aft. And yes, I know I have some fairing to do. Some of that is shadow (the BHD's are actually white) and too much is me.
  12. Thanks y'all I'm feeling more confident. I was measuring the planks shown on the plans and some at the middle BHD are supposed to be 1/8" but on the plans the sizes are inconsistent. So I just took .125" X 8. Whatever works at fore and aft is what works at fore and aft. Panic over.
  13. OMG! If I had any dignity I'd be embarrassed. Seriously. 35 years ago I was a very bad boy and did 30 in the county jail. I was in what they call the single man side. One person per cell. There were 32 cells. They let 1/3 of the inmates out at a time to stretch and play cards or whatever. One day I told a guard that I was having trouble figuring out how all the inmates got out. I said: If cells 1 thru 10 are 10 cells, and 11 thru 21 are 10 cells, and 22 thru 32 are 10 cells than that 10 X 3 is only 30 people, but all 32 got out. How? No one could figure it out. I agree, no way I'm trimming anything off accurately this early in my learning curve. But I'm not going to ask for more wood. I figure the garboard plank can be adjusted... And if I have to use a little wood filler so be it. One strake starts with 8 - 1/8" planks, but the strake is only .57" at the stem. So either way I'll screw it up and rely on the garboard plank. Or did I not drink enough Scotch last night? Question. (again) I know the planks have to be beveled on one side to reduce the klinking effect, but I don't recall where I saw if it's top or bottom. I've read the manual too many times and seem to skim too much now. THANKS!
  14. Ha! just caught the Snap-On comment. AMEN! I have some Snap-on and some Craftsman. I've had to replace some Craftsman, but the older Snap-On have never needed replacement.
  15. I think I spent $150 on the digital. So whataya think, can I get away with modifying the strakes to accommodate the 7/64, or should I ask for the right sizes? I mean, which way would be the wisest to learn? Right now I'm thinking it'd be wisest to have some directions to follow.
  16. I used these non-digital callipers to measure all the wood from the kit. When I planked around the gun ports and sweeps it looked to me like I was missing more than half of the planks I needed. Got 'em from Model-expo. Now, when preparing for the planking of the hull, I need 8 1/16"X3/32" for each side for the first strake "A". When I started measuring out the battens and verifying with the width of the planks I started having problems. Things weren't adding up. The 8 planks I needed totalled more than what the plans call for. Thinking WTF? to myself, looking over and over I noticed an oddity in the callipers I used. See I have it set to 5 mm, but look at 10 mm and it's a mm off. 10ths of inches appear to me to be off too. I bought some considerably more expensive callipers and to me it looks like what should be 1 cm is off by .137 mm. (lighting is playing trick with the shadows in the picture) But the original callipers say something about .002mm. More, WTF? Thing is, converting metric to inches, I get what *I* thought was 3/32" is, according to the new callipers, actually .101" or 7/64" Bottom line, I have no more 3/32"X1/16" planks, and I'm anxious to learn to plank. Question is, the plans call for 8 - 3/32" planks at bulkhead H, strake "A", but all I have are 7/64". Can I change the .75" strake called for in the plans in section A, to accommodate the 7/64" planks I have? Seems to me I can modify all the strakes because the 4th strake "D" has the garboard strake which is the odd man out anyway. I'm out to lean "how to", I don't care about authenticity. Yet.
  17. Ok all you 650,023 people that are following this log... I used these non-digital callipers to measure all the wood from the kit. When I planked around the gun ports and sweeps it looked to me like I was missing more than half of the planks I needed. Got 'em from Model-expo. Now, when preparing for the planking of the hull, I need 8 1/16"X3/32" for each side for the first strake "A". When I started measuring out the battens and verifying with the width of the planks I started having problems. Things weren't adding up. The 8 planks I needed totalled more than what the plans call for. Thinking WTF? to myself, looking over and over I noticed an oddity in the callipers I used. See I have it set to 5 mm, but look at 10 mm and it's a mm off. 10ths of inches appear to me to be off too. I bought some considerably more expensive callipers and to me it looks like what should be 1 cm is off by .137 mm. (lighting is playing trick with the shadows in the picture) But the original callipers say something about .002mm. More, WTF? Thing is, converting metric to inches, I get what *I* thought was 3/32" is, according to the new callipers, actually .101" or 7/64" Bottom line, I have no more 3/32"X1/16" planks, and I'm anxious to learn to plank. Question is, the plans call for 8 - 3/32" planks at bulkhead H, strake "A", but all I have are 7/64". Can I change the .75" strake called for in the plans in section A, to accommodate the 7/64" planks I have? Seems to me I can modify all the strakes because the 4th strake "D" has the garboard strake which is the odd man out anyway. I'm out to lean "how to", I don't care about authenticity. Yet.
  18. Silly me, I thought steaming meant to soak the plank in water and run it over a soldering iron or in my case one of those irons with the rounded end that model expo sells, because when one does that, the wood steams. I assume one simply runs the plank in front of the steam slowly? Off to buy one now, I should be ready to start planking soon.
  19. Home Depot (local home do-it-yourself store) was tearing down some display end caps. They let me take some of the scraps home so I made this:
  20. Given the problems I caused myself with the transoms - see the bottom of page one. I used balsa wood to replace what I was having trouble with - I'm happy enough with the way this turned out. What a learning experience! Are we having fun yet? As a matter of fact I am!
  21. Thank you! I feel brave again. Did that jet ever catch up with you?
  22. Oh yeah. THANKS! My mother taught me manners. I just never learned. I'm a kinda "to the point" man.
