yancovitch
Everything posted by yancovitch
  1. ok...made the entrance way, although the steps are a bit too far apart, which i can't change now....got pirates of the caribbean figures which i may modify ..or not ....they may be a bit too large....i don't know......added the bell and did a lot of work which is not evident ........... have to make two more smaller lamps....
  2. hmmmmm....not red for sure, cause when i install some orange led lights, they will look orange in the dark obviously ....so during the day they will be white....but....i think i'll warm them up a bit ..amberish, when i spray them.....(i sprayed the frame white)....could have done a better job with soldering the frame, but i figure i'll leave that option open after completing the ship...maybe then, i'll experiment with a clear epoxy covering type of lantern...we'll see......
  3. haha.....i thank my wife for that...don't know why i didn't think of it
  4. condom would have been great, but too fragile, so my wife suggested a nylon sock....and i'll go for it....will cover with urethane or epoxy after painting frame white........like a chinese lantern.......
  5. no problem..a friend is sending me some shrink film.....
  6. need some advice.....some kind of tissue or iron on heat shrink translucent material to cover the lantern....thought of 2oz fiberglass cloth but it falls apart too easily.....
  7. gee thanks dirk all the way from hamburg! still holding off on finishing it, until i get the basic couronne hull completed......
  8. very kind.....may not be as good a job as sawdust dave, but it should look nice in the end....cheated on the ratlines,..... no clove hitches...too small thread.....so now the ship will only have half the value when finished ...haha.......call me shortcut vic i guess, when building, one has to decide the degree of accuracy or refinement one can do, or wishes to do.....hmmmm..even if i can feel very happy about something i build, when i look at some of the great modelers out there, i always am aware of my limitations whether self imposed or genetic .....but having fun is priority.....
  9. haha....from what i see of your build, you'll make mine look simplistic or even amaturish .........been out of touch with the forums aside from throwing in a photo here or there....uh...mostly there ............best thing though for me, was using pear wood or some other suitable hardwood....so much easier to work with, and when i pick up the model, it doesn't leave accidental fingernail gouges on the sanded surfaces ...... if i used the basswood, i'd have to put on my ballet slippers and wear a tutu
  10. ha....seems like i have to work on both models at once like ej
  11. super thoughtful ej.................thanks...anything helps......
  12. aaaah....just realizing.....rigging....what a problem i have trying to find rigging plans...bought the plans for musees de la marine, and they were useless unless i read italian....and the luci's couronne plans, weren't helpful as the numbers on the lines didn't match the belaying points on the deck plan.....may have to purchase some plans for the mantua kit, as mine is closer to that.....the corel plans are available online, but the resolutions is so poor, it's hard to read..... ...i dunno....haven't the patience to do alot of research in books etc. as it's a close enough for jazz effort, as this ship i'm doing is a bit of a fantasy ship to begin with...........great advantage of doing a kit, for sure in this regard, although some kit plans leave a lot to be desired, and one has to do research anyways......which, it seems may be what i may end up having to do...though i do have a few books...yuk....i'm just not a reader, just a full time doer
  13. hmmmmm....christmas break......hmmmmm....may be longer than that .....then again it's difficult when there are two ships demanding to be finished at the same time......i wonder what i'll end up doing........a master of division........as i mentioned once, if i had written the wizzard of oz, the story would have ended at the scarecrow and the fork in the road ......fa la la la la.......la la..la...la...........................
  14. ok....the last shots for awhile.....have to get back to the confederacy rigging....will just finish the railings then off to those drat lines.............cheers, and seasons greetings.........
  15. thanks ca......and now that i look at it, i feel i should have made the planking on the walls behind the doors more visible....the walls are planked but sanded smooth.....and i painted them cause the wood was too grainy looking....maybe next time haha..............
  16. thanks, and ha......was going to leave off on the couronne and finish my confed, but i can 't seem to stop working on it..........found some beads on line, cut one in half on an angle and added two more on top....piece of copper wire hammered down the center after drilling holes in base......was going to do gold for the glamour, but i think i can leave the natural color of the beads...... oh... bent rings around the door frames......
  17. meds?...for what...did i miss something?............it's the crazy glue...that's all....the crazy glue
  18. that cold in kansas??!!!......wow!....doesn't make sense.............................kansas???..........sheesh!
  19. hmmm.......the bowsprit seems a tiny bit long....or is it a wide angle lens effect?....i'm probably wrong....was working on mine when i checked yours.......
