Everything posted by yancovitch
wow...all the way from taiwan....most grateful
- 213 replies
- la couronne
- 74 gun
me too ca.......but it seems there's nothing i can do till next spring-summer, and summers way up here in burns lake bc, are really short.....but god willing ...it will happen
- 213 replies
- la couronne
- 74 gun
thanks hubac............not the best finishing...not the best accuracy.....but it think the effect of it sailing, will be it's saving grace ...cheers, vc
- 213 replies
- la couronne
- 74 gun
double merci chris.....should be finished by chris.....tmas :)......then i have to finish the confederacy rigging...and ooh...you just reminded me on your post, that i should include the ship's boats too.......cheers..........vc
- 213 replies
- la couronne
- 74 gun
thanks ej.....i'm looking forward to the trials next spring-summer too....should finish it by christmas, and then i'll finish, god willing, the confederacy.....after that no more building...will have a clean house from then on ..guess i'll not be posting anything till then..will spend time enjoying other peoples builds.......cheers to all....................vic
- 213 replies
- la couronne
- 74 gun
ok...thought i'd post some 'where i am' shots.....and i'm sorry about the poor photos, as i'm working in my living room which is not very large...next spring i'll take some shots outside, when it is finished..... rigging not attached properly yet, and needs more work....staining etc....using braided nylon which is good for a working model...got some 'close enough size' belaying pins from model expo..... shots show imitation rigging which looks roughly like it should, but instead, is functional.....will move yards with separate lines attached to a winch...and the drive assembly is already made...... for the gold pedestal sculptures, i got lazy, and put a wig on a superman toy...close enough for jazz and i like the imagery:)...like kings tend to think they are supermen... these are the cannons, designed and built by dan lewandowski, which will be installed in the center of the lower deck, four on each side............... filled a 42''- 2'' abs pipe with lead, and it will be used as an external ballast, which may not be needed, as the ship is quite fat, but it will give more stability and handle a bit stiffer breeze..... using a bamboo sheet for the sails, which i'll be starting shortly........ a friend, has a large lathe, and he turned these pedestals for me.......the 3/8'' threaded rods that secure the ballast, which will also secure the two pedestals on a stand, which i haven't made yet....may use a sheet of dark maroon laminate....easy to clean and goes nice with the walnut..... ha...and no.....i won't be building a case for it
- 213 replies
- la couronne
- 74 gun
an inspiration, so clean....so clean...........!!!
- 290 replies
- confederacy
- frigate
Le Soleil Royal by Nek0 - 1/72 - Marc Yeu
yancovitch replied to Nek0's topic in - Build logs for subjects built 1501 - 1750
beautiful beautiful beautiful!.....and...no....no one can work so meticulously, so fast...............either you have a bunch of elves working for you at night......or..... your ship is really already completed, and you're just posting shots of the build as the days go by............. it's just too much for me...i may not be able to look at it anymore kinda like if Christ came down and manifested in a blaze of light right now.....many, if not most, would shriek, and cover their eyes, and hide....all their shortcomings and sins being so exposed... it is kind of a miracle to me.........i'll keep looking, but i'll be at a loss for words, so i'll just be clicking on ....like.... from now on apologies, if i'm over reacting...cheers.............- 208 replies
- le soleil royal
- 104 guns
not to mention, that taking good photos of a model, can be quite time consuming if done right, and this young fella does a super job of it......
- 290 replies
- confederacy
- frigate
gads, i hope you haven't already revealed this, but what glue did you use to install the planks?....ca?...if so.....no allergies? ha, my wife's sinuses clog up when she's exposed to ca fumes...i'm starting to react too....but, coming to the end of my build, i't not a problem...
- 961 replies
good info, thanks....but for my situation, i need the flags fluttering in the wind....i'll use these as a temporary solution, and when i get the bucks together, i'll have some proper flags made.........ha...last ones i had made were purchased in usa, and came from turkey for e.j.....they should work well.....and....i've never done planking as well as ej...super!
- 961 replies
fantastic herve!!!....all the power to you......sent address.........ha....now back to googling and ogling at this build- 208 replies
- le soleil royal
- 104 guns
well ...my gosh, i'm truly honored!!!.........yes....i mainly build to create a mood....a romantic vision .......i just cannot do what you do, which, like i said, is breathtaking!....you will likely combine the two......and that is an accomplishment!!!............i pray herve is well....lost contact.....i think he had some difficulties in the past......i'm so enjoying this log..........cheers.....- 208 replies
- le soleil royal
- 104 guns
gag.............breathless.......................- 208 replies
- le soleil royal
- 104 guns
friend just printed them out for me on some silk inkjet printable fabric sheets, and they don't look too bad....very thin....so i'm applying some fray check liquid to see if that works.....will let you know.....although i'm sure silk screening would be better....and i just discovered that the fray check i am using makes the colors run..............i mailed the company and maybe they can give me some advice here ....guess i'd need a water based one...................we'll see.......cheers....
- 961 replies
oh..............just curious.....do you think you can use those flags i sent you for your la couronne?
- 961 replies
a holy man i met once said.......''a strong man revels in his strength....and a weak man wonders how he got it''...........well ...you can go ahead and revel deservedly, and i, contently, remain here scratching my head ....thanks for the experience............ and oh....you're obviously right about the chisels........- 208 replies
- le soleil royal
- 104 guns
oh neko..........if you would like some dental burrs, if you should be so inclined, not that you need them :), i have a bunch, which i'll never use that i could send you ....the only thing is, it would be nice to have a really small dremel type drill to drive them, which won't be unwieldy....but some artists are attached to the manual method, which may add more soul to the work :)....- 208 replies
- le soleil royal
- 104 guns
if i may........what kind of pear wood?.....got some pear once which was very light like yours....then the second time years later i got some which was relative dark.......maybe grown in the north or south makes a difference.....and if i missed it .....what kind of wood for the carving?...looks like it has an awfully fine grain...thanks..- 208 replies
- le soleil royal
- 104 guns
augh.....i think i'm gonna be ill ..or at least cry....unbelieveable....time for me to quit pretending i'm a modeler .........boy.... am i gonna be attached to this thread....super super....and the fellow looks so natural and lifelike..............................................................and so small...................sheesh!!!- 208 replies
- le soleil royal
- 104 guns
so sorry!..i was referring to neko's work......just discovered all these talents, and i'm yet getting people mixed up ....sheesh!.....where is cedric's build that you mentioned?...........
- 2,699 replies
- heller
- soleil royal
(and 9 more)
he sure is!!.........but it ain't plastic ..........
- 2,699 replies
- heller
- soleil royal
(and 9 more)
