Everything posted by Siggi52
Hello, I finished now also the last gratings at the upper gun deck. But when I started to plan the capstans, I realises that I had build the bases for them too small. 😬 I made the upper flat 24 mm Ø, and I don't know why. The capstans at the Dorsetshire, at the plans for the Tiger they are not drawn, have at there bases a diameter of 28 mm! And at the most plans I looked at, the capstans have nearly the same measurements there. The stanchions at the front of them came out without any damages, and what a wonder, I had left over two extra 😃 So today I turned two rings to enlarge these bases, as you may see at the pictures.
Thank you Greg, I can't really remember what I used, but mostly a scraper, small chisels and files. It's now over 2 years ago, that I build them. But it was't an easy job, that can I remember very well. But I thought, when they did it in the 18. century, why should I not do it 😉
Hello, and thank you for your likes and Mark for your explanation. Today the men from the shipyard finished the second group of gratings. But the shipwright discovered already some things they have to repair tomorrow
Hello, and many thanks for your efforts Mark. Alexander found in Goodwin's book English Man of War, 1719 establishment list, under gun deck and plank, page 249 binding strakes. The same for the middle deck, under Flat, page 252 and for the upper gun deck also under flat the next page. What is the difference between plank and flat? That means, I have to build them, but as you already said, I do not inlet them. I have also a little upgrade at the shipyard
Hello, Jaager, I think I did't need such a sliding table for my saw and yes, I have my fingers all the time in view and away from the blade So, the first set of gratings is so far ready. But from these curves under the beam you did't see very much 😐
Good morning Mark, and many thanks for your efforts. Yesterday I read a lot, and came to the solution, to omit the binding strakes. You say, that you did't have contracts from the time of 1702 to 1755. That was the time of the establishment, and in the lists are no binding strakes mentioned. And may be, as you say, it was left to the shipwright. I think, when Anson became the 1. Lord of the Admiralty(1751) and Slade and Batly were the Surveyors of the Navy (1755), they reintroduced the binding strake.
Many thanks Mark, then I build them as planks on top of the beams, the full breath of the planks from stem to stern.
Hello and thank you for your comments, Mark, are that really binding strakes? I know that they may have the same function even if they are only nailed on top of the beams. Falconer, Lavery and even Goodwin did't mention them. In the 1815 edition of Falconer they are mentioned and of corse in Boudriot book about the 74 gunner from 1780. A colleagues in a German forum has posted this from: "18th CENTURY SHIPBUILDING - Remarks on the Navies of the English & Dutch" von Blaise Ollivier? That should be from 1737, but who did write the note to the left, and when? Druxey, that is the only source I have. But I thought to get them out it would be helpful to have some room under them. Also for airing the surface of the beams there. Chuck, thank you too
Hello, and many thanks Gary So, the first arrangement of gratings is ready. Left is only painting, but I think that is something for tomorrow. To the right comes later a capstan and a ladder way And before anybody cries, oh that is not authentic, here the Centurion 😉
Hello, today I finished these gratings. And my question is also answered, I found pictures of a 70 gunner 1730 and of the Ajax 1767. Both are models where the upper part could be taken away, and they show at the underside of the upper gun deck these two planks.
Hello, today I started building the gratings. To show you how I did it, here some pictures. I think the pictures explain how I work. It is important, to cut first the grooves transverse to the grain. Otherwise you would have later a large puzzle. I leave them over night so, that they may straighten out a little more and glue the battens tomorrow in. After that, I grind the back away, and they are ready. But at least I have a question. At Falconers deck plan (gun deck) you could see to the left and right of the gratings and ladder ways two planks, who are going more or less straight through the ship. Those with the rings for the canons, Z. Was that also at the upper gun deck so? At the models you see mostly only the waist.
I really don't know that Joe. But why not, may be in an other version? The carpenter on board has sometimes also something to build or to repair.
Thank you Keith, we are all boosted and I hope save! The boss spend sometimes a brandy, for disinfection. 😃 Druxey, I got out of this without any destruction. But I have to work this way, because how should I install the canons when the upper deck is ready? Not to speak of the paint work with all the ports open. But this was at least the most dangerous work, and it is done. 😰
Hello, not that you forget me, here a small update. I build in the spirketting for the upper gun deck. and today the waterways followed These guys are controlling all. They are standing on a 3 inch (1,6 mm) plank. The planks later have the same size. And that is, what the carpenters have to do the next weeks, planking the deck.
Hello and thank you for your comments and likes, today was a great day, because I finished the gun Deck. More or les, because there are the capstans and ladder-ways who will follow later. I decided to build the anchors all on board, so the anchor cable did't go over the riding bits. I'm sorry but the crew had there breakfast break, so they are not at the pictures 😉
Hello, today I puzzled how to lay out the anchor cable at the deck. First, must a cable when not in use go over the bits? I build that at the port side. At the starboard side I would say, the anchor is out and the cable goes over one bit. Falconer says, only at a heavy sea the second bit was also in use and more stoppers. I secured the cables with two stoppers. All is not hard and fast, so if someone of you have other suggestions, please let me know. At least, most of this you would't see later 😐 I had some trouble with the uploading of two pictures! That is the reason, why one picture is now smaller.
Hello, so, the deck is scrubbed and I made a first sample sitting for the cannons. The question is here, should they be perpendicular with the axis of the ship (pic.1), or with the outside of the walls? (pic.2) I tend for the later variation. You could see both at the contemporary models. And JJ, the shipwright stands before the ladder way. So it is't so tight.
Hello JJ, I leave it so as it was designed. I don't think that it is a mistake. You find that at many plans. Here the Tiger 1747 Standard 1782 Dragon 1760 Or even not Essex 1741 Ipswich 1730
Hello and many thanks for al the likes, and now back again at the gun deck. Today I opened the port lids at the port side. The weights are bullets cal.45, if someone may ask.
Hello, it is done! That was more work as expected. The next, and for the next time last thing to do outside of the hull, would be to rig up the gun port lids at the gun deck.
Hello, and thank you Albert That was not for the first time, but when I look long enough at the pictures it is not unusual that I'm back in my shop and tear down what I had build before. So also here. It is terrible what you could see all at pictures 😬 Now the window borders 2.0 At least I carved only these red and white half circles new, but I also build the pillars and painted them the last days.
Hello and many thanks for your comments and likes The carpenters started with the window borders. Are that also rigols?
