Everything posted by Kevin Kenny
Thanks for all ypur frank comments. The purpose of doing the video was to be instructive and once you admit to one mistake the other 100 are easy to admit to. Just thinking ahead. I have no idea what the figuerhead on the Thorn was. Any though on how i should try to identify the figuer head? Should i just leave it out? Kevin
- 1,041 replies
i have to tell you i have been to the wall a few times and did get discouraged. But i am a stubborn SOB and have spent most of my life dusting myself off and getting back on track. This build is no different. I still have to take out two frames which i will do next week. This group of modelers deserves a clap on the back, because it is a word here and there that kept me going.Keep well. Kevin
- 1,041 replies
The plane you see in the shop is a 1/3 cub kit from Yellow aircraft. She flys beautifully.. The build was actually started by a friend who got cancer and eventually died and i furfilled a promise to him to complete the build for him.
- 1,041 replies
This is the last Video this year. Many thanks for all your support and help. Kevin
- 1,041 replies
First of all my frame plan ZAZ 4691 A aft does not show a " cast" at the top. My gut feels to follow the book and not the plan in this case? Your comment. I am a bit confused on the frames sent to me via email. Greg Can you see if i have it right There are 11 frames left. I have use the "@" to depict the center. Starting at the back, - 1 aft. floor Spacers -1 fore. crosschock -1B , floor, top timber shifts aft. -1A , crosschock, -@1 fore. Floor, scarf joint Spacers -@ center, crosschock Spacers -@A, floor -A aft., crosschock, maybe cast at the top? -A fore. floor -B aft., crosschock Spacers -B fore., floor
- 1,041 replies
I had to change some errors in the video so had to repost. Kevin
- 1,041 replies
I had to take a rest after a real bad bout of flu. But i am back and used the time to clean up the inside of the frames on the model. In the process i modified one of my Proxxon sanding tools and have invited Proxxon to produce some accessories that may be of use to our hobby.
- 1,041 replies
so waht you are saying is that all the tops of the frames are cut flat and added after. I wondered how i was going to cut holes for each of the timberheads to pass through the rail ( not sure of the correct term) . This makes so much sense.
- 1,041 replies
At the time i started posting it was very difficult to post quality video , that has since changed but i had already picked a place to host my videos and so am sticking to vimeo.
- 1,041 replies
The reason i chose Vimeo over YouTube was the quality. The down side to Vimeo is that ypu will need at leat 2m to view. Sorry about that.
- 1,041 replies
Not sure why you cannot see the video as it is on vimeo open to the public. Is there something i can do to help you get access? Best regards Kevin
- 1,041 replies
I will give it a try and see how they come out. As always thanks for the feedback. Kevin
- 1,041 replies
Hi Greg what do you think about Toni point. See my response to him here. Hi Toni Just saw your post. I was under the impression that all comments were sent directly to me . Either i missed youe email response or i did not get it. Your point is very interesting. In fact as i look at the plan of the Thorn i see a lot of differences. The frame 2,9,14F,11F, there is a light line drawing added after the plan was drawn, suggesting that these frames go all the way to the railing. There ar two missing timber head at the back but again light pensil marks??? At the front section the plan has one addition timber head.. What is your openion about the light line drawings.? Also not sure which frame you felt is shifted. Is it 7Aft and 11 aft? Best regards Kevin
- 1,041 replies
Not sure how to post pictures but i have been following the Thorn plan as per Gregs suggestion. The forwar section has one additional timber head while the stern is short two timberheads although you can see some light drawing on the actual print. Maby Greg could comment on this?
- 1,041 replies
Video 20, installation of the forward square frames L-G
- 1,041 replies
Installing the rising wood and the gun port sills
- 1,041 replies
