Noctavigant
Posts posted by Noctavigant
Happy Sunday all. It's been quite some time since I've posted and my previous build never took off. I figured it was time to start a new kit that was simpler than the last. I decided on the Whaleboat since it's a smaller kit without the higher parts count, and it seemed to be easier than the Occre kit I tried last year.
I have been working on this over the last two weeks, so here are some photos of my progress thus far.
I started setting up the jig, beveling the stem and sternpost, and gluing them to the keelson.
Finally got some time over the last couple of weeks to work on this. I found a problem after gluing the bulwarks in place. A couple of my clamps popped off during the night, which caused a lot of gaps around the deck. Rather than try to cut everything apart, I decided to see if I could make things work since it will be painted in the end.
Filler blocks in place.
Planking the interior of the bulwarks.
Stanchions in place. I will be painting this model, so the filler will be hidden.
Starting the first row of planking. This kit is double planked.
- Tim Curtis and GrantGoodale
- 2
Thanks for the invite Lee. I'm only 30 minutes from the library. Does the club meet in one of the conference rooms there?
- Keith Black, mtaylor and geoff
- 3
My name is Sean. I'll be adding it to my signature block along with my current build soon.
- mtaylor, geoff and Keith Black
- 3
Can you see the photos now?
Well, here is my first build log. I haven't gotten very far over the last couple of weeks, but it's a start! I will warn you, my nautical terms are severely lacking, so feel free to correct me if I am wrong, or don't know the proper term.
First up I glued all the frames together using aluminum angle to keep everything square.
Adding the planking to the deck. I found the wood to be very dry and quite fragile. I believe it's sapele.
Trimmed up the planks and glued the deck to the frames. Everything lined up pretty well.
Did some pencil lining on the deck to give the planks some separation. There are a couple of gaps that I will have to deal with soon.
That's it for now. I'll be continuing on with the hull this week. Thanks for reading.
-Sean
Hi all! I've been meaning to post here for some time. I've been registered for almost 4 years, better late than never
I've been following this site for some time, reading over build logs, and trying out cheap MidWest kits before I posted an actual build. I currently build a lot of plastic amour and ship kits, and I am active with our local IPMS chapter. I used to build furniture a long time ago, but after selling our home a few years ago, I had no where to keep the tools and work. I did manage to take over our den and the wife has been completely supporting my hobby.
I am a systems administrator for a local school district. Building models helps me relax and keeps me off a computer most evenings. I will be posting a build log of my current project shortly.
New Bedford Whaleboat by Noctavigant - BlueJacket Shipcrafters - scale 1:33
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by Noctavigant
Bending and laminating the false stems.
Keel and stems glued in place.
