Everything posted by iosto
Congratulations Chuck, a beautiful work. I follow you step by step in the construction of my cheerful. I'm proceeding with the riveting of the hull, very tedious job but effective. Do you have some photos spars? I'm also beginning to think the shop window on which store the model that I will definitely Plexiglas but are undecided on the base, if it on a stopover site, you have a few drawings to show me? Hello
- 1,051 replies
- cheerful
- Syren Ship Model Company
Cutter Cheerful by iosto - 1/4" scale
iosto replied to iosto's topic in - Build logs for subjects built 1801 - 1850
At this point I'm starting to think the window and definitive basis. I am undecided whether to create a leg with strips square as models of arsenal, or set it on twooo turned columns with screw pin concealed in a more classical. Could someone give me suggerimentio designs or realizations of stairs? or on how to make the columns on the wheel? so big I never made more than anything I want to find some nice drawings. -
The hull is then filled with balsa finished with coarse sandpaper, and then finer after the surface is grouted, and then again sanded, and then stuccoed Finishing -
I preferred to use a construction technique different from that indicated in the instructions. Typically use this technique for years for the hulls filled. The technique is to glue the frames and then fill balsa spaces then fill with synthetic filler to have a uniform surface. in this way laying the boards is very easy, it does not require nailing. For gluing use then a cyanoacrylate glue -
I bought the designs from the site Syren Chuck. Unfortunately there are no available pieces in laser cut, I proceeded to cut them after pasting paper forms on plywood -
- 11 replies
- model shipways
- 18th century longboat
- 11 replies
- model shipways
Construction of the base I wanted to get an antique effect as models of museums The columns copied from those of Chuck,,,,,
- 11 replies
- model shipways
