ccoyle
Moderators
Everything posted by ccoyle
  1. More recently ('recently' means last summer ), I decided to somewhat imitate the elaborate decorations seen on the stern counter in the Williams & Marshall painting. First, I located some heraldic dolphins on the Internet, scaled them to the appropriate size, and then printed, painted, cut out, and edge-colored them. It took me a couple of tries to find the dolphins and color schemes that I thought looked the best. Here is the final result, with the dolphins swimming in some dappled foam. Of course, since then I've learned that the artwork on Fly was completely different. Oh, well. Please note, that is what eighteenth-century maritime artists thought dolphins looked like - not what I think they look like.
  2. This shot shows a number of things. First, the careful observer will notice the absence of cast metal fashion pieces. I simply could not get the kit castings to fit the hull properly, so I omitted them - on the Captain's orders. Second, I had to rebate the back sides of the quarterbadges, because they overlap the wales. Third, you can see where it was necessary to paint the lower railing posts to match the colors on the hull - black, yellow, red. Same went for the forecastle posts, except they needed black-yellow-red-yellow again. This was necessary to match the Williams & Marshall painting. Fourth, you can see where I replaced the 1x1 mm hull trim from the kit with Bluejacket double-beaded molding -- much nicer.
  3. This is the aforementioned forward screen bulkhead, along with a view of the two ladders that had to be built from scratch because the kit didn't include enough ladder material. I also added some detail to the gallows, using a file and some scrap card and wood to add beveling, decorative panels, and cheek blocks.
  4. It took quite a bit of tweaking to get all the quarterdeck rails in place. For one thing, the dimensions given for the stanchions along the break of the quarter deck (the square posts) were wrong; I believe they were given as 2 mm too tall, but my memory is fuzzy on that one. The stanchions at the entryways were off-the-shelf turnings and were both too tall and too large in diameter, so those had to be cut down. The entryway railings also had to be cut and trimmed to correct the angle of the elbow where those railings join the quarterdeck railing. But in the end, it all worked out. By the way, the lengths for all the breeching ropes and tackles were taken from a table in the Ship Modeler's Shop Notes published by the NRG.
  5. Another couple of tweaks to the kit. The cleats in the kit are far to large, so I cobbled together some smaller replacements. The kit's binnacle is also very, very basic, so out that went, too. I built a replacement based on some drawings and pics submitted by MSW members. The binnacle lantern is made from a sacrificed CA glue Z-tip, the compass roses are some scaled-down images from the Internet, and the chimney is some part from the scrap bin. The chimney should be black, but I haven't had much success blackening turned brass parts, so I left it shiny. Don't tell anyone.
  6. This lovely photo shows what happens when you think you've done an adequate job of planking, only to have the flash show up every ugly gap in the planking. Next time...must do a better job next time. Anyways, the stern carvings are a decent casting. After painting with the basic ochre color, I brought out some detail with some washes. Of course, the flash then proceeded to wash out all the wash detail. The curtains are an idea I copied from another build long ago. The period after 'FLY' is period-appropriate (no pun) and is not included in the PE brass set. It's just daubed on with a brush.
  7. I also decided to purchase the available Fly upgrade kit, which basically consists of the extra stuff that was included in the Pegasus kit, but not part of the original Fly kit. It is well worth the money, in my view. Among the options in upgrade kit are wooden carriages to replace the kit's cast metal carriages. The metal carriages are virtually impossible to drill, something that needs to be done if one wishes to properly rig the guns. The upgrade kit also includes PE brass insignia and locks for the guns. The kit guns are not entirely true to English guns of the period and already have a cast insignia on them; I made do with turning the barrels over and adding the upgrade insignia to the bottom (now the top) of each gun.
  8. First off, I am using the Williams & Marshall paintings of HMS Kingfisher to guide my painting of HMS Fly. The operative word is 'guide' (as opposed to 'template'). Early on I decided to add screen bulkheads to the model. These were scratch built from scrap plywood and card stock. The door knobs are brass nail heads. This is the aft bulkhead - it is less detailed than the forward bulkhead, which is far more easily seen on the model than the aft bulkhead. The forward bulkhead windows are properly glazed. As you can see in this picture, the proper placement of the aft bulkhead is not between the existing kit bulkhead extensions, but slightly aft of them.
  9. OK, I'm going to try and recreate parts of my build log for HMS Fly. I have been working on this model for so long that it has now gone through the deaths of two sites - once at the old Dry Dock Models, and once during the Great Crash of 2013. First a little back story. I bought this kit waaaaay back in 2006 - it was one of the very first production kits off the line. It should be done by now, and if it were anyone else but me, it probably would be. But that's not the way I build. My modeling urges come in intermittent fits and spurts - periods of great progress followed by usually long spells of inactivity, at least on the wood front. I also build card ships and 1/33 scale card aircraft, so sometimes when you see Fly come to a halt, it means I have some other project on the front burner. During the ensuing years, many fine models of Fly and her sister, Pegasus, have been completed here at MSW, so I will not go back to the very beginning and show all the basic framing and planking, etc. Instead, I will highlight some of the bashing I did to the basic kit, mostly to give other builders some hints about what can be done with it. I'm not actually working on Fly at the moment, so don't expect updates in the very near future. Mostly I'm doing this to create a placeholder of sorts. So, on we go!
  10. And before you know it, it's done! Actually, I didn't take many pictures during construction because I was in some haste to get this model finished in time for a convention. So, here it is. The railings are made from thread using the supplied jig and the technique mentioned in my log for Folke. Thanks for looking!
  11. One of the hardest parts of building these small monitors is getting the hull right. Everything after that is gravy. The difficulty is due primarily to the very low freeboard and the necessity of preventing warpage. I tack the hull base plate to a small sheet of glass to hold everything flat during construction. The kit includes optional dressing belts, which I included; these are fairly difficult to install because of their extreme length and narrow width. Once the basic hull is complete, the addition of the superstructure and turrets goes rather quickly.
  12. The Spanish monitor Puigcerda (named for the city in Catalan and the only monitor ever to serve in the Spanish navy) was commissioned in 1875. She displaced 553 tons and carried three bronze muzzle-loaders, one of 12 cm and two of 10 cm. After brief service during the Third Carlist War, she was laid up until the Spanish-American War in 1898. Re-armed with two 16 cm guns and two 12 cm guns, she patrolled the Vigo River during that conflict. She was sold out of the service in 1900 and converted to a civilian steamer. Puigcerda is another of the excellent offerings from Paper Shipwright. Designer David Hathaway's models are well regarded for their fit and detail. Despite their small size and relatively low parts count, builders should have some experience working with card due to the number of very small parts. My kit was a laser reprint sold by Paper Models International; their website is still up, but hasn't been updated in ages. The kit includes several pages of parts, instructions, diagrams, and railing jigs.
  13. The model goes together relatively quickly and makes an interesting finished product. It is by no means a difficult model compared to what else is available in card model subjects, but it does have a fair amount of small parts, so builders should have some experience working with card before attempting this or other Paper Shipwright subjects. Cheers!
  14. The railings are made by gluing the template to a piece of stiff cardboard, then wrapping quilting thread (very little fuzz) around the template. I wick some CA glue into the thread to fix the joints and stiffen everything, then spray the railings with an appropriate color. In this case, gray primer was perfect. The CA-stiffened thread trims nicely and is easy to bend where necessary.
  15. Next up is the addition of the hull superstructure. Once the turret is in place, the remaining build consists of adding various deck details... ...until the job is basically done, except for the railings. Not much to it on such a small subject.
  16. I built this model in the spring of 2011. Folke was one of a small class of monitors built for the Swedish navy. Alone among her sisters, she carried her main gun facing aft, the idea being that she could cover a flotilla in the event of a withdrawal. My particular kit is the laser reprint sold by Paper Models International, but the model can also be purchased directly from Paper Shipwright. Owner David Hathaway has designed a number of monitor kits, as well as a variety of working craft. These kits are well-regarded in the card modeling community for their fit and detail. The kit includes the printed parts on two sheets, instructions, diagrams, and railing templates. Step one is to build up the egg-crate style hull skeleton and attach the deck and sides, all temporarily affixed to a sheet of glass to prevent warpage.
  17. Same designer, likely to have roughly the same level of detail. Go with whichever one makes your heart beat faster.
  18. Nice work! Seeing it makes me want to get back to work on my own HMS Fly. Cheers!
