![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
IgorSky
Members-
Everything posted by IgorSky
Many thanks Bob, Dimitris, Mark for your words of encouragement and support! I made some mistakes, but work is nearing completion. Best Regards! Igor.
Hi Patrick, Are Symphony and Signe two names of the one boat or these names of different boats? Best Regards! Igor.
Hi Carl! Thanks for good words! You discovered the secret of my technology - in fact, you need to put the necessary ingredients in a bottle, shake well and mix thoroughly with special wands and ... voila Best Regards! Igor
Patick, hahahaha! Two hours ago, my wife suggested that I was a micro-surgeon in one of my past lives. I think secretly you must be a psychic who can read minds at a distancepsychic who can read minds at a distance :) Best Regards! Igor.
Hi everyone! Many thanks for yours good words and likes! Yesterday, I could not escape one of the nightmares builders of SIB - one of the small but important detail broken off inside the bottle: I had to find a way to something to replace it: After quite some time of obscure manipulation inside the bottle back mast was installed: Best Regards! Igor.
Yes it is so, Patrick. But, unfortunately, if something breaks off, it breaks off after this point
Hi Dimitris, Perhaps you might be interested to see some more photos of this ship: http://loveopium.ru/putshestviya/ekskursiya-na-italyanskij-parusnik-amerigo-vespucci.html http://bigpicture.ru/?p=194333 http://www.liveinternet.ru/tags/amerigo+vespucci/ http://korabley.net/news/uchebnii_parusnii_linkor_amerigo_vespucci/2009-04-19-218 Best Regards! Igor.
Hi Jeff, I use these needles with a diameter of 0.3 - 1.0 mm. But they can be used not only for the port holes. For example, I think the needle diameter of 0.3 mm can be used as the yards or for making cannon for the models of very small scale. It is the tube through which you can skip the thread. Best Regards! Igor.
Many thanks, Bob! I remember about the figure of Captain Slocum. I'll try to do it, but there is almost no free space on the desk nearI'll try to do it, but there is almost no free space on the desk near еру steering wheel Best REgards! Igor.
Hi Carl, Yes, it is the pigmented epoxy as a basis and acrilic gel for making of the foam. I put a little the white paint with almost dry brush before using of the gel. Best Regards! Igor.
Hi Carl, Yes, there are 2 new photo tools - the pin vise and the steel pin. I magnetized the steel pin, and it allowed me to easily take the pieces of the needle to insert them into the holes.
Thanks, Patrick! I could not make an indentation with smooth edges. P.S. From Dykstra & Naval Architects - JH2 Rainbow 1st at the first race of the Antigua Classic Yacht Regatta! You can read more here - http://antiguaclassics.com/v1/index.php/over-the-rainbow/
Hi everyone! Many thanks you for your words of encouragement and support! So today I started doing a sea for the yacht. Best Regards! Igor.
Patrick, I tried to do it with paint before. But I could not make a smooth boundary in this way.
Yes, Patrick, I think you found the optimal solution Once in the situation like this, I used a brass wire. I made a small recess in the hull and then I glued wire and then polished it with sandpaper. As a result, I got stripes. Best Regards! Igor.
Hi Patrick, Take my admiration! How you did gold cove-stripe? Is this the paint or the metal strip? Best Regards! Igor.
Hi Matt, It is cool! I admire these small details each time when I watch your log. Best Regards! Igor.
- 425 replies
- bounty launch
- model shipways
