IgorSky
Everything posted by IgorSky
  1. Yes Patrick! I mean something like this. But I think it is necessary a little to paint for this model.
  2. Are you going to do folded sails or straightened? I think that you can use not the cloth, but the tissue paper or the film.
  3. Hi Carl! Many thanks for good words! I think really it just looks so complicated, but it's not very difficult. All you need to do - just try to do it. And I am sure that you will do it also succesfully. Best Regards! Igor.
  4. Cork ... every time you want to come up with something original... but do not always succeed ... )) Now needs just hang seal.
  5. The next step - I pulled, glued and cut the threads of the running rigging. I used a small tool that was made for this project.
  6. Next, I need to set the upper part of the hull on its lower part, to raise the mast and to pull the rigging.
  7. Finally, came the most important stage - I put the ship to the bottle
  8. The next step - I carefully pasted and glued all elements of the deck and prepared the upper part of the hull to the placing in the bottle
  9. The next step - I made the sea and I have put in the bottle the lower part of the hull.
  10. Hi everyone! Thank you all for your interest in this project and your Likes! Weekend is a perfect time for a hobby! So you can see the photos of the next steps below. I finally glue the ends of the standing rigging to hull:
  11. Happy Birthday Tony! Good luck always and everywhere for you! Your work is amazing! Congrats! Are you going to do sails? Best Regards! Igor.
  12. The carriage of the gun can be made from the pieces of the plank 0.4x0.5 mm. Oh, I see you managed to make holes for guns. Bravo Tony!
  13. What sizes the guns you need? I think that if you find a needle diameter of 0.3 mm, you can do it.
  14. Thank you Carl! No, I do not use the mill for this, because now I have the opportunity to buy different kinds of wood planks necessary sizes to me. Best Regards! Igor.
  15. Hi Tony, Yesterday, I also have tried to make small guns using needles. Ø 0.6 mm Ø 0.4 mm I think that the wheels can be simulated if done at the base of the gun transverse grooves and glue the rods of the desired diameter. Best Regards! Igor.
  16. Tony, look at these threads - I think you can find them in shop for fishermen. Guns... I think it is not so difficult to make the guns, how to make holes in the gunwales for the guns that are on the deck. Are your gunwales made from metal? Igor.
  17. OK, Chrome! I usually try to use for small models solid wood species such as pear, hornbeams etc or you can glue the planks of hard wood on the hull of model. In addition, if you use the planks of wood in different colors you do not need to paint the model. For me, the problem is always good to paint small model. Masts and yards... I like to use bamboo to make them. It is easily processed and I can do the holes of 0.3-0.5 mm in them if necessary. What yarns you are going to use for rigging? Are uou going to make the guns? Best Regards! Igor. P.S. Chrome, I think that the scale of 1/15000 is not quite correct. Perhaps the scale of 1/1500 would be more correct.
  18. Hi Taoism! Now I usually am ordering the planks my desired size 0.5x0.5, 0.5x0.8, 0.5x1 mm. But the planks 0.5x0.5 mm for the deck easily to cut out from veneer 0.5 mm using a scalpel and a metal ruler. Best Regards! Igor.
  19. Hi Chrome! Start of construction impresses me! I hasten to take a seat next to Patrick! Will you let me say a few of my thoughts about some of the details? Best Regards! Igor.
  20. Hi Jesse! Very nice work! You can try to use thin tubes for guns, such as needle syringe. You can also try to carve the guns out of bamboo. Best Regards! Igor.
