aviaamator
Everything posted by aviaamator
  1. Keith! I'm using The Altivar 312 speed controller. 1f220-3f220.
  2. I offer my deepest condolences to the families of the lost hockey players, as well as to all of Canada...My youngest son is riding on the ice, and his skating is the inscription: Ottawa...
  3. And then what????!!!!! ( to make a milling machine-need a milling machine!) In the photo my homemade milling machine.
  4. Anchor, until only experimental. If you do not like me , then make out of steel.
  5. I've slightly changed the way anchor parts are assembled. And another thing: today I went to work after the holidays!!! Bored!
  6. Russian proverb: seven times measure - cut once...
  7. On the frame you can see the seams from the casting, I would clean them. And work first-class!
  8. For some time he was not engaged in the construction of the model, because it is impossible to remain indifferent when people die in the fire, small children... There are no more words, only work helps to distract a little from this tragedy. I wish everyone good health!!!
  9. Many thanks to all! I am very pleased with the appreciation of my modest abilities. Matti! My nerves suffered a lot after many surgeries, and right hand badly compresses the items and tool. Can I change that? No! Therefore, I do not pay attention to it and continue to work! And this work brings me pleasure!
  10. Got my eye on! You have a very interesting name! Can I take a look at the nails that you use to build the model?
  11. Superb! Pavel! I agree with you, the ring has an ellipse, but it's quite disposable. I did not eliminate it, as my hands are clumsy!
  12. And here is the result! Without claims on the standard... Material-steel wire after heating.( annealing's.)
  13. For several minutes I created a small strategic supply! Thank you, all raze could not begin to this task. The seam will not be visible after soldering.
  14. Pavel! I advise you to cut the rings with a thin saw, not to have a bite. The joint of the ring will be much more accurate.
  15. No, no, I'm sure it should be better! I will strive for it! In the meantime, locksmith work continues...
  16. I would like better! But my vision and my hands let me down. Thank you for your kind words!
