Drazen
Everything posted by Drazen
  1. Thank you Peter! Nice, and a nice Baroque music,. Does Clous van Mechechelen conduct? Is reminds ma also to Ton Koopman, one of my favourite old-music conductors. Relaxing and done in the spirit of the baroque. Enjoy your beer! I will enjoy mine - a smaller high-quality brewery here - "Hirter Bier" here in the region, who I support/consult in innovation management. Proost! Drazen
  2. Jan, 1. Solution: You will find the answer on the last photo. On the wall, there is a small humidity measuring device. I am trying to keep the humidity between 45% and 55%. In the winter, I have a humidifier and in the summer a dehumidifier. In a normal situation - if I would not work in the cellar - this would not be any problem since the deviations in my flat are from 42% to 58%. 2. Solution: I have reinforced the areas which were opened and I could work with epoxy and glass wool. The complete stern lower part (area near the sternpost), I have filled in with epoxy and glass wool and the vertical walls on the kampanje dek and hutdek, I covered with the several layers of glass wool. 4-6 layers come out thin, but this holds very well and will be covered later on with the klinker anyhow. 3. Solution (did not work): Since the cracks on the deck near the gratings were not possible to reinforce with epoxy laminate, I tried to spray the shellac through the gunports. I sprayed several layers of shellac, starting with very thin, to normal. The idea was to cover the wood also from inside and thus prevent humidity coming in. This did not work. It seams that the covering is not well or not possible and the humidity finds some possibility to enter the wood. Still, keeping the humidity under control makes these cracks nearly not visible (see my next photos). If I one day decide to live in Norway (what is a heart wish of mine), there, I may have again the problem due to the low humidity. Conclusion: Next time, I would do the walls of my base layer much thinner and think about reinforcing the structure from inside. I was talking to a colleague of mine (Alexandr Dobrenko - unfortunately, he died in a car accident last year) and he said, the problem is less with peer and he also covers the wood with special oil from inside. Just as an option to think. Strong humidity deviations + thick wood - without reinforcing structure inside is really a big problem. Following photos before and after my actions... Drazen
  3. With this, the klinker is ready. I didn't show the whole railing, which is ready since months, I will show the making of the railing later on, when it will be installed in place. Drazen
  4. Making klinker on the hull... For this, I needed to cut different widths of the klinker planking and on some areas - continuously narrow them. So I have the same number of planks at the beginning and the end of one section of the hull. (The part of the hull which I needed to plank with the klinker is higher at the stern.) Drazen
  5. My protection for the hull - same level as the waterline. One can imagine how the ship looks in the water. This protective parts can be disassembled easily if needed. Drazen
  6. Here is the ship with painted area below waterline and I did later some construction to protect the painted hill from unintended touching with tools I am working with. Drazen
  7. ... going on with the construction on the galleries... Drazen
  8. Towers are ready. The windows are missing and some details. This will be done later. The sharp edges where the klinker are connected are not very exact, but I didn't care since the sculptures are going to cover this areas. The whole system is like LEGO - it can be disassembled in order to paint the parts later separately. Also the other parts on the side galleries can be removed. This will be shown later. Drazen
  9. Making the construction on the towers... The vertical pieces are made of two stripes under exact angle in order to fit well. Drazen
  10. I continue with the towers on the side galleries... I glued small parts with epoxy and gave it the final form. Drazen
  11. In the meantime, I finished painting the area below the waterline. Drazen
  12. Making the "slingerlijst" out of two stripes which I have bent and formed before gluing them together. Drazen
  13. Ab, welcome here to the MSW. I am soooooo glad to meet you here! I didn't know about it till today I occasional found a link when searching for some information in the internet. All thet we are talking per emails etc. you can now find/follow in my build log on De Zeven Provincien: ... and here the link to the build of Royal Carolinf my friend Mile Bijelić did: Have fun! Drazen
  14. Mile's next project will be the HMS Royal William 1719 in admiralty. I am looking forward to it a lot! Drazen
  15. And now, pay attention - the ship is ready! After some fine tuning on the rigging and the yards, Mile Bijelić has finished his second model of the Royal Caroline 1749 on 22. October 2019. I will try to make some nice high-resolution photos when I visit him in Zagreb next time and will post it here. Drazen
  16. An example how a particular sail has been made... Drazen
