Garward
Everything posted by Garward
  1. Good evening, Anja! Thanks for care about we wash health, I considered it and have just supper and now with new forces I will continue . Work at the computer to me is very habitual and at all I don't strain, at the same time I also systematize available information. That I already published on Montanes on new MSW - only small part of the previous publications. Therefore while there is time and opportunity I try to restore a new forum to a look habitual for us.
  2. 1.14 . Production of imitation of cannon hooks and eyes The brass foil 0,3 mm thick, wire of 0,75 mm, rubber lining and drill shaft for foil punching is used.
  3. 1.13. Сontrol blade Loops of a control blade are made of a brass foil of 0,5 mm and a wire of 1,5 mm; PV 209 gumboil, PSR 40 silver solder.
  4. I tried to do samson posts of different breeds of wood, but stopped on a pear.
  5. 1.12. Fore body of the hull Installation of details of fore body of the hull.
  6. Hi, Carl, thanks for an assessment! Yes, I plan to restore gradually the main reports on the models, published earlier on MSW.
  7. 1.10. Channel board Channel board are made of a plate, glued of 4 layers of an interline interval of ebony. Plywood bracket from a kit are replaced by the wooden.
  8. Continuation Decorative rubbing piece are established.
  9. Continuation Guard rail is established on the hull.
  10. Continuation Figured curves of the ends of guard rail are made of a pear.
  11. 1.9 . Figured levels for rubbing piece and guard rail Levels are made of a pear on the MF-70 Proxxon milling machine by means of extras - a laid on little table (brass of 6 mm, fastens in grooves of a coordinate table) and self-made figured mills (from nails with a diameter of 3 mm).
  12. Continuation Rubbing piece and covering from ebony fine line are covered with a black pigment.
  13. Continuation Before continuation of further works on the hull the sheeting is put on its lower part - two layers of shellac.
  14. 1.8 . Imitation of nails Imitation of nails is executed from a brass wire of 0,5 mm by means of a self-made mini-drill (the DPM motor in the case from cases for a film + the boss with grips) with a drill of 0,5 mm and side-cutting pliers.
