Garward
Everything posted by Garward
  1. Continuation All details of galleries are established. Columns from the Australian cherry (Cherry Ballart).
  2. 5.4. Windows Are cut out from a pear 1 mm thick interline interval
  3. Continuation I made one option of replacement, not absolutely it was pleasant - I made this detail on another.
  4. 5.2 . Sinks DSH/E electrofret saw, pear, inserts from ebony fine line interline interval; ready sinks are covered with linseed oil.
  5. Continuation Milling of end faces of overlappings is executed on MF 70 milling cutter by means of shown below extras. Mills are made of nails with a diameter of 3 mm.
  6. 5 . GALLERY Replacement of plywood and cast details wooden (pear) proceeds. 5.1 . Gallery overlappings On a photo without No. gallery drawing from a set is shown
  7. Thanks for an assessment of my work! I these details held when milling (speed of rotation of a mill about 3000 turns) fingers if strongly not to press them, danger minimum. However, time of their production, but the whole fingers increases .
  8. 4.5 . Installation of covers of ports on the hull Covers of ports were established on the hull after construction of gallery and finishey processing of the deck.
  9. 4.4 . Ready covers of ports. Ready covers of ports after impregnation by linseed oil.
  10. 4.3 . Assembly In the beginning wooden details are stuck together by glue cyanogen, then the knife imitated seams between boards and metal details are established.
  11. 4.2 . Metal details Loops from a brass wire with a diameter of 1 mm, an axis - brass nails with a diameter of 0,75 mm. Eyes from a brass wire of 0,5 mm, nails with a diameter of 0,5 mm. Loops from a brass foil of 0,3 mm.
  12. 4 . COVERS OF CANNON PORTS 4.1 . Wooden details Covers of cannon ports of the 1st battery of 14х14 mm in size are made of a pear and padauk
  13. For prevention of such incidents expediently to insert balsa blocks into nasal part of a set of the hull.
  14. Here so the gun carriages of the Spanish guns made presently (a museum "Royal Artillery Factory in La Cavada", Spain) look.
  15. 3.6 . Ready guns Each gun consists of 35 details: 11 wooden and 24 metal
  16. 3.5, Assembly Assembly was carried out by means of the simple adaptation, glue - ZP-30 cyanogen.
