Essayons
About Essayons
  • Birthday December 22
  • Gender
  • Location
    Bryan Texas
  • Interests
    History, naval history, ships (all eras)
1,137 profile views
  1. Tom,Do you have a company email? I have questions... R. Chisum
  2. I'm not sure where to post this question, so here it is: Under Guidelines there are companies that aren't allowed for reasons stated. My question is about CAF Models and if they are on, or perhaps should be on the list, or are they a legitimate company that honors copywritten protections of other's creations? Admin: if this isn't the correction place , let me know where it is refiled, or respond to me by PM.. V/R R. Chisum
  3. Yes Mark! That was my initial question on Hahn's framing method, the upside down method, but mixed with conventional frame method of cutting out each futtock and assembling them.. I think it will take some study to build the jig pattern. If it were a RN subject where the upper futtocks varied in thickness(sided) and relative position to each other frame(use the HMS Euryalus 1803) for example. On the other hand, I have the Ancre book/plans for the Hermoine. Their drawings show a constant room and space of ~24"/12" all the way up to the upper futtocks, so making a Hahn-syle jig could be very feasible. Randy
  4. Yeah Mark that's what I was contemplating; extending the frame tops but still building the frames in the conventional manner to reduce wood waste..Also looking at the way DVM 27 describes some French builders.. The main reason as I already mentioned is that the Hahn frame can be put down in the box to protect it if work gets interrupted and that it stays relatively stable... just pondering my options!
  5. mtaylor, I fully agree. The style keeps the model very sturdy, much more than the traditional "shipyard" configuration. It seems to me that making a framing jig would be the largest hurdle.
  6. If you are able, cast your parts in Type R pewter (no lead). It flows well but it melts at 575 degrees F which will shorten your mold life. I believe archivists classify as some pewters as archive grade.
  7. Okay I pose the question to the forum: Has anyone built a plank on frame model with as designed scantlings but in the Harold Hahn method? The downside is the extra wood required. The upside is that the hull while under construction, remains stable and protected. This alone is a big plus since I might get to work on it constantly. If there is a build log that to which one could direct me that would be great.
  8. Thanks all for the repllies. Mtaylor, yes I think I will look into maple and pear depending on the application, saving boxwood for carving.
  9. Curious of the pro's and cons through your own experience of using Alaskan Cedar for framing, planking, etc, vs. Boxwood, and Beech.. Randy
  10. Here's a picture of the famous HMS Black Joke which was in the West Africa Squadron..white ensign. Curious what fleet they were under.
  11. It sounds like she was in the West Africa Squadron (Preventative Squadron). They caught a lot of slavers between Africa and Brazil.
  12. Either a red, white, or blue depending on what squadron she was assigned. Each fleet had these squadrons. Exact areas and how they changed and were adjusted over time is my question as I have a query on this topic. This until 1864 when the white ensign became the royal navy ensign, blue for reserve and red for merchants/civilian. Not sure if your ship was in the West Africa Squadron.
  13. Curious if anyone has a map of the RN squadrons(red, white, blue) area of responsibility from about 1750 to 1865 which were assigned to their respective fleets, or they might be stand alone squadrons? I would like a more detailed depiction (and any changes)..R.C.
  14. Hello everyone! I've been a member of this site before and modeling most of my life. I'm trying to compile a group list of modelers in Texas. This would be could be shared with each other(or not), but would serve as a tool to get everyone together to exchange ideas, etc. almost like an unofficial "club". Please PM me and we'll go from there. Randy
  15. https://www.woodenmodelshipkit.com/product/4930-open-panama-fairlead-10x8mm-2/?v=7516fd43adaa Not sure of the size you need, but it shouldn't be hard to solder from brass...
