Everything posted by JeffT
That is frustrating. Have you tried contacting them?
Weekend progress. Have most of the stem assembled. I used the ultimation sander to clean up the ends. I removed the 120 grit sand disc that came with it and replaced it with 220. The 120 is a little too much for this. I glued the two halves of the lower keel together and the first section of the keel which forms the boxing joint. The inner parts are just dry fit for now.
Starting with the stem. I just did a quick dry fit and everything fits together almost perfectly. I haven't touched anything yet and just very minor adjustments needed. Doesn't get any better than this. I won't remove any laser char from the surfaces until they are glued together. Don't want to risk rounding over any edges.
This will be my build log for the Speedwell. I just received the box yesterday so not much to talk about yet. I need to go through the parts and make sure all is organized. I am planning on having a copy made of the plans in Tyvek and a second paper set. I don't plan to cut them up. I can just print the areas of the plan at scale that I need using the pdf's provided by Chuck. I haven't set up a build board yet but I will probably build the keel and all the frames first anyway. More to come.
Welcome to MSW
