jaybees
Everything posted by jaybees
Hi Did you get your rigging and masts done on the Vespucci.
Really bad and confusing instructions.
I am really stuck on some clarity on the yards.
Cheers
Unfortunately, the rigging instructions for this kit are full of errors. For instance there are no block and tackles employed on any line: there are no halyards listed: there are no sheets and tacks for the lower sails. Most of the other lines are run incorrectly. There are no belaying pins and not enough belaying points for the rigging. And the plan seems to imply that most of the rigging leads to the base of the main mast.
Personally, I scrapped the entire plan and rigged the ship per the description in Harold Underhills book Masting and Rigging the Clipper Ship and Ocean Carrier, covers ships of that time frame.
Rigging the ship to this plan necessitated adding additional pin rails, eyebolts and cleats to appropriate points about the ship. I also had to change the whiskers and martingale on the bowsprit to accommodate the additional rigging..
If you are going to use the plastic sail they will have to be trimmed down quite a bit in their vertical dimension in order to fit and you should glue in a bolt rope around each one in order to prevent the rigging from ripping out of the sail.
I purchase probably 100 or so 2mm single blocks and about 40-50 2mm double blocks to complete the rig. I also layed up several sizes of three strand stainless steel wire rope to use for the standing rigging.
I bought some very fine chain to use for the bowsprit stays and shrouds and anchor chains. I also used chain for the fore and main lower topsail sheets. The upper topsail sheets and some of the other rigging should be chain also, but at this scale I could not get any chain that would work.
Overall, I would have to say that making this model was fun due to the research and challenge of reworking the entire rig. But I am only somewhat satisfied with the quality of the result. The very small scale prevents an accurate depiction of the ship.
If you have any specific questions about the rig feel free to ask.
Regards,
Henry
How did you furl the signs?
