I'm thinking of cutting in the angle a bit more. Cutting into the darker wood...to slightly harmonize the vertical and the curved. I think I might have added a bit to much to the curve...filling it out a bit too much. No problem. I'll add that to the several adjustments I need to make before moving on to finishing up the planksheer molding. Rob
Rich. I see what you are saying....however, after great reflection and profiling from every painting we have of her....it appears to me that the correction I performed makes her stem more of the upward angle also described by McLean, "The cutwater is tapered to an angle". Are you suggesting I cut it back to my original curve? Back to the original stem line, I had originally cut...without the addition? I supose I could cut the stem back half way...to mimic more like Glory. Rob
Today's projected work schedule will include addition of the McKay *Hoods*....port and starboard. Once they are fabricated and installed, the addition of the leading planksheer moldings will be installed atop the leading edge of the *hood*. All the external moldings have to be installed prior to painting. Since the scroll work is unspecified, I can assume artistic license, in this matter. I prefer to get the external paint out of the way, prior to deck installation. Just makes keeping things over spray clean. Rob
The forecastle and poop decks are level with the main rail...once I add the scribed decking. I will then add the 18" monkey rail with its cap. I think when all is dry within...I will begin shaping and carving the molding on the rail cap. It has a kind of carved out center....creating two lobes similar to the planksheer molding (currently where the line is drawn). This same trim look will be carved on the monkey rail cap as well. (The stern rail around the stern stanchions will also be carved) (at a later date). It's these little details that set the build apart. I need to address these issues before I paint the hull black. As I look at it now....there are so many small details that need to occur at the same time...or there abouts.
Rich...recalculating my measurements...Her bulwarks are 6.5ft including the monkey rail. That means her main rail is at a height of 5.1ft where her poop and forecastle decking are located. Correct? Her planksheer sits atop her 12" waterways. I'm assuming her main rail is measured from the deck, not on top of the waterway? I am finalizing all these measurements so I can calculate the placement of the external planksheer Moulding, which is be 6" thick and 16" wide. Same size as the rail cap. fun, fun, fun... Rob
