Harry...fine work, however, I don't mean to be a Debbie downer, but your chain guys, port and starboard are too long. They should terminate on the hull, just in front of the catheads. Otherwise, the anchor would become fouled in them. They are behind the Catheads and cross right under the catheads. Making raising and lowering the anchors very problematic. Do you see? Sorry. Rob
- 200 replies
- Flying Cloud
- Mamoli
It's a safe bet to keep this *running* rigging black...to represent the tarring. It had to be preserved or it would rot. Lanyards were extremely susceptible to rot...being soaked in sea water and generally tightly fit...preventing good air circulation. When the USS Constitution was recently rerigged...her naval architects chose black rigging for the lanyards , foot ropes and ratlines. If they concluded it was appropriate...you can too. All my clipper builds are rigged with black rigging for these standing fixtures. Rob
Been enjoying your log....and I must say...you produce some of the finest quality work, I have seen. Great job. Rob
Sometimes Revelation is the fuel for motivation. I use steal wire, which does not abrade and is more naturally Pro typical. IMV. New ideas and material are always on the radar. Good job everyone. Rob
- 359 replies
- Flying Fish
- Model Shipways
Flying Cloud Bowsprit Jibboom Line/s Rigging Help
rwiederrich replied to hof00's topic in Masting, rigging and sails
Just remember....there are no photos of Flying cloud....just models and speculation. Duncan McLean describes her hull and deck furniture the best.....however. The photos I provided of Glory of the Seas...McKay's last clipper Must be your best option. I cannot assume he would have done things differently. These images are *EVIDENCE*. Will you be correcting the kits cutwater and stem to replicate as she was originally built. Utilizing McKay's secret *Naval Hood* design? Contemporary paintings and models clearly get her bow wrong...simply sticking the figurehead on the stem. This photograph of Glory of the Seas....depicts McKay's famous *Naval Hood*. Note the location of the figurehead...on the Hood under the bowsprit! Drawing by Clipperfan. Rob -
In this close-up of Glory of the Seas...you can clearly see the fore topmast stay pass through the Bees....and back toward the root of the bowsprit...where it terminates. Not sure if McKay used this arrangement on Flying Cloud. She still sported single topsails. Near twenty years separates their evolutions. -
Well Harry, I know what McKay did on his last clipper, Glory of the Seas. Not shown in this image, is her jibboom stays...which were all(four per side) inserted along the front of the cathead. You can identify the bullheads. -
Furled , unfurled or no sails -Preference
rwiederrich replied to Canada Steve's topic in Masting, rigging and sails
Paul...it is acceptable to simple knot the bunt at the block. (blocks are secured to the jackstays, or simply tied off at the yard) When the bunt line is in use, it is fed down the course of the sail and affixed to the rope edge of the foot of the sail. When sails are removed...you can simply knot the bunt line at the block...then finish running the line back through the top block and down to its belay point. You retain the bunt detail without the sail. Same with the clue lines. What I did once....to make it easy, was to tie the bunt off to the block eye....then wrap it around the yard, running the bunt back through the sheeve of the block snugging it up against itself and then running the line up to the top blocks Hope this helps? Rob -
When I built my Glory of the Seas...I wanted all the rigging to be visible. Nothing was left off...cept the stunsail booms and their rigging....since they were not present during the period I was basing my build on. -
Rigging Mast Deadeyes Order
rwiederrich replied to acaron41120's topic in Masting, rigging and sails
I did the same for my Great Republic. Once the shrouds are fixed to all the masts the easy part comes by adding the yards. -
I always rig the topmast deadeyes and shrouds off model before I set the mast. Much easier that way. -
A little bump to the thread. I'm sorry I have been very inactive on this build as of late.....My daughters house purchase fell through....so she and her's are back home. I've been tackling the new roof install on my garage....so that too has held me up. And now its getting to spring...which means loads of yard work and outdoor activities. I hope to get back into the shop and organize my modeling thoughts...once again....soon. I hope everyone is having a smooth new year and coming spring. Rob
Hanks for attaching staysails to stays
rwiederrich replied to Dr PR's topic in Masting, rigging and sails
Sorry for the vary long absence . family and moving stuff around...takes time. I'm not all back together again...but getting there. I see what you are talking about. when you drill a hole through a thin mast or yard...the point where you drilled becomes vary thin and fragile. especially along the edges on either side of the new drilled hole. this hole make the remaining material very weak and apt to breakage. What I do in this case is drill the hole.....then...fill the hole with CA glue. letting it set hard by using an accelerator. I then redrill out the hole. The Cured CA strengthens the fibers of the wood on either side of the hole by soaking into the wood fibers and aids in preventing the wood from fracturing again at this point. Rob
This second model I decided to build the case into the wall and ceiling....resting on custom made brackets. I used three sheets of plexiglass cut from a single 4X8 sheet.
Well I need my models protected....I have 6 grandbabies. the first case I made with glass it weighs a ton. I can disassemble the side and remove the model to flip it If I wish.
Thanks everyone. My wife reminds me that this is the time we will never have again and we must take full advantage of having our grand babies with us so intimately. They are not moving far away...and we generally see them once a week or so. We had a big fire in the pit last night...enjoying *smores*. It was nice..untill the boys began to rough house....dad had to shut that down fast. Boys will be boys...they say...... The girls weren't far behind them. I can only see my model room through memory...... I still have my advice and opinions though...... Rob
Sorry for the laps in activity. I began to lay planking by getting everything ready and a situation arose. My daughter is buying a new home....however that is upon the contingency of selling her own home first. that means she and her family will be staying with me for around a month. I had to use my work shop as a temp storage space to make room for her and her 6 kids stuff. Needless to say, I have no access to my shop at this juncture. It is on the other side of the spare bedroom, she and her family are using. I've had to put my build on temp hold for the time being. We have been quite busy around here making room and decluttering the house for her family. She has 6 kids...from age 10 on down to 2. So I have lots of stuff to put away and protect. She's getting a much bigger house...if everything goes as planned. So hopefully in a month from now...I'll have some progress to post, when I put my world back together again.
