rwiederrich
  1. Working on milling the edge moulding on the port channels. Rob
  2. Some of the men from the earliest models, are still crisp and clean. I have a sprue of men from a 50's kits of the Cutty Sark. They are very well injected actually. I can only assume the gentleman Whom I got these wooden models from got his men from a Conne kit or somewhere like that. Rob
  3. Not much time to work on the aft cabin I haven’t secured the ladders , cus McLean’s description says the captains cabin “overlooked” the main deck. So I’m considering adding a small window on both sides. Rob
  4. To me honest Nic....I got them from a model maker years go, who was renting from my cousin and who abandoned his home and left all his stuff (Junk too) to my cousin. His entire stash of models (All wooden kits) He had a partially built a 1/96 Constitution and America ...and he had a pastle of these 1/8" men done up. I've used some on Glory of the Seas and some other things as well. All in 1/8". Some are pretty poorly done...others are serviceable. They were in the mix of model stuff I got. Rob
  5. I knew this data was in the folders...I just couldn't remember where. Thanks for pointing it out to me Rich. Now I'll make some comparisons and recalculate. Rob
  6. Indeed. the trick with any mast compilation is devising the doubling distances. We know how long each mast is...but how long the doublings are can be a tricky guess. Each mast must be included in each doubling...thus that must be included in the total mast height. These temp masts I made are only proximities at this point. This is why....I only made the foremast with doublings and the main and mizzen are single sticks. It's all part of the calculation process. Is there any data truly identifying her actual mast heights? Just throwing out ideas for evaluation....as an aid to others. Rob
  7. Everything is dry tested. I the placed the portico for reference with Johnny Shellback. Rob
  8. After I set the test masts. I jumped into the poop cabin bulkhead. Rob
  9. Began to add the mock-up masts so I can get the correct angles for the chain plates. Rob
  10. Spent time finishing up the forecastle front and companionways. I also added a foul weather shutter partially open exposing the window behind. Rob
  11. Further research shows that Chapelle's drawing shows the point of the forecastle facing bulkhead is rough 29.5 ft across....making our 27ft rough guesstimate pretty close...considering all other hull modifications. Notably the reconstructing of the forecastle front and relocating the W/C's and windless internally. Rob
  12. Staghound, was probably dimensioned after the typical *fish* body method. With her fullness being amidships and then tapering aft to her narrowest...at 24.5ft. Forward, we can only assume her entry followed the natural curvature and inclination to terminate with a sharp entry at her cutwater. Everything in between, is an educated speculation. McKay's own half model is our only data point. A good top view would have been nice. Still you can make a good educated guess from the images you acquired. Personally, if her forward extreme was any wider than she is currently....it would change her overall body curve....forcing her widest section to be moved farther forward. Or at worst, not giving her the smooth contours she has. This is exactly the issue I was projecting on the issue of scaling transcription errors. We are moving from the verbal (An that is vary subject specific),to the 3 dimensional. Even with McLean's measurements....were they inside or outside measurements? Taken from a corner or a projection of molding? How does one extrapolate...ABOUT? Rob(Moving forward)
  13. Here's the call Druxey. We do know the space was *airy, well ventilated and well lit*. This is the first time the forecastle of Staghound or any early McKay clipper has been truly realized. The working windless was below decks...3ft below, actually. Like any window...I would assume there were clap shutters that were applied during heavy weather. I placed the windows just over a scale foot or so above the decking. and the companionways doors 6 scale inches. this means the windows are 4ft above the floor in the forecastle space and going nearly to the ceiling. She also had prismatic ceiling light fixtures to aid in her illumination. I admit it is a deviation from what we have always assumed.....like the McKay stem/cutwater, *hood*. These interpretations are not of my own doing...however the construction and expression is. I might even simulate on one window the addition of a partly opened shutter....to drive home the clear practicality and application. Thanks, for the question. Rob
  14. See...this is the stuff of scaling transcription errors. I knew right away, you would bring this up.😆 From your original drawing we *concluded* the width to be 27ft. No real true dimension is ever given from McLean....only that her entry was the sharpest ever seen on her model. In this space I could only fit the two companionways,(3ft including jams) and the ladders(3ft),(required to ascend and descend) her forecastle deck. What was left over was trepidatiously divided for windows, space between fixtures and such. I don't recall the actual width off my head, but I do know it is around 26.5 scale ft.....not 18~20. I'll reverify when I get home. No windows were places outboard the ladders...this space is relocated for the below deck W/C's. I might still add some paneling embellishments. Rob
  15. Everything is just test fit. I’ll reduce the companionways roofs slightly and add the ladders on either side of each companionway outboard. I opted to add only 2 windows for the forecastle front. It looked crowded and a bit overdone with four smaller windows. I figured I’d add this and the poop cabin facing before beginning the channels. Rob
  16. Your 1/78 scale allows for greater detailing and, thus requires far greater perfection of that detailing. I have the ability....just not the desire, to build any larger then my little 1/96 scale. Just enough detail to wow the critics, but not so much to extract any joy I may derive from building the model in the first place. One time...and only one time did I ever build a clipper larger then 1/64 scale. It was as large as a canoe. I only did the hull. Waaay too large.......waaay too much ambition. Plus, these models have to fit with each other in the house. One reason I strayed from 1/96, when I built the Great Republic. It would have been 6ft long...and no place to live in the house. I truly am moved that you would even consider thinking my work has any respectable merits. again....thanks. I'm enjoying your CS build vary much too. Rob
  17. Thanks Rich. It does complete the stem. When the bowsprit gets finished it will tie it all together. Rob
  18. It's all a mystery.....or...where there's a will...there's a way. Some long holes were pre-drilled, then the rod was heated and was pushed through, burning the way through, trueing the hole. However it was done it was done accurately and quickly. Staghound was built in only a couple of months. Rob
  19. Great conversation....and if we can take anything away from this information...it would be, *How did they do all of this drilling (accurately) in a timely manner, without a modern drill motor and spade bit*?😲 Wooden ships and IRON men....... Rob
  20. Thanks Rick. I only had time to fiddle with some weathering...... I have to make all the chainplates first and that means some metal work. Rob
  21. She is a much sleeker shallower model for sure. I appreciate your investigation into the more accurate hull contours....but I ain't going back and since we know the narrowest point was only 24.5ft...it is only within the bowing of her hull from there to her max breadth of 40ft that can be contested. The images never show exactly what you want to show and they ALWAYS reveal what you don't want to show....flaws in detail and workmanship. Well...I'm moving onto the next phase...addition of the chainplates and channels. this process takes time and, thus I will have to build mock-up masts to properly attain the correct angles for the chainplates. So as I had mentioned to Druxey....I will be slowing down for this. I also have to make the 60 or so chainplates and their connective plates prior to install. But first, I've identified some overlooked items I have to address first....items that will require some additional time and correction. Even things get past me......magine that. Rob
