GeorgeKapas
Everything posted by GeorgeKapas
  1. A similar project to the cruiser Averof. Once again, the lack of detailed plans was a problem, which was alleviated by the small scale and the decision to make it waterline. There are almost no models of this class of ships outside the two in the museums here in Greece. I wanted to make one for some time now. Bizzare little battleships, with an unconventional layout which proves a bit of a challenge to recreate. In any case. Here are a few photos of what I am talking about:
  2. Thank you all! She is finally ready! I managed to find a small enough chain in a jewelry shop, and with small additions she is finished. The final gallery:
  3. The model is almost ready, some details need to be added like chains etc. I also re-did the base....again!
  4. The deck is painted by hand (I did the lines in MS paint and printed them on A4, then added color etc)
  5. I know this is getting tiresome, resurecting this thread already twice... This time I starting tinkering into a diorama - base. I am not sure about the background at the dock, I havent gone that far yet..
  6. Once again, sorry for the lack of updates, as always I am working on many projects at once!
  7. Thank you. The sea is a very thin papier mache with a coat of wood glue. I may need too add a few more coats of wood glue. This method gave a hard time at this scale (1/700)
  8. Updates!! The base and sea has progressed a lot, and the model as well. Photos are not good, the sea gloss is not very visible here. I'll try to take new photos in the morning.
  9. BTW I also started two more Royal Hellenic Navy ships, the old pre dreadnought Hydra and the destroyer Aetos (1912). I may have to start new threads for them? I am not sure.
  10. More work on the tripods, and the first railings. I went back and forth many times, the old funnels were scrapped, and I started new ones.
  11. Yes, well, her engines are not the main issue. The problem is the last time she had her boilers retubed was in 1928. And they still burned coal. They are now beyond any functional restoration. As you can see the engines are in good order, certainly restorable, but it is impossible to practically feed them steam. Not to mention the screws, shafts and rudder have been removed to seal the hull watertight.
  12. Filling and sanding is the order of the week though. It seems the pieces will turn out well in the end, but this is the first time that I attempt this. I am really glad with the choice of 1/700, as anything bigger would have certainly be a problem.
  13. Thank you. It would be a magnificent sight to see her steaming again, but that is am afraid too much of a luxury expense for the Hellenic navy at this time and age.
  14. Thank you. I'll post a few more: Progress on the various parts, the start of the forward tripod, and the concept of the diorama: A pencil for scale!
  15. A model of Averof was in my mind for some time, but the resin kit from YS was really expensive. I dont have much experience with scratchbuilding, only kitbashing, so I decided that the best course of action was a small waterline diorama in a familiar scale. So 1/700 it is! I'll propably add photo etched railings so that will help. But needless to say the ship comes up quite small. All this because the Royal Louis kit is really tiring me out... The diorama will show Averof in Faliro as she is today. So, materials are foamcore, cardpaper, superglue balsa and melted spruce. I went for a simple bread and butter method (the ship is tiny) It will require a lot of filling and sanding though First steps
  16. Yes, here it is: Many wooden kits of her also copy this, Mamoli has simply added a few gratings around the capstain, but the paris model is like that:
  17. Progress on the deck. I dont know what to do with the forecastle. The model in Paris has no gratings, just a large empty wooden area with a capstan, which seems odd and in a very high placement for a first rate
  18. A little bit more work on the deck fitings, gratings rails and columns. Most parts still dry fitted. Also notice the ship is full hull, at the very least I am very pleased with how well she fits in the sea base without noticing it. Saved me the very unpleasant task of cutting her up.
  19. Thank you. The sea is a mixure of wood glue and soft paper, on a base made out of modeling foamcore board. After drying it was painted with acrylics and glossed with more woodglue.
