Wiktor.L
Everything posted by Wiktor.L
  1. Hi. I glue the broadsides. And i made a bad mistake.... I m retouching the edges and i went to centre of printed side... Any sugestions to "repair" it? I m complete "green" about it....
  2. Hi. They are to identical. Not enough shadows... Good luck!
  3. Hi. I draw trial studding with pencil. And initially i grind the hull and stained it. Its look great. And with the occasion i glue 2 planks.
  4. I end the underwater part. Unfortunately stealers on this side are moved relative to other side.
  5. Hi. I end the one of the broadside part of the underwater planking. I know, maybe someone can do it better, but for me its good
  6. Hi. General painting watch good, mistakes glue on the model dissappear. But if you can change details now-do it. Shading (darkers or lighter from the base colour) does the weak thinned paint. Dont forget about wash, and dry brush technick.... And the priority for figure painting, really thinn brushes! Can be not expensive cosmietic, maybe for nails. Good luck.
  7. Hi. I going to end 2nd layer of planks the underwater part of planking.
  8. Hi. I started the relations of the model HMS fly. I try to make caulking with the black cotton thread. Two first rows of the planks are bad, but on this will be deck and it will not be seen. http://www.koga.net.pl/forum/viewtopic.php?f=7&t=47195&p=84654#p84654
  9. Hi there Will come putty wil be good After grinding that all i paint this on copper colour. Before filling that i cleaning the hull with
  10. Hi. I dont like brown paint on Vasa instructions, beacuse that i glue the pre-stained planks. That stain: Stained the hull with 50% opaque oil paints its good to. Polish modeler used 50% opaque paint to, that its effect: http://santisimatrinidad.jun.pl/viewtopic.php?t=2039&start=8 And the polish dea page build: http://blog.kolekcjavasa.pl/zeszyt-nr-52/ Patience, once a month pack was deliver to you I have 100+numbers. In the shop was 120..... Tweezers, and you can glue that on place.... In this scale using only glue to the ratlines was..... In 1/65 scale must be the ratlines knot. Good luck! Whatever, i glue few planks, and stealer...
  11. Hi. I glue doors and started under water planking. That job can be make better, but its my 2nd card model...
