sire_eris
About sire_eris
  • Birthday 04/24/1983
  • Gender
  • Location
    Basel Switzerland
  1. 100% completed model on the stand I built for it. Really happy with the result. All went good and I learned a lot during the process of building. I'm somewhat proud of the optimizations I made on the kit, makes the model look much nicer than all that die cast parts... Thanks guys for reading my blog here and I hope it was interesting and may give one or another some hints and inspiration 😄
  2. Took a week of holidays and used this time so have a concentrated "sail mounting week". So all sails were mounted without any interruptions by other projects. All sails are up.
  3. First sails are up. Fixing the ropes to the dollboard was really intricate 😅 IMG_2908.HEIC
  4. Time to fix all blocks and the sails onto the yards. I prepared all sails like this before mounting them one by one.
  5. After a very long time letting this model idle and working on some other projects, I finally resumed working on it. Time to go the last mile and cross the finising line... (which happened als already quite a while ago but I never updated and finished this building report... 😉) In order to add some deails to the ship which are not inculded in the kit, I built two small bilge pumps from scratch. IMG_2899.HEIC IMG_2908.HEIC
  6. So far all worked well. Even served the part of the stays which go around the masts with thin rope, including a "mouse". Took me quite a while to figure out how to do that and had to build a serving machine for that, which I rebuilt by looking at the serving machine offered by Syren model (thanks guy for putting the assembly instruction online!).
  7. Status of model as of End 2022. Masts are completely set up with all the standing rigging.
  8. As I haven't worked on the ship for quite a while, respectively only did some stuff during some short periods, it took some time for the next post here... Recently I picked up work and now am trying to finish the build. The rigging is something complete new for me and a lot new stuff and techniques to learn. So I have quite some respect regarding all that work - also stuff can be broken easily now when working on the model 🙄 As there was some space on the deck and I thought this detail is missing in the kit, I built a scratch capstan:
  9. Thanks! Looks like Artesania did change some parts quite frequently. My instruction says the deck gratings are included in die cast but wood was included to build them, the bow grating should be included as die cast part as well but there was nothing at all in the box... I previously built the SF2 cross section and there was also a top of laser cut wood included. My ship is the old version of the SFII (single planked), so probably the older kits contain (or should contain) more die cast parts than newer ones? Anyway, AL is out of business which is a bit sad, I liked the kits and a lot of the parts are also very well made and of good quality. The included 5mm planks were good mahagony and the sails are pretty nice I think. They look handmade and are of good detail.
  10. Next part in the kit that was really ugly was the top plattforms (how do you call them in English correctly? In German the "Mars") of fore and main mast. So I made some own completely from scratch, trying to rebuild them as close as possible to the ugly die cast part. Was quite a process cutting and fitting all the small delicate parts together. I'm quite happy with the result Last pictures show the testwise mounted platform not attached yet. Another comment to artesania latina's die cast parts: they are ****! The top plattforms die cast parts not even showing the holes you need for attaching the upper shrouds. If you would forget to drill them as the instructions do not say anything about it, you would be fucked up having to deal with it if already mounted on the mast... As well as drilling holes in such die cast parts of a complexity of that top plattform is not the wood modeler's main ability nor will it end up very precise...
  11. The included die cast jollyboat in the kit was not really nice and also way too big for the deck I think. So i made an own one from a separate kit with upgrading it:
  12. Hi Barr1. Sorry just saw your message, so answer a bit late... Cool, nice to hear that pictures can be useful 🙂 I guess that casted bow grating in the kit looks quite ugly? The lines on the deck (joint of the planks) are made by slightly engraving the planks with a saw and blackening the groove with a pencil. The "nail holes" are made by hammering a not too pointy pencil into the planks. Both done before gluing the plank stripes onto the deck. Which part do you exactly mean with "bow sprit stanchion". And from what view? My mother language is German. So it is quite difficult and tricky for me to get all the names of the ship's parts in English. Crazy anyway how many technical terms there are in the world of old ships... X-)
  13. Sorry guys took a long time to finally display the result. Thank you very much for the hints. Tried to do it with the truckers hitch but it was too small to succeed. So I just did some improvisation with square knots and seizings:
