Troy Chaffee
Posts posted by Troy Chaffee
- etubino and GrandpaPhil
- 2
This is a “patch” I added to one of the cross beams that was short. I’m not sure if I did it correctly or how others would have, but this was my work-around: I cut a section from the un-used plywood provided in the original box. I hand carved (and at one point...thumb carved 🙄🤭...what’s a little blood in a tall ship?!) a piece to match the curvature of the cross beam. I glued it in and after letting it set I sanded it down. I didn’t want to use the provided “plank” material because I’m not sure how much I have vs. how much I need. (Another issue with the instructions).
Interrogative: Is there an easier way? Did I make this way harder then I needed?
- Fernando E and Edwardkenway
- 2
Thanks Fernando! I actually read everything you posted on this model before I started. You gave me some much needed direction.
I double checked my numbers as well, just to make sure I had not made a mistake. It’s just to big. The adjacent cross beams are ok. I have one that is going to need an add but it’s further down the line.
So just a few issues I’ve found within the model and plans themselves.
1). Some of the instructions in the book are incomplete. On sheet #5 a sentence starts “Also ensure...” but there is no continuation...anywhere. “Also ensure..” seems like an important start to something. Guess I’ll figure it out at some point.
2). One of the cross beams is a bit to large and will take some modifications to make it work. It’s the same cross beam on both sides of the false deck.
- ccoyle, Chook and GrandpaPhil
- 3
Keel layed in with minimal issues. Some sanding to make the frames fit in the keel but nothing drastic. Only had A few issues with the #5 not wanting to line up at 90 degrees but I was able to correct it with some binder clips. Started fairing the hull last night. That’s been the most daunting part so far but I’m taking it slow and step by step.
- GrandpaPhil and Moab
- 2
- Edwardkenway, Chook, GrandpaPhil and 1 other
- 4
- mtaylor, GrandpaPhil, ccoyle and 3 others
- 6
Perseverance 1807 by Troy Chaffee - Modeller’s Shipyard - Scale 1:48 - Colonial Brig
Planking has been an issue with me...it’s my first ship and I’m learning. Thanks to advice from the shipmates and some deeply buried articles on this site I’ve decided to get rid of the “planking tool” and create an easy jig. I pulled all the planks and started again... my OCD stepped up and wouldn’t let me proceed😂
