Unegawahya
Everything posted by Unegawahya
  1. You are half correct! The second carronade from the stern on “port” and starboard!Sorry Mtbediz!
  2. I’ve been going through google to do the 3D tour because it has all 4 decks. I’ve also been basing my build of of the 2015 3D tour. https://maps.app.goo.gl/Q3qWEqXeBnqpqrf87 I'm hoping the link will still work! If it doesn’t I’ll send it again from my PC. I messaged the link to myself so I wouldn’t loose it again!
  3. I’ve gotten a little more progress on my 36” Pinnace today! I jut need to make the cleats and the rudder. I also need to decide if I’m going to have the ores or if I’m going to leave them off.
  4. I forgot that the kit came with the eyebolts. I’ve been making mine with a set of jewelry pliers. It’s time consuming and I can understand why a lot of people just order them. I also had to modify my pliers to make the size I needed! I also agreed with Mtbediz, dropping the second set of tackles and doing the recoil is worth it. The second set of tackles are a little hard to get the correct size and distance. They’re also a little difficult to rig at the small size.
  5. I’m finally getting some time to work on my Constitution again! I apologize for my absence but now that the two commissions and the plane I started in October are done I’m hoping to have at least a little more time to build! I’ve gotten a lot closer to completing my 36’ Pinnace and I’m mostly finishing up the details!
  6. Yes the tiller ropes go directly through the commodore’s pantry and come out and run back through the top of the wardroom.
  7. Great job on your canopy frame! I love the way you overcame the problem of drilling the holes in the center! Keep up the great work!
  8. Your canopy frames are looking great! I ended up leaving the two companion ways at the front of the main hatch way covered because I really didn’t feel like cutting them open and trying to replicate the frames smaller. But, I’m sure I’ll either change my mind or wish I opened them up later.
  9. When I did mine, I had only drilled 4 holes in my hubs. The string is there so when I eventually dropped the top down the common way I wouldn’t loose it. I would get the first opposing corners in first then each of the next two. The side frames were just glued to the side of the hub. Looking at your build, I wish I would have done my canopy frames before the common way was installed! That would have made putting them together so much easier!
  10. If it helps, here are some more pictures to show the canopy frames from more of a distance.For me thinking about the canopy frames was harder than actually doing them. The second two were definitely a lot easier than the first one because I was able to get a method and I built them together. I also wish I would have built mine like Jon! It would been much easier before I installed the hatch ways. I found the post showing the 3D printed ones if your wanting to go that route. He may be able to print another set.
  11. Your companion way canopy frames are looking great! Seeing your pictures is making me miss working on my ship! I had two commissions come in that I needed to work on and I have one done and the other is 60%. I’ll hopefully be back to her soon and can get my 36’ long boat done and installed!
  12. I wish I would have seen your jig way back when I did my gun deck! I had to figure it out on my own. They look great!
  13. Your carriage looks great! I don’t think the peace under the carriage would be that much of a loss because like you said “it’s not very visible.” are you going to build all wedge type carriages or are you going to add in the two screw types that are there.
  14. I was thinly slicing oranges. I had a flap of skin hanging off the end of my thumb. I had just sharpened the knife too!
  15. I got a little more work done on my 36’ Pinnace this weekend! It doesn’t help that I almost cut off the tip on my thumb yesterday.
  16. Ok here are my three files for the boats. I hope they work as well for you!36'%20Pinnace.pdf28'%20GIg%20Whaleboat.pdf28'%20Whaleboat.pdf
  17. It’s not just you placing the skylight window bars was very difficult! I decided to scratch build my boat hulls because I’m not a huge fan of the bread and butter method. I put together and sanded the hull for one of the whaleboats and I wasn’t happy with it. I made the mold from the line drawing you sent me. I used photo shop to separate all of the frame lines. I then glued the printouts to 3/32” basswood. All of the frame templates where cut out with my table mounted jigsaw, sanded and placed over their top down frame lines.I have the files to build the molds for the Pinnace, whale-boats, and gig if anyone wants them!
  18. I know you had a lot of fun decorating your boats! I went back on your blog and saved all your pictures for references. They all looked really great! Thank you for your help.
  19. Well that was a lot easier than I was thinking it would be! I’m now looking forward to when I get to do the other three boats! I have the mane hull and planking for my 36’ pinnace done. I ended up remounting it to the mold and finishing all the planking with the hull on the mold for support. Its now time for the details!
  20. Wow! Your star looks so much better than the one I tried for the stern on my Connie! I found the link for the ribbon stars! https://www.vanguardmil.com/collections/ribbons-medals-attachments If I remember correctly they’re just a little too big to be used on the bow. There is also a small star on the front of the billethead.
  21. I do agree! The stars are a complete pain to make! I cheated on my stern stars and bought uniform ribbon starts.
  22. Using the plexiglass for the spar deck sounds like I great way to show off all the work you put into your wonderful gun deck! My question is, would you cut it into planks and plank it like a normal deck just clear. Or would you try to make it in just one peace. I was also thinking of the admiralty models where they leave sections of the deck with no fittings open. You could use the plexiglass there instead of leaving it open and that may reduce some of the dust falling into the gun deck. It would also give a good surface for the fittings and guns to rest on.
  23. lol No it’s the full hill from the gunnels to the bottom for shaping and setting the ribs.
