Unegawahya
Members-
Everything posted by Unegawahya
On my wheel I had a hard time drilling out the two wheel hubs for the wheels, I had just decided to to make them completely separate. In the end this turned out to maybe not be such a good idea because now I had to make everything close to square and I used a toothpick as a center shaft to keep everything together. The toothpick allowed me to glue the ends of the wheel to keep everything together. I was worried about that because I wanted everything to accept stain somewhat evenly. To that end all of my spindles and hubs have a small interference fit. The only part of the wheels that are glued are the rims and the small spots on the very ends that will be covered by the stands. Once I stain the wheel I was thinking of using a test peace of wood and drilling all the small wholes and inserting small brass wires. If this doesn’t work on the test peace I may just try to paint them on. I referenced all of my sizes and shapes from the Model Shipways plans and unfortunately I still can’t find the wheel in the instructions accept for a picture on page 33 of the actual wheel. I also referenced the Navy plans. Unfortunately, after looking I have been unable to find Bobs Practicum.
Thank you! I really appreciate your kind words! This is technically my third all wood kit but I’ve been building plastic models and stick and tissue planes for about 28 years! I made three attempts to make my wheels. The first two I used too thick wood and I could not get the tight bend. I finally decided to use use 1/32 mx1/16” basswood. From here I boiled one stick that was about 24” for about 15-20 minutes. Then I curled the wood around a small spray can. Once the wood dried for about 6 hours I boiled it again. After I boiled the second time I taped about an inch of the wood to the socket and the rolled to wood to the socket on the counter. Doing this I still had one split in the wood, but it gave me enough material to have a little extra leftover. After I got it secured to my socket I let it dry completely overnight. To form the wheel I layered two more layers on the first. Each layer was offset by one third of the wheel. To make the holes for the spokes I used the cast wheel from the kit to get a good even positioning around the wheel. The I used a needle awl to make a small pilot hole and started with a three sizes smaller drill bit. Each time I drilled the holes I checked for center and took my time. I went up each size to make sure that I didn’t get to close to the sides. The spindles I had to use my fingers and different files to lethe them. Making the spindles has so far taken the longest of everything.
The way I drilled the holes as close to the center is, I made all my marks first. Then I uses a needle awl to make a pilot hole to start. Then I started with three sizes smaller than I needed the hole. Once the first holes were done I went up in each size drill bit. Each time I drilled the holes I also made shire that the drill wasn’t walking to one side or the other. to make all the spindles I made a master spindle to model all of the next ones off. Unfortunately I don’t have a actual lathe so I had to use my fingers to turn the spindles using different files to shape.
Since my last update, I’ve managed to get my spar deck capstan done and installed. All of the laser cut peace’s from the kit made making it a quick and easy job. The only thin that was interesting was removing the laser burn from the wood parts. I also did a little experiment in bending wood to make a new ships wheel. In the end after some trial and error I was able to curl my 1/8x1/32” basswood around a 3/4” socket to get close to the diameter for a wood ships wheel. So far I’m happier with the results than I originally thought I would be. Hopefully I’ll be able to get some work done more on my wheels Monday when I’m back at home.
The two port and starboard aft most guns, in the Commodores Cabin are probably omitted because with the guns it a tight space and during battle the bulkheads are usually removed. With this tight of a space and including the chairs, table, and side board, a lot of it will be lost to sight when the ship is complete. I added mine from the plans from the US Navy. I did enjoy adding them, but rigging those gun as a chore! I also opted for more of a simple table and chairs.
Hi Peter, I actually have not polyurethaned much accept for my decks after staining. I actually like the way the acrylic paint brings out some of the details in the wood when painted. Also, when I find somewhere that I’ve painted and forgot to add something first I almost always prep the area. This usually means removing the paint or scoring the area. by build also looks different from other builds because I’ve done a lot of customization to my kit. This includes adding the full gun deck, cabins, and lowering the main rails. I’m doing my best to make my Constitution look as she did in 2015 when the 3D tour was made.
I was worried about making the 15 stanchions that I needed for the fife rails. In the end, they were not bad at all. All 15 are done now and I’ve fixed the location of the mizzenmast fife rails and patches the deck planks as best as possible. Once the stain on the patches is dry I need to add a little more in spots and then seal the patches.
I e finally gotten all of my bulwark details completed on my USS Constitution. Now it’s time to start the Fife Rails. The biggest thing that I’m starting to not enjoy, is removing the burned sides on the laser cut parts. Some times it seems almost easier to make them from scratch if your going to stain them!
Finally after all of my breaks and getting sidetracked, I’ve gotten all of my spar deck guns completed and detailed. I also dry fitted them in place to see how they look. After getting my guns completed I started working on the rest of my bulwark details that I’ve been neglecting. The cat heads as mentioned before ended up being harder than if I would have gotten them done earlier. But, in the end I was very pleased with the way they turned out.
Once I had my spar deck bulwarks done and painted I got my pin rails finished and stained. Then I took a long break again and built the Dumas Albatros D-V. I modified her to look like the one hanging in the Smithsonian. Which included sheathing the fuselage in 1/32” balsa and adding in the control surfaces. The next project for my Constitution was the channels and to finish all of the hull painting including the stern. After a break to draft and build my FokkerD-VI I got my carronades started just to take a break and draft and build a Fokker D-II. The carronades were interesting because the Britannia Mettal barrels that came with the kit were not shaped very well but were at least the correct size. The 3D printed ones I ordered had the wrong carriages and the barrels would only work for 2 of the 20 carronades that the Constitution has. So, I made a jig to hold the barrels so I could drill holes to add trunnions to the 3D printed ones that I had ordered.
Next up was the inside of the spar deck bulwarks and here is where I messed up a little. I should have installed the cat heads before doing the bulwarks but I didn’t. It just meant more work for me to do later and some patching. After the bulwarks where finished I felt it was time to finally finish the head and that was actually very satisfying! I also went through the time consuming task of installing the rivets into the bulwarks to add texture and realism. In the end I’m ultimately glad I did because I love the look. Wile I was working on the rivets, it was also finally time to renovate Luna’s bedroom. She got a bay window and a even a custom Dutch door.
Once I had the Explorer fixed I was able to get the rest of the framing for the spar deck done and one of the last things was the captains ski light. About halfway through laying the planks for the spar deck we went on vacation to San Diego Ca. One of Luna’s favorite places we visited was the San Diego Maritime Museum. After we got back I was finally able to finish the spar deck and my 79 F250 finally got its air conditioning reinstalled!
Once my main guns were done it was finally time to start on my cabin and last gun deck details. I love my little assistant! She was so cut at that time! Every time my desk was open she wanted to sit there and play with what ever she could get her haves on. One my final gun deck details where done it was finally time to start on my framing for the spar deck and hatches! Before I was able to complete the framing, our Explorer had a massive water leak that came down the back of the engine!🤦♂️ luckily it was the intake seal and we didn’t get any coolant in the oil!
After a short break to build a dollhouse for my wife’s cousin I started finally installing and rigging my 30 main guns. I also included pictures of the method that I used to make all of my rope coils. To make my rope coils, I acquired four metal “do it yourself” round makeup trays from my wife. Then I drilled center holes in each one. To make the coils I soaked my rope in 50/50 Elmer’s glue/water. Then I threaded the rope through one hole and pinned it in place with a small nail. Then the second half would go on to make a snug fit and to make sure the coil wouldn’t over lap. After winding I would hold the assembly over a candle flame briefly to dry the rope. I would let that one cool wile I started the second one. most of the time the coils came out great and after a little trimming I loved them!
I apologize for my long absence! I’ve since gotten a lot of work on my Construction done and I’m going to try to get everything updated here soon. These are my pictures of when I got the port side painted and started making my blocks for my main guns. I had an inspiration of insanity here and custom made all 180 blocks myself. It took forever!
