Unegawahya
Members-
Everything posted by Unegawahya
I’m taking a lot more pictures for the other two companion ways and I’m hoping to make a better post showing all of my progresses. tonight I will hopefully have time to get back to work! I also don’t have a lathe. I used the good old finger lathe to make the finial. All the parts that I used are all brass stock that I got from TrueValue. I did use my 8” drill press with my needle files this time to make the finials.
It’s really nice to be back working on my Constitution! I’ve gotten all the spar deck guns mounted and the recoils are done I’ve gotten one of the carronades rigged with one set of tackles each side.I’ve decided to tie off the ropes to the tackle like the USS Constitution seems to keep them. Or at least that’s the way it looks on the 2015 360 virtual tour.
I apologize for the delay! The glass I used was .005 Clear-lay film from Grafix. 4649400a.pdf I scaled the US Navy plans to the Constitution as best as possible. Once I had the open frames I used a pin to trace the openings onto the film. Once I had the window openings I used Testors canopy glue to assemble the windows and mullions. Onec everything was in place I used as little CA glue as possible on the window joints. Just be really careful because the CA glue can cause the film to fog up! Once everything was good and dry I was able to carefully curve each window with a lot of irritation to fit the quarter galleries frames. If I remember, I used a curved surface and a lot of pressure from my thumbs.
It’s beautiful! I’ve been doing a lot of 100%scratch building myself! since I’ve been on my break I built, my version one of my SE5a my second version of my Fokker D-VI A half sized Guillows 18” Sopwith Camel at 9” from the plans a Guillows TBF Avenger as one of George Bush’s plans from WWII my Sopwith Pup my version two of my SE5a a Comet F4U Corsair scaled to 10” from the 20” plans. my Nieuport 11 and I’m almost done with my Mooney M20 Ranger
Thank you so much for all the help! I thought I was going crazy. I looked every where for these. I'm starting to think that they where removed for some reason, because the museum didn't have them and I didn't get them with the download the I got from the Navy Museum. After I get the 28' Whaleboat done I'm going to get started making a Jig file for this one too! 28' GIg Whaleboat.pdf
To start thins off, after sleeping on it I was not a fan of the way the barrel of my wheel looked for my USS Constitution. So today I backtracked and rebuilt the barrel today. I started with a 1/8” dowel and used 1/16” sticks to cover the dowel. (This took me two try’s) Luckily my new barrel turned out to be exactly 20mm in circumference which made it easy to mark the 10 holes. I used modeling tape with the marking to line up and poked small pilot holes to use my hand drill on. I got the stands finished tonight and now I just need to stain everything.
