Bill97
Everything posted by Bill97
  1. Thanks again Robert. Again looking at your Man O War it is obvious that large portions would have to be hand painted. Impossible to airbrush unless you did a crazy amount of masking and unmasking. I really appreciate your thoughts and advice. It is fascinating reading the building blogs of different highly talented builders and seeing how each feel very strongly about their preferred way of doing things. As I am honing my skills my mind is fully open to all techniques and methods. I will be making my own sails for my Cutty Sark. This will be my first attempt. I like your cloth sails and I like Ron’s (Great Republic) paper sails. Going to experiment with both methods to see which, if either, I can pull off convincingly.
  2. Absolutely beautiful work on the painting. I was wondering how you got the billow n the sails. Modeling wire is the secret. Great idea.
  3. Robert I just keep looking back at your build log. I am so impressed with your work. It is making me want to get to my Man O War build. I still have a ways to go on my Cutty Sark and need to be patient. I have so many questions and I hope you won’t mind me asking. If you do, please say. In the first part of the log you show all the hand made cloth sails. Are those the same ones you show later on the ship? Also was the ship painting a combination of airbrush and hand painting? I saw you holding a brush in one photo and I expect some areas are so detailed it has to be hand painted. Other areas look so smooth and even it looks like airbrush.
  4. Lou that looks incredible! Are you building it from wood? It looks way to sharp and clean to be a plastic model, or my skills are needing some work. One thing I noticed on your Cutty Sark, and have noticed in photos of other builder’s ships, that I am curious about. It looks as if you used a tan thread to make a the lower deadeyes. I like the looks of that and wanted to paint the molded rope in the plastic deadeyes on my Cutty Sark a rope tan color. Everything I read says the standing rigging was all black. Is it just a preference thing and OK to do it that color?
  5. Thanks Robert. I will go with the more or less. At least once it is completed and I display it on a shelf I don’t have to tell people it is just a pretend ship like something from Disney. Even though there was not an actual British Man O War the ship’s design and structure replicates a Spanish gallion. I can live with that.
  6. Good morning Robert. I just received this Ravell kit as a very pleasant surprise. Will be starting it in the Fall. Currently working on the Revell 1/96 Cutty Sark. I guarantee I will be referring to your build log as I tackle the project. Excellent job! I am curious about your sails. What technique did you use? Are they cloth or paper? Very realistic. Paint color scheme is fantastic as well.
  7. Thanks Backer. Really appreciate it. I looked all over the site and even used the search button. This will be helpful.
  8. Has anyone on this site built the Ravell 1/96 British Man O War? I recently received the model kit as a surprise gift. It is unopened and setting on a shelf right now as I continue working on my Cutty Sark. I searched this site for any build logs for the Man O War but have had no luck. My ship research indicates it/was not an actual historic ship, but more a artist’s rendering of a Spanish gallion? Don’t know if this is true or not. Would love to find someone’s build log if there is one.
  9. Began working on the ratline assemblies today. Since Ravell has these as molded replicas of the actual ratlines it was not necessary to rig the actual blocks and eyes. I have seen a number of builders on this site create them with excellent results but since I have yet to attempt that I stuck with the molded pieces.
  10. Assembled the masts and yards today. Since I will be adding sails (Rob’s paper technique I hope) I set the yards at 25 degrees. Always a bit of a challenge to get all the yards level. Getting them set at the consistent degree is not to tough using a protractor but getting them all level requires me using clamps, tape, and or string. I ultimately go with “eyeballing” to get them as close as possible. The connection points on the yards are not substantial and in fact seem as if they will be fragile. Will see after the glue drys. I know it is not authentic but I painted the molded connection points for attaching the yards to the mast metal gray. I like the visual interest it adds.
  11. Spent some time preparing all 16 yards for painting today. The Ravell 1/96 Cutty Sark is in pretty good shape out of the box, but still some areas need to be cleaned up of stray plastic left by the molds. Since I am airbrushing the mast components I sprayed a surface primer on all the yards and will let them dry overnight before spraying them black tomorrow. I thought it wise to leave the plastic scrap piece on the end of each that has the molded piece number. Would have been crazy trying to find which goes where after painting if they were to get accidentally mixed together.
  12. Began the mast construction over the last few days. Worked with several color and pattern ideas before deciding on the one I used. Took some ideas from other CS builders on this blog and went with a color combination that matched the deck houses. This is probably not authentic in actual color scheme but I think it makes for an attractive display. Anxious to get the yards on to see the full effect. Mast are currently just setting in place and will come out to attach the sails. Curious about the studding sail booms. Not sure if i should add them or not?
  13. Rob another question I have, I feel like Luke Skywaker asking the Jedi Master Obi Wan Kenobi, is that it seems you leave the Studding Sail Booms off the yards. Just hang sails on the yards not the extensions. Is that correct? And if so, is that a preference you have arrived at for specific reasons? I included them on my recent USS Constitution but left the sails off. On my current Cutty Sark I am going to attempt your paper sail technique, but am curious about the studding sail booms. Have not added them to my yards yet.
  14. Thanks Rob. As I hone my skills I try to pick up hints and techniques from you guys I consider masters of the craft. I am beginning the mast construction for my Cutty Sark and was going to wait to include the yards at this time if that is what you recommended. Based on your reply, and that I hope to make paper sails following your method, I will go ahead and attach the yards in the up position and at about 20 degrees. Bill
  15. Thanks Popeye. You have been extremely kind and helpful. Appreciate your information and advice.
  16. Thanks popeye. Very interesting. Looking at the davits I did not consider having the life boat pass through them one end first then the other. I was trying to figure out how it could be done with life boat parallel to ship. Whoever designed it that was genius. So for the chain on the rudder it is OK to just attach the ends of the chain to the eye bolts on each side or should I run them inboard somewhere and attach them to something?
  17. Hey Rob I noticed in some of your post photos, and photos from other builders, that it seems as if you do not attach the yard to the mast until after you attach the sail to it? Is that correct? The instructions show attaching the yard to the mast during assembly. If I am correct in what I think your photos show, do you find that better, and I guess possible?
  18. Thank you popeye2sea! Now it makes sense. Thank you as well John. This site continues to be a wealth of knowledge and help to model ship builders with limited knowledge like myself! I am even learning nautical terminology! Had no idea the lines used to lower the lifeboat were called Falls. So Popeye2sea, if I understand you correctly the Falls are simply rigged either up and down or crisscrossed on the davits for safe keeping (lack of a better word) until needed to lower life boats. They are not actually attached to the lifeboats at this point, but to the other cleat on the davit? And John you are saying the same thing only having the falls attached to the life boats as if about to be lowered or returning to the skids? Looking at the design of the davits, I am curious just how they worked? Did they pivot in some way allowing the life boats to be extended out over the side of the ship? Just trying to picture how they would have worked. With the falls attached to the life boats it seems that no matter how the davits were rotated the lifeboat would hit one or the other and not be able to extend over the side. Since you were so very helpful I wonder if I may trouble you with one other question? On the back of the ship the instructions show attaching an eyebolt to the top of the rudder and two additional eye bolts on each side. Then either rigging rope or chain (I have seen in some of my research) from the side eye bolts to the rudder eyebolt. When I have done this it really looks odd and does not appear as if it would have accomplished anything in reality. What am I to do here? Instructions are limited at best.
  19. Looking for help from anyone familiar with building the Cutty Sark. I am building the Revell 1/96 but I think any build would provide an answer to my question. Read everything I can find on MSW but at a loss. I am trying to rig the two lifeboats to the divots. Revell instructions show vertical lines. Other instructions and actual photos show an X pattern. But nothing explains what to actually do. Anyone have an idea?
  20. Back at it a little today. Had to step away a few days because of busy schedule. Nice way to relax and spend part of Independence Day. Working today on life boats and davits. Weathered the davits, life boats and top of deck house with some black and white wash. Instructions simply had the 3 pair of oars glued in. I added tan thread as tie downs for a little more realism. Instructions showed rope (tan thread) attached at ends of life boats and then running to davits. However there was no place on the life boat ends to connect a pulley so I fabricated a set up using left over parts from previous builds.
  21. Continued some work on both ends of the ship today. On the back end I added the black rope rail around the top of the deck house. On the bow I added anchor supports, rail poles with rope to be added later, and the red and green lights on the side. I have continued to refer to the older assembly instructions provided by Arctic37. So much better than what Ravell now includes with the kit. Had an oh *^#% moment today. As some know Ravell now includes decals for the name and decorative scroll work on the bow. I definitely don’t like it as much as the molded form on other ships like the Constitution. On the Constitution I carefully painted the raised design and name with a fine point brush. On the Cutty Sark it is just a peel and stick decal that looks like a peel and stick decal. Since that is what was provided That is what I applied. Well, somehow today moving the ship around and leaning it over to touch up paint I accidentally damaged the decal. So I just sanded it off and will either try to hand paint something in that area or just leave it black. I know I can find new decals on eBay but don’t know if I really want to put decals back on it.
  22. Continued today with mainly touch up and fine tuning my painting. Also added the wheel house. I found Artic37’s Cutty Sark build. He included the building instructions from an older production that are much more detailed and informative. In the instructions with my kit it said to paint the 8 bucket shaped objects back by the aft deckhouse brown and place them under the quarterdeck rail. Gave no name to these pieces. In the Instructions Artic37 provided they are called fire buckets and instructions say to paint red. That made more sense to me so I changed them. Also weathered the top of the two deck houses. Developing into a beautiful ship.
  23. Just a bit more at the stern of the ship today. Also did some fine tuning of some of my paint lines to get sharper edges. Once all the deck elements are on, probably some time this week, I plan to do a little additional touch up. Have some glue spots that are showing up a bit shiny I want to touch with some matt top coat and a few little white spots on the deck where the weathering effect needs to be touched up.
  24. Continued to work from the bow back toward the stern adding deck elements. Some of which I must admit don’t know the name of. One of the things I really liked when I built the Revell USS Constitution is that the instruction book had several pages that listed all the parts by number and name. The Cutty Sark instructions did not have that. Something I am curious about and someone may know. On the deck house in the back there are two elements that look like upside down baskets near the front. No idea what they are. The instructions had me put the compass on the back end of the house. In videos I have watched the compass is in the front where these little baskets are. One other thing I have noticed that I have to work on is my sharp edge painting. When I look with my naked eye I think my edges look pretty good. But when I take a picture and zoom in I can see a bit of fine tuning is needed. I added some weathering to the sides of the deck houses as well.
