Everything posted by xodar461
Greetings! Constructions resumes after a 2-week trip to Japan. After the Clam and Oyster Co building is complete, the basic wharf deck it sits on is constructed. The wharf is a single piece that is laser cut to simulate planks. two different sized planks are used to trim the edges (wire brushed and stained first). A template is provided to locate the center lines of the future pilings and the wharf braces. once the braces are glued, the underside is painted green and the topside is weathered. Instructions called for Floquil concrete - i used a variety of chalks and some AI. Here is a photo of the Clam and Oyster Co on the dock. Next is the diorama base. As I am combining 2 kits this will be left for later as I plan to complete all the buildings and other structures first. So onto the Foss Launch Co. First up is some advance prep such as was described with the previous building. No need to repeat that. The siding on this building is vertical vs horizontal as on the Oyster Co. These were detailed in a similar fashion. One interesting note is that no internal bracing was described for these walls so I decided to make some with leftover strip wood from prior ship models. These must be carefully placed so the wall will go together seamlessly when the trim is added to the edges of several of the walls. Here is the final result of the bracing: The walls are then weathered and I added some random knots. Again, rather than using paint, I used a variety of chalks and AI followed by a very light amount of white to simulate old white paint mostly weathered away to get to this: Some trim can be seen lining the freight doors. After the walls are trimmed, the signing is done more dry rub decals. I was worried about this given the age of the decals and difficulty with some of them on the Oyster Co. After doing some research, I decided to give Elmer’s spray adhesive a try as I was not entirely satisfied with the double-sided tape described earlier. I think with larger signs the tape would be quite visible. I first tried this on a small "posted Keep Out" decal. These small decals from the Oyster Co building did not work with a variety of methods I tried earlier and there are plenty more of these small decals. Here is the result: Pretty good so far. Time to try it on a bigger sign: The "Foss Launch Co" and the "Tugs & Barges" sign. Each required several pieces of strip wood to be glued together then some stippled white. The area where the spray adhesive was to be applied was taped off. A light coat of the adhesive is all that is needed. The decal was then burnished onto the wood and ... A slight amount of yellowing on the Launch Co sign, I believe, is from the decal paper. I was able to tone it down with a light brushing and some chalk. So how does this method work if the signs are placed directly on the building? The "fast boats for hire" sign goes to the left of the freight door. the entire wall was taped off except for the amount needed for the sign. And the result: Wish I had this figured out before I ruined the Coke and Pepsi signs (sigh). One other sign goes on this wall, placed onto several boards glued together. Here is the completed left wall of the Launch Co: Two more decal are placed directly on the walls. These can be seen on the photos below. The windows have also been placed. Construction is similar to the Oyster Co building. Some holes and cracks were placed and the windows dirtied up a bit. Next up were the doors - one regular door and six freight doors. The regular door has 2 pieces that come on the same sheet as the window. After prep, they are stuck together. I drilled a small hole and used a tiny nail to simulate a doorknob. It’s still a bit bright so I need to weather it a bit. The freight doors had a base tan color and then finished with a variety of chalks - raw umber, grey, black, brown, rust. Curiously, all the right doors were missing the lower hinge. This was easily rectified with a small bit of wire. The doors were glued in place with 2 life preservers and the walls were then glued together, squaring them up as described before. Although not called for in the instructions, I decided to add some blinds to the windows. Rather than black I decided to go with a lighter color - the end result was a slightly dirty, streaky tan. Here are all 4 sides of the Foss launch Co. One issue is the subtle shading on the white Boat-House sign that is a remnant of the spray adhesive. More noticeable in the photos than real life. I am not quite sure how to tone that down without causing damage to the sign or even it it needs it. I think it turned out OK. Any comments / suggestions are, as always, appreciated. Next up, the roof. Jeff
Onto the roof. The simulated tiles / shingles were painted earlier and now are repainted with black and grey to produce a variety of shades. Here is one example: Next, the edges of the template and some of the bottom was painted green. The individual rows of shingles are cut from the sheet and applied to the thick cardboard template. Lines are drawn on the template to keep the rows lines up. Here are a few rows already glued... And here is one roof complete except for the cap shingles: The hole is for the chimney. Rather than just glue the chimney to the angled rood, I drilled a 1 mm hole in the chimney (metal was fairly soft) and stuck a 1 mm brass wire in it. on the opposite site of the roof, I glued a small 1.5 mm plank to give more purchase for the brass wire... The capping shingles are made from the unused perimeter of the shingle sheet. Instructions said to use one large sheet but I cut them down to size and applied them in an overlapping fashion. Here are a few pics of the 2 finished roofs. Also added are the stove pipe coming out of the window and the chimney. The chimney was first painted with VMA aged white ( 71.132)and then dry brushed in several layers to paint the bricks using VMA 71.105 (this is listed as brown but look more like brick red) . Support wires were added to both. Some soot was added around the chimney and streaks added to roof. The "tar" around the base of the chimney is glue mixed with some VMA black green (71.021) and black. I also used some aged white to add some bird dropping to the roof. hard to see in the photos however. After hanging the 4 freight doors this structure will be done. Jeff
Greetings! Thanks for all the kind comments. Once the windows and walls are complete it's time for some window treatments - shades and curtains. Shades are simply black paper glued to the inside of the window. One window has curtains with part of it hanging out the open window. Much of this is unseen (though will stand out better if i decide to add some light to the structures). Next, the second story door and first floor wharf door are added. The previously prepared clam and oyster sign is glued and finally the walls are glued together. Much of this can be seen in some of the following photos. A simple L square was used to keep things squared up. The left wall awning over the freight doors is now installed. This was painted earlier. Instructions called for some testors Dull Coat and then bush with some rubbing alcohol to fade it. However, I did not want to buy any more supplies at this time so I decided to try what i had on hand - matte finish polyurethane. I then painted some alcohol on it after the polyurethane had dried and this was the result... Before: After: I think it is acceptable. The awning is made by cutting strips and gluing them onto a thick template with some overhang on all sides. I left a bit more on the back side as this would be against the structure. The awning was weathered with a variety of chalks (grey, black, white, rust) then glued at an angle against the building. Two wires are added to simulate support. I mixed some black grey paint with glue and put it around the areas the wire contacts the building and awning to simulated caulk or tar that might be found at the ends and some black chalk to stain the canvas below the points of attachment. Before starting on the stairway and landing to second floor, I added some supports to in inside tall wall that will give more support to the roof when attached (red arrow). The other red arrows at the corners of the first floor of the building demonstrate where I added wood the side walls so that they would have more surface for glue when attaching them to the front and middle wall. Now for the landing and stairway. Construction was straightforward. All the wood used was to be treated with white paint to simulate peeling however I left the landing floor and steps in the natural faded wood condition. I figured one would not paint the steps and landing as they may end up slick. Templates are provided to make the construction pretty full proof. Here is the landing: However, one caveat: The landing has 2 supports. A template gives the dimensions and angles to cut however the if you follow the template, the supports, which should attach to the building just above the window, will end up a good distance below. See next photo: In this photo, A should equal B but B was at ~3.5 mm longer. I was an easy fix and here is the final staircase and landing. I added some nail holes and rust to the landing boards but not the steps. That whole structure is much too delicate and I did not want to mess things up for a relatively minor addition. I also used some black / grey chalk on the stairs and landing to simulate dirt where steps would be taken. Next up is the roof jeff
Greetings! Work continues on the Oyster Co. After the windows come the doors. 4 are cast and one is constructed in layers like the windows. The 4 freight doors were done in layers with the white applied to he wood painted a variety of shades with a hint of red as this was the original color before weathering. Similar process for the wooden door. rust added at hinges and doorknobs. Next several of the walls were trimmed, again using stippled white to simulate peeling paint. The bill of goods dry rub decal was placed at this stage. I did not know what to expect given the age of the decal however it turned out OK except for some missing letters at the top. Turns out dry rub decals don't last for years, a problem that became more pronounced for some of the smaller decals. The bill of good sign was then covered with a light coat of satin polyurethane to keep the letters in place (hopefully) and then dulled down a bit with grey chalk. Photo below shows the lettering before the grey chalk was added. Tthe walls are completed by adding the windows with the lower panes and some signs to the back wall. One of the signs was a red coke button that required a Coca Cola decal. Needless to say this did not work as the dry rub decal did not separate from the paper. I tried a few methods after doing some research but nothing seemed to work. So for the coke button, I found a similar sign on the internet and shrunk it to size and glued it over the button. Here is the result... I think it looks passable. Next a few more signs were placed. The sign are on a paper sheet. The sheet was scuffed up a bit with fine sandpaper, cut out, glued and weathered with some chalk. Here are some photos. Note the installed windows: some propped open with a small wood board, others with wooden slats to cover holes and another with several boards through which a stovepipe will be placed. The boards were completed with some rusty nail holes at their ends. The clapboard below several of the sign were weathered to simulate paint and rust running down the wall. And finally I think I may have found a way to use the old dry rub deals. Double sided Scotch tape was placed on a wood board and a single decal was cut out and stuck to the tape. When the decal paper was removed, the tape was then trimmed with #11 blade very close to the decal. I ended up with this... Although the tape is slightly visible in the photo, this is highly magnified and it is pretty much invisible and regular scale. I think this may allow me to salvage the rest of the decals in this kit although some have been ruined in my attempts to find a workable solution. I'll post a few pics with some decals applied this way with less magnification to give you a better idea of what they look like at scale jeff
Greetings, Work continues on the Oyster Co. Once the detailing on the walls is complete, they are braced with 1/8" sq wood to prevent warping when painting. Unlike the shipyard, there seems to more painting with this kit. I will probably use chalk to do some of the weathering rather that the paints. Floquil grime is called for the base layer on the walls - I used Vallejo antique white. I noticed that the wood is quite porous so I had to be very light with the brush. before I put on the next layer and after the paint had cured for 48 hours, I used a light coat of satin polyurethane to act as a sealer (here is the ship modeler rearing its head). The next layer is Boxcar Red (50/50 mix of Vallejo {VMA} 71.038, 71.105). once dry, a light sanding with very fine sandpaper was called for followed by wall streaking with more paints. This last part I will leave until the roof and windows are on to get a better idea of where I want the streaks to be (and I may use chalks). Here are the walls to this point... It's kind of hard to see some of the details (I even added in a few random knots) given the low resolution. After the walls were painted I grunged them up a bit with some grey chalk. I may use some black at the bottom when the structure is complete to represent more dirt and grime. And finally, while waiting for the walls to dry, work was begun on the windows and the clam and oyster sign. Each window has multiple parts including the inside frame, outside frame, lower sash, and mylar windows. These can be seen in one of the earlier photos. first, they were treated with white paint to simulate peeling. I tried the terrycloth method as described in the manual but was not really happy with it. So I went with a stiff bristle brush (I think I read about that on the shipyard build). The frames are supplied with a sticky backing. Once painted, the mylar "glass" (which comes cut to size) is is stuck to the upper part of the inside frame. The outside frame is then stuck on top of the inside frame, which then fits into the window openings in the walls. I made holes in some of the window, took one pane out completely and took out just one corner in another. The clam and oyster sign was fairly straight forward - 3 pieces of strip wood were weathered (thanks Dr Grunge!) and painted white with the bristle brush. They are then glued together and some nail holes added at each end. The dry transfer decal is now placed on the wood. I had no idea how this would work given the age of the kit (at least 7 years since I bought it. Brett has great instructions on how to do this. Not all of the deal transferred however I think this add the ages look. The decal was rubbed with the end of a paintbrush to burnish it into the wood (you can actually see the wood grain through some of the decal). The a few very light swipes with the steel brush and it was done. Here is a pic of a few windows and the sign... Jeff
Greetings, After completion of the Revenge 1577, I thought I/d turn to something a bit different - 2 HO scale models by Sierra West that I've had on the shelf for several years... Foss Landing and the Shipyard at Foss landing... There is a current build log for the Shipyard in this section and I will be following along with great interest, however, I am starting Foss landing first. he sierra West website has a great forum with many helpful tips on weathering, painting the various casting etc., however there are no logs on Foss landing so I hope to not screw things up too badly. So off we go... The instruction manuals are quite extensive and offer many tips on construction. Foss landing is 67 pages. A list of kit components required tools, paints and other supplies are all supplied After getting said supplies, first steps are to give a base coat of paint to both the metal casting (black) and the resin ones. I decided to try my hand at finishing some of the resin casting by following a tutorial on the SW forum. After the base layer is applied, the various items are painted, then highlight and weathering / rust is applied with a variety of soft pastel chalks (Rembrandt is the brand recommended). Here is a before and after... Here are a few others... There are many wooden barrels, steel drums and metal castings yet to be done. Some advance prep before starting work on the building include painting the roofing tar paper and shingles and window frames... And adding texture and stain to the strip wood (which seems to be basswood). This will be used for edging on the first building and window / door framing. The wood is give "texture" by running a steel wire brush along its length to add grain, then stained with paint which has been thinned (this is an earlier kit compared to the Shipyard where staining is done with the rembrandt chalks and alcohol. More work on the wood strips comes later (adding knots, more weathering...). I think you can get the idea in this photo... Once these steps are complete, its on to the clapboard walls of the first structure, "Foss Clam and Oyster Company". The walls are pre-cut clapboard style. The need the be textured to give some grain, small nail holes are placed along the wall to simulate the nailing to the underlying studs, some boards are divide d with an 11 blade to simulate a seam and finally details are added to simulate weathering (loose boards, chips). I also added a few random knots in a few strips. The walls are then braced with 1/8 inch sq wood on the back to prevent warping then given a light coat of paint (off white) as a base layer. the final layer will be a brown/red. here's one wall with the base layer. This is highly magnified but it does demonstrate a loose board toward the top, some chipped boards, scratches as so forth. The first layer of paint pretty much covered the nail holes I made. Not sure I will do much about it as at this scale they should be pretty much invisible anyway. There Jeff
Greetings and thanks for all the kind words! last topic - the flags. As I stated earlier, what comes with the kit is quite nice however it is much too thick and stiff. As you can see a post above, the flag is meant to be folded over onto itself (one side is sticky). This results in a flag that is 0.15 mm thick. While this seems pretty small, at a scale of 1:64 this represents a flag that is over 8 mm thick! A 1:1 scale flag I have at home is 0.15 mm. So I uploaded the flags to Adobe Lightroom, played a bit with the colors and printed them on paper - same problem, too thick. next up, some leftover silkspan that I used for the sails. This was .02 mm thick this would be 1.28 mm at full scale which is close enough. when printing on silkspan with an ink jet printer, the design ends on on both sides. I cut a piece of the silkspan, used a glue stick to attach it to a standard piece of paper and printed it out. the results were not bad but the silkspan was too translucent IMO and too white. So, with the same paint I used for the sails,this was the result (this was actually one of the paper sails but I used it to show the contrast between the stark white of the paper and the off white of the flag)... Three of the 4 flags had to be treated in this manner to tone down the white and translucency of the silkspan. Another thing to consider was how the flags would hang. Having the flags waving as if there were a stiff breeze would not be appropriate as the Revenge is at anchor with calm seas and minimal wind. so the flags would have to hang limp. problem is , if you wet the silkspan with water, the colors will run, especially with the blue and red main flag. After doing some research on this topic I came across Krylon Workable Fixatif. This is used to fix colors on pencil charcoal and chalk art and has a matte finish. A few coats and the flags went up - basically tied to the topmasts with 5 evenly spaced ropes to fix it in place. The flag on the fore topmast was a pennant so i placed a very small block at the top for the pennant to be raised and lowered. here are 2 flags in place... Now hoe to get them to hang limp - rather that water I used 70% alcohol to wet the flags an put a very small clamp at each corner to pull the flag down. That has yet to be done to the bonaventure flag. And finally the main topmast flag Overall I am pretty happy with the result though it took some time to get it right. And what would a ship be with out some crew. If you take a look at the for sale section on this site you will see what I used. Here they are painted and if you look closely at the many photos above you'll be able to spot some. The scale is 1:72 which was close enough. This about wraps it up. my final post will be with the plexiglass case complete and in it final location at my office. Thanks to all for following. Look for my next project in Non-ship/categorised builds. Jeff
Greetings! As we fast approach the end of this story, here are some additional photos. I'll start with the seabed. Here are some close up pics of the sunken cannon and anchor. below is a photo of the ship in its plexiglass sea. Although it is textured plexiglass, It looked a bit flat to me. After looking at some railroad hobby websites, i decided to use something called mod podge to create some slight ripples (as this scene is a ship at anchor, very calm seas. I also added some floating seaweed and a few leftover barrels floating around. first pic is what the mod podge look like going on Maybe not perfect but I am happy with the result. I think the floating weeds and barrels adds a bit more character. Next one shows the anchor cable and anchor buoy. I wanted to show one anchor and buoy stowed but not the cathead fall block with rigging. and one last view from the bow and starboard... Next post I will describe how I made the flags and crew. Jeff
I have the following items available and all I ask is shipping costs. I have copies of each book and the extras are just gathering dust. Also, I used the English sailors for the Amati revenge. As I am not likely to be building another ship from this period, i offer them to someone who can use them. Here's a few photos of the items Written on the boxes above is the number of figures left. Below shows what they can look like painted. Historic ship models is a bit worn (given to me by another modeler) and is missing some pages at the beginning (must have been a printing error as they do not look torn out). However I have supplied the missing pages in print and theses pages do not cover any of the most useful info in this book. Arts of the Sailor is brand new, lists for $8.29 on Amazon If anyone interested in these items send me a PM and I can give an estimate of postage. Jeff
Greetings: Its been awhile since my last update. Work on the ship is pretty much complete with all the sails now up. I decided to leave the bonaventure sail set in order to show one sail not furled or drawn up. Gaskets were added on the square sails. Here are 2 photos: Still on the to do list: anchors, flags and the base with simulated water. This next pic shows the kit anchors and stock. The anchor stock was pretty bad so it got tossed. New stocks were made using some leftover boxwood. Here is the complete stock, compared to the kit stock. The anchors were also lightly brushed with some paint to give it slightly rusted look. Anchor buoys were constructed next. Rather than carve an egg shape, I used small slices of various diameter dowels and glued them together. They were then covered in wood filler and sanded to shape. Next,, the buoys were wrapped in black rope and harnesses attached. Here are 2 photos. One anchor will be stowed along the channel with the buoy tied up to the shrouds. The other will be on the seafloor with the buoy "floating" above on the simulated sea. The photo below shows the base of the ships case. The vertical dowels are plexiglass which will hold the plexiglass sea (eventually screwed in at the corners). And this photo shows my simulated sea floor - large and small stones, sand and lichen. If you look closely, one anchor can be seen in the foreground. I also has 2 leftover cannons from this kit. Although they were assembled there was no place to put them so they became detritus on the seafloor (after smashing them with a hammer). see if you can spot them. One of the last items are the flags. Material supplied by the kit is really too thick and inflexible. I've imported the flags into Lightroom and I am planning to print them on silkspan or tissue paper. Still a work in progress getting the colors correct and printing them. I'll post some pics of the stowed anchor and buoy and the ship in the sea soon. Jeff
Thanks for you comments and observations kirill. The look I am aiming for is for the sails partially drawn up with the ship at anchor, not fully furled. Most of the paintings you have shown on this log show either sails fully furled sails or billowing. I am looking for something in-between as might be seen with a ship at anchor but able to make way quickly if need be. As such, I am not exactly sure of the location of the top yard but I would assume that when the gaskets are undone, the yard would be elevated so as not to foul any of the lines beneath. Of course I could be wrong but I'll likely leave things as they are. Photo below is close to what I am trying to achieve. Regarding the gaskets, I guess I should have read a bit further in the chapter on sails in Anderson's The Rigging of Ships in the Days of the Spritsail Topmast. I will give some thought of how to add them to the yards (and decide whether I want them to hang loose[drawing "B" in above photo] or coiled, ["D"]). Jeff
Greetings It's been a while since my last post but progress continues. The last post ended with work on the main sail. The main topsail is now complete excepts for the braces and work is in progress on the mizzen and bonaventure sails. These yards and sails are a bit "fiddly" to work with. The parrel is a bit different than for the square sails. The trucks have 2 holes for the 2 rows of parrels however one end has a deadeye seized as such: The deadeye is a standard 3 hole one with the middle hole plugged with a treenail and then stained. the parrel goes around the mast and the 2 loose ends go around the yard's halyard, through the deadeye and end after a short length around a thimble. Here's a photo: Next photo shows all lateen sails in place. The upper mizzen halyard is still under construction in this photo (which is why the sail is a bit "off"). Also, the small triangular wooden supports for the lift crows feet on the mizzen halyard happen to be in the wrong place (the bonaventure sail has the correct location - blue circles). It took a bit of work but they have been corrected. With the sails in place all that's left is the running ringing - easy, right? Well, the lateens yard's lift's were quite the headache as all them are connected. here's what is on the plan: And this is the model. Some of the ropes were left long at the seizing for adjustment if needed (one or 2 still need to be snugged up a bit). and a closer photo... You'll notice that the mizzen top lateen sail has been furled. The only other line for this sail was the sheet. The mizzen lateen also has the bowline, sheet, martnets and tacks in place. I am working on those line for the bonaventure sail at the moment. And finally, a ship needs a crew so a few have been added ( one is visible on the main top in the photo above). Pretty soon work will start on the plexiglass cutout that represents the sea as well as a base for the model. Jeff
Mike: I think I understand what he was asking now. Based on the bulkhead slots for the bowsprit, it should come straight out from its slot in the bulkheads, basically parallel to the center line of the ship (although offset from center on the starboard side). It should not angle from right to left. When I placed the bowsprit, it was a pretty snug fit with no "play" at all. Jeff
Marc, Here is a photo of the bowsprit and the stem. The angle is close to 20 degrees though it was hard to measure with all of the rigging in the way. The distance between the stem and bowsprit (red line) is about 58 mm. Not sure why you have a lot of play in the bowsprit as mine was a pretty tight fit. Hope this helps Jeff
Thanks for the comments Marc: In regards to your question, I assume you mean the angle of the bowsprit from horizontal. not sure I can give you the angle but I will let you know the distance the bowsprit is above the stem in a post later today. That may help with the correct angle. Allenyed: I am aware that belaying pins on a ship of this period are likely anachronistic, however I decided to keep them anyway. There are just not enough places to belay all of the lines on the rails and cleats without it looking a mess in my opinion. (The foward rail on the fore deck would have to have 14-15 lines tied to it for example). Even so, the plans call for several lines to be belayed on one pin so these lines were tied to the rail. As the kit was designed by Chris Watton for Amati, it would be interesting to hear his opinion on this subject but I have not inquired. ( I did find one reference of belaying pins found in the wreck of the Mary Rose, so...) Jeff
Greetings Work continue on the sails. The sprit sail, fore course and topsail lines have been placed except for the bowlines in the following photos. The spritsail is shown partly furled. Here's a photo of some of the lines belayed. In order to remember the size of each line and where it was rigged (in order to make the appropriate coils), I made this cheat sheet to represent each belay point on the fore deck. The name of the line and rope size is listed for each belay point. After the main course was set, I decided to finish the lines to the sprit sail and the fore sails. This included the sprit sail sheet and the fore sail sheet and tack line. Some completed rope coils... forward view of work so far... And finally one of the crew working the sprit sail halyard. Jeff
Greetings! Construction continues...below - martnets and buntline on the forward side of the fore course. The Halyard was a bit of work to place as the lanyard and block were placed a long time ago as the knighthead is below deck and unavailable to rig. The first loop around the yard was easy enough...the second one had to be secured with the mast in place and under the correct amount of tension. Not visible is the 1mm brass rod the was placed to hold the yard onto the mast. This also keeps other lines from pulling the yard up. At full scale the yard would have enough weight that this would not happen but at this scale, there is not enough weight to pull the halyard down naturally. On the aft side we have the martnets and the clew lines. Fore course sheets and tacks now attached to the fore course clew. The sheet lines had to be taken down a bit in order to have access to the fore deck for placement of later lines. These ropes were used to pull up the sail to its current position. The sail is lightly sprayed with water making is quite pliable and easy to draw up. It will then dry and keep its shape. It was at this point that I realized I forgot to place the parrel trucks and beads (see photo 2 above). The work was a bit tight however I was able to get them on as can be sen below. The fore yard lifts are also on at this point. Here's a view from the front. Only line left is the bowline which will go on after the topsail and sprit sail are on. Next up, the for topsail. Placing the halyard and lanyards for this is quite the process. Everything has to be checked and rechecked to get the correct tension without pulling the main stay way out of alignment. here's a photo on the work in progress... And finally the topsail ready to rig. One of the issues with sail placement is finding a place to belay all of these lines. Some of the belay points on the plans did not seem to work and in some cases up to 3 lines were to be belayed at the same pin. I was able to make it work with a combination of the belaying pins and the rails and modification of the run of some of the lines (belaying pins may be an anachronism for this period but so be it - leaving them off and tying all of these ropes to the rails is not something I wanted to do). Most of the work on the topsail and sprit sail is complete and I will update with more photos soon Jeff
Greetings! For anyone interested, here is a brief description of how I made the sails. Comments and posts regarding sails and their construction on MSW were quite helpful as I have never done this before. Starting with a sheet of silkspan, one side was painted with a foam roller and hung to dry (I used some acrylic paint, cream color, that had been used for walls in the house). The kit provides templates for all the sail. These were cut out and glued to cardboard to provide some thickness. The sail outline was then traced onto the silkspan. Seams were marked and drawn onto the sail with the result below. The sail was then cut out with ~5mm overlap that would be folded over to secure the top and bolt ropes. I know this is not how the ropes were attached however at 1:64 scale there is no practical way to sew the rope to the silkspan so I figured this compromise would work. Photo below shows the process with the head rope glued and work on the bolt rope. The flap has been folded over and glued on the left. The bolt rope was one continuous rope from the left upper corner to the right. The clews were easy to make by just leaving a little extra and seizing the rope. The cringles were made by passing a needle with a small thread through the bolt rope at the appropriate intervals (as marked on the sail plan). They are pretty secure once the flap in folded over. This process can be seen below. After the ropes are placed I lightly paint the sail to lessen the prominence of the seam lines (this also makes the foled over flap of silkspan less visible). On my previous post, I think the lines are too visible on the fore course so this extra layer of paint make them a bit fainter. I ended up redoing the this sail for this reason and also because I placed the robands at the seams and after further review, they should be midway between the seams. Photo below shows a close up of a lateen sail and then all the sails. Once the sails were complete I decided to revise the head cringle (or earring) as I did not like the loop as seen in the main topsail (second from bottom). It should look more like the main sail (bottom). I've already got the fore course, topsail and spritsail rigged so more photos to follow Jeff
Greetings! I am looking for a ships boat to compliment my Revenge build. Does anyone have any recommendations for a commercially available ships boat kit that would be close enough for this period. I've seen what is available with Vanguard Models and Master Korabel but these are meant for ships of the 18th century and I think may not be appropriate for the 16th century. I might be able to modify a kit but I've not had much luck finding a picture of said boat. Thanks Jeff
Greetings Kirill Great points, as always. Every time I look at your galleon I am amazed with your work. On more than one occasion I have used it as reference for the Revenge. Re: the blocks at the end of the fore yard, they are indeed the same size as that was what the plans called for. After some thought, I decided to change them on both the fore and main yards to a 6mm block for the topsail sheet at a 4 mm one for the lift. I have some 7 mm blocks but I think visually they look too big. As far as darkening the lanyards the time for that has passed - I don't want to try to darken them up in place and it would be way to much work to redo them. As they are a medium shade of brown I do not think they detract from the overall look. I may use black for my next model (whatever that may be) but I do like the contrast even if it may not be historically correct. And finally, I think I will do as you suggest with the sails similar to the photo above. I will continue to post as things progress. Thanks as always Jeff
I am using silkspan for my current build of the Revenge. I got it from a company called SIG. it is offered in light, medium and heavy. Here is the link: https://sigmfg.com/products/sig-silkspan-tissue Here is a photo from my build log. I am trying to simulate sails partially drawn up as if the ship was at anchor but not completely furled like they might be if the ship was in port. Jeff
