rummy
Members-
Everything posted by rummy
Hello Everyone.I have been working on aft deadwood #4.Why you ask? I decided that if I could not make this part and get it close to what it should look like,Then I should quit and take up plastic models. Here is the results,made of maple this time. Here Is where I had most of my problem.Getting this to 3mm.I finally did and this end will be covered. The bottom part has to be tapered also to fit the keel.The top and the knee was a problem,the only cutout I could find was the side view of with the dead wood.Wangs pictures did not show this knee being used so I tapered it also. I am happy and can continue building wooden ships.Few more pictures Larry
Guy,I am going to try that thickness sander.Nice job. I have a drill press sander but I'm allways looking for something new. I just aquired a disk and long board sander.I'm looking for some way to control the sawdust. It makes a lot and makes it fast. Yes I am on the western side of Wi.Been here about 25 years.When it snows in May it is time to leave. Larry
Hello Everyone,I'm having a heck of a time with my stern deadwood. Christian here are a few pictures of my problem. This is a picture of the of the keel which measures 6.5 mm and the rear of the deadwood which is 3mm On the 3 piece steps the center wood would be 1mm and the steps at 1mm each at the rear of the deadwood.How do I make the keel and deadwood agree Here is the way I did this. Thanks for any help Larry
Hello one and all.I finished most of the bow pieces.A real challenge to say the least.The whole thing I did over again,some parts I did Over 3,4,and one piece 5 times. On this part I used the saw seemed to be easier.Yes and up side down.Dang camara "smile" This is the steps cut in three pieces. The rest were cut,sanded.fitted and sanded some more.It takes quite a while to get the fit right Does anyone know where to start the taper and what the final size is on the bow? Where to start next?Maybe the keel? Have a nice day/night Larry
Hello Muggle,What is the name I should call you? Are you in China? My name is Larry And I started this build a short while ago.The thickness of the Bobstay and the Eaking is 8 mm.They will be tapered later. Your picture of the chocks shows only 3 and there should be 4.The timber you chose is nice Best of luck Larry
Thank you Mark and Guy,I did change wood for the keel and bow pieces.I went with mahogony.I will still do the frames in maple.I changed my building technique.Now I am cutting fitting and sanding one piece at a time.It takes a little longer but the fit is better,at least on the bow.Only one picture. Good Night Larry
Thank you everyone for the warm welcome. I have been cutting bow and keel pieces.I took a look and decided to go with a darker wood for these parts.Back to the hardware store.Thats ok for I need practice.There is one piece I was dreading and that was the fore dead wood steps.So I took the easy way sanded the fore wood down to 3/16 inch then added 1/16 Bass wood steps. This made a nice clean steps Best Regards Larry
Nice tip Rusty.I was wondering the best way to do thoses. Thanks Larry
- 332 replies
- Triton
- cross-section
Hello to the few, the brave,and the crazy.I have now joined you and I must be crazy to try this build. I am almost done with the Triton Cross Section.I took a look at this build and saw the bow and all the pieces I knew if I could build this I could get threw with a lot of help.I am milling my on wood and the frames will be made of maple.Parts will be cut with a band saw and finished with a home made drill press thickness sander So on with the show Larry The first picture shows how I mount my templates to the wood.Double sided carpet tape then a little baby powder to remove the sticky.There are other ways but this works for me
