Posts posted by Micklen32
Good job Slog and great repair
Looks really good
Great work as usual
Had a fantastic night at the theatre last night with The Admiral
Solid Gold Sixties 50th Anniversary
Celebrating 1963
I was 13 at the time but the music was something else
Some of you may not remember some of these groups but we saw. The Fortunes, The Searchers, Brian Poole and Chip Hawkes (Chesneys father) from the Tremeloes, P J Proby and headlining Gerry and the Pacemakers
Absolutely fantastic
I was so up I managed a bit of work today and finished the Foremast yards
Completely done now and ready to fit
I have also made a start on the main mast making the top and shaping the lower mast
I get the paint for the guitar Monday I hope and then I will be concentrating on that for a bit
Once I actually start painting it shouldn't take long as the paint and laquer system is made to work together and coats can be laid down 15 minutes apart
The guitar is about ready for painting
Took a lot of work but I think I am there
It is difficult to tell without laying a coat of paint on there
OMG I would kill for tools like that
And the workroom to use them in
Does that do beautiful work or what ❓❓❓
Superb Theo. Superb
Great work Theo
It all looks so realistic
Excellent
Got to have a rest day today
Woke up to pins and needles plus cramp in both hands
- Sjors and DCIronfist
- 2
have a look here Mick : http://www.occre.com/index.php?option=com_productos&task=showProduct&idproducto=121〈=en
it seems the English index doesn't list everything
click on the Spanish flag and you ll see her listed
if you are in the detail page you can click on the English flag to get the English text
AAAAaaaahhhh. Thanks Adriaan
That is wierd Sjors as it is not shown on the OcCre site
There is another ship they have on their list, the Nuestra, that doesn't appear on the Occre site
I don't understand that
Just as Adriaan says, they will join the ship when you finish it
- 2
Looks good Adriaan
You are definitely right about the windows
White would not have looked right I think
Thank you Tom
The first ones I made were more like the one at the top
They did not look as good though
I finished the first foremast yard
It took me a full day as I could not do too much before resting the fingers
I had to make most of the blocks as well
I would have to say that so far this has been the most difficult part of the build
It still needs the fancy bit making to go round the mast and hold it in place
At least the next one is a lot more simple
Well it looks like it should open
Great work as usual Tom and thanks for the violin block info
Just to show one of these violin blocks I am making here is a photo
Whether I am making it right I don't know
I glue the 4mm to a loop then put a spot of glue on the top of the 5mm and glue it to the 4mm
then wind around
I did try crossing the cotton under the 4mm but I didn't like the way it looked
It then looked very much like two blocks 'tied' together
Were the violin blocks one piece IRL?????
Hi Sjors
Yes, two more masts to go, eight yards and I think it's called a gaff
I make a batch of blocks every now and then trying to remember to run a drill through all the holes
I bet when I come to threading the cotton through some will be blocked
Thank you Alistair
It is certainly a striking colour and I hope the translucent candy apple on the front will compliment it
They do a translucent candy apple green for the airbrush so I am hoping that will make my life a lot easier
Busy again today as well
Finished the foremast
Very happy with how it went together
It wasn't easy though and I will sit down and study the plans to see if there is an easier way
I am now working on the first yard for the foremast
Seems almost as complicated as the mast with all the stirrups, foot ropes, booms and I don't know what else
The work after the hull is built and finished is, I think, the most difficult and I hope rewarding part of the build
I am getting Sjors in as soon as I open the bag containing the ropes
- Adrieke, Sjors and Captain Slog
- 3
Hi all
Just to let you know I have been busy busy
I have spent most of the day making these :mellow:
They seem to take forever
Half the time is spent sanding CA glue off the fingers
I have nearly finished the foremast then I have the three yards to make and they are nearly as complicated as the masts
Been hard at work on the guitar
The photo won't look much different from the other one to the uninitiated
Can see that the constant laquer/sanding had brought out some darker areas
Also if you compare this to the other photo you will see that this one is much much smoother
When the front is perfect I have the sides and back to prepare but they won't take long as the Basswood is much easier to work on
Whoops
Forgot to show you the neck after copious applications of lemon oil, THE treatment for guitar fingerboards
Lovely work as usual Slog
Totally different from mine again
My Bumkins sit ON the gallant rail and have also straightened out a bit after getting them just the right shape
Also my cats eyes only have one roller at the top and then that thing at the side
Someone did tell me what it's called but I have slept since then
Hi Mick,
Your choice of colours for your guitar should look real nice.
Greg and Tom answered your questions but might add that probably easier to fake the mast sheaves with a couple of holes and a groove. I did 0.3mm holes and groove in the 2mm ensign staff and today did 1mm holes in the cat-heads.
Once you drill the holes use a steel rule and a new No.11 blade with a sharp point to score a line between the outside edge of the holes, joining the two. Doesn't have to be deep then use the point of the blade to pick out the material between the scribe marks. For the 1mm holes I also used the point of the drill at a shallow angle to 'scrap' up and down the groove by hand to clean the edges. Didn't with the 0.3mm for fear of breaking it.
Cheers
Slog
Thanks a lot Slog
I am hoping it will look good
I am getting quite close to painting but the problem is I have to save up for it as I busted myself buying the kit
Coming on very nicely Edward
Planking is certainly up to it
A bit of work will get it perfect for the top planks
I like that idea of using a piece of basswood
Hi Mick,
I have the same on my masts , those sheeves…..
I try to make them on a spare part of dowel that I have left, and it not works….
I try the milling machine and that also don't work.
So, no sheeves on my mast then….
I think when I go further, I damage the mast and that is not a thing that i want to.
I see Sjors
What were you trying to do
Two holes through the mast then a groove between????
Thanks a lot Tom and Greg
I'll get those violin blocks put together and see if I can reproduce that slot/sheeve
These masta and yards look like they will be the most complicated parts of the build
HMB Endeavour by Micklen32 - OcCre - 1:54
Not doing a lot today
Being lazy
Did a bit of work on the lower mainmast
Stuck some stuff on it
I think it actually has less bits on it than the foremast
I was thinking of doing the wooldings but that went up in smoke when I decided to prepare the guitar body for painting by screwing a length of wood on it to be able to handle it and hang it
I also made sure my airbrush was clean
So it is depending if the guitar paint arrives or not what happens tomorrow
