marsalv
NRG Member-
Everything posted by marsalv
Pandora by marsalv - FINISHED - 1:52
marsalv replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Greg, Nigel, Janos and Albert, thank you very much for your kind words. I´m very happy that you like my work . I finished the gallery windows. -
Thank you Mark and Dimitris for nice comments . I have started production of the rear windows. It took a pretty hard time, because each window is original. -
Hi Greg and wyzwyk. Thanks for very nice comments. I added the upper base for the side windows and mullions. -
Thanks guys! The milling machine is Proxxon M7 70. -
Thank you to all for very nice comments! I finished the deck, including treenailing and attachment of the sculpers. -
Thanks to all for nice comments. I added the top part of the planking above the wales with free space for decorative moldings. -
Thanks Greg, you are right - not hours but days . I finished the first part of planking above wales. This part will not be colored, so I used here the treenails. -
Thanks to all. The idea for making treenails with needle is not mine, I learned this method from russian modelers . To rtropp: see enclosed picture - front side of the block with treenail is covered with masking tape, block is cuted off with saw. After removing tape you can easily eject treenails from the block. After endless hours I finished the hull treenailing. Result will be more visible after waxing. -
Thank you Greg. Although it is not historically accurate, I decided to leave the hull without copper plating. On the other hand, the whole hull will be with treenails. So I started the "mass" production of the pins (about 8,000 pieces). -
Thanks to all for nice comments . So after about a month of hard work is the planking of the hull under wales finally done. -
