marsalv
Everything posted by marsalv
  1. Little progress - futtock staves nad catharpines are installed.
  2. Hi to all, the most useful books for me are the following: - Masting and Rigging of english ships of war - James Lees - Rigging a sixth rate sloop of 1767-1780 - David Antscherl Citation from the second one: "In reality there was an eye spilce in each end of line that was then seized to the end shrouds, and the line clove hitched around each intermediate shroud. For model work, unless you are absolute purist, this can be simplified by omitting eye splices and seizing." It is also my case, I used the clove hitch for all shrouds. The knot is finally fixed with small drop of diluted PVA glue.
  3. Hi Alex, beautiful work. Your log is great inspiration for me.
  4. Hi GuntherMT, there is odd number of grooves on the wooden ring, each groove contains one thread. I used a single thread and weaved it around to make a spiral - this is reason why skeleton must contain odd number of thread. If you use even number of thread in skeleton, you can not use a single thread, but you must use a new thread for each row in mouse - this is not good idea.
  5. All the ends are secured with diluted PVA glue to the stay. It is very important that the "skeleton" from thread must contain an odd number. Then just drag out another thread throughout the "skeleton", alternately one under, one above thread. It is little difficult and time-consuming work. The stays (and their accessories) is ready and installed on the model.
  6. Thanks Bedford. Next part - mouse for the main, fore and mizzen stay.
  7. I have finished the shrouds instalation. The used dead eyes are not ideal - groove for the rope is too big and the rope is hidden in the groove. I will try to make my own dead eyes for my next project (Pandora).
  8. Works on bowsprit rigging are cpmpleted now - bobstay shrouds, bowsprit shrouds, boomkin shrouds) and main stay collar.
  9. Thanks Nigel . Bowsprit is attached to the hull. A few pictures of the gammoning and rack-blocks. .
  10. Hi Alex, wonderfull . Your log is great inspiration fo my work.
  11. Hi again, after a short break I would like finally finished my Royal Caroline. Although most of the parts are already done, there is still a lot of work on the sails and rigging. I started slowly preparing blocks and auxiliary cables on the bowsprit. Jib traveller will be mounted later on bowsprit.
  12. Hallo Alex, thank you for compliment. As you can see I was very inspired by your Sphynx log .
  13. Probably the last work before saving Pandora to hibernate - deck in the officers cabin, gluing the main deck beams.
  14. Hi Michael, I will try to answer your qustions (sorry for my bad english). Proxxon drilling maschine has 3 spindle speeds and I use the medium speed. Each treenail is made only with one down/up movement of cutting needle. Sequence is following - down with needle, up with needle, movement wit XY table and again. It´s pretty fast. You must only watch, if you can see treenail in the wood block after drilling. If you see no treenail (black hole), needle is propably blocked with wood and you must clean it. It is also the answer to your third question - treenails MUST stay in wood block. After drilling cover the face side with holes with adhesive tape, carefully cut off the opposite side and then push and remove the treenails from the block. It is easy .
  15. Thank you all for nice comments . I used usual hypodermic needle with diameter 0,8 mm (21G). Needle is carefully ground to the tip - see pictures. As wood is used pear, a necessary condition is that the wood fibers would be parallel to the needle. Is it possible to make treenails with diameter 0,45 mm (needle 0,7 mm 22G). You can see the comparison between 0,55 and 0,45 treenails in the last picture.
  16. Lower deck - it will not be visible, but I made test how the deck will look with black paper and treenails. I made about 3500 pieces of treenails (diameter 0.55 mm), so I have a sufficient supply for any remaining deck.
  17. Thanks everyone for the feedback regarding painting. I still have enough time for a final decision. I soon interrupt work on Pandora and start finishing Royal Caroline. I make now only minor works from this reason - preparation of deck beams and deck planks.
  18. Inner planking is completed now including sweep ports and holes for fixed blocks. Now I am standing before deciding whether to paint inner planking red or left it in its natural state.
  19. Hi Nils and Dave, thanks for compliment . I started the inner planking - waterways, spirketting and quickwork are completed.
  20. Thanks to everyone for the positive feedback. It gives me great encouragement for further work. I decided to make wales from separated parts. It took me about 40 hours to make and stick 4+4 wales nad 1+1 black strake .
  21. I started the hull planking - the lower counter. It is my first attempt to planking the hull in one layer.
