DaveBaxt
Members-
About DaveBaxt
- Birthday 06/27/1953
Gender
Washington,,North East England
Interests
Walking, football( now watching) Ship models and Maritime history
Beef Wellington reacted to a post in a topic:
HMS Diana 1794 by DaveBaxt - Caldercraft - 1:64
DaveBaxt reacted to a post in a topic:
Le Rochefort by Some Idea - 1/24th Scale - First POF Build
Thank you Andrew for your kind words ,it is always appreciated. . Hopefully I am not slowed up for to long. I moved into the garage where I have most of my machine tools and whilst working on the hull and have more space. For all the other stuff I have another shed which is much more cosy and well insulated..
Slow process due to health issues and unable to work on my Diana other than short periods . After laying the deck planking and checking the height of the gun port sill against the 32lb Carronades it was obvious the sill were too high. It was therefore necessary to remove the 1mm thick sill to remove some of the material or then replace the 1 mm thick sill. In order to do this the sides of the gun ports, also 1 mm thick also required removing. Although this was time consuming I eventually managed to complete this. Below is a photo of a 32lb carronade in position and it can be seen not parallel with the deck due to the gun port being too high Once the sills were lowerd then it was possible to fit the 1mm walnut planking on the inside of the bulwarks and cut out the shapes of the gun ports.I then moved onto the hatch coamings and various size gratings. Fitting of the stove chimney. At this point I would like to Thank DavidEN for giving me the idea of upgrading the ships Wheel to 24mm Caldercraft Deluxe wheel as the one supplied by the kit looked to be on the thin side. Next up will be the 32 lb carronade and 9lb Cannon the latter of which I will once again upgrade to that supplied by Vanguard models.I think I can get away with the Caldercraft brass cannon but feel Vanguatd carriages are a definite upgrade. There are still a number of fitting which need to be completed before finally getting to the ships boats. Hoping my health improves so I can get stuck in during these winter days.
HM Cutter Trial 1790 by AJohnson - FINISHED - Vanguard Models - 1:64th
Handling the anchors on large British frigattes (HMS Diana 1794)
DaveBaxt started following Types of 32 lb Carronade on late 1700s frigate and Wood Glues
Wow! So much work since I was last here and what a great first attempt at sails which look like they were done by a seasoned pro. Well done Andrew your workmanship is an inspiration to us all.
According to Brian Lavery book 'The Arming and fitting of English Ships of war 1600 to 1815' The Sliding bed of a Carronades where secured either on the inside of the bulwark or the outside but I am unsure which way is likely to be the case on the HMS Diana 1794. Here is a photo of an assembled 32lb Carronade which came with the kit According to the book AOTS Diana the front of the carronade is secured by what is called the fighting bolt through the iron bracket and a piece of wood on the outside of the bulwark and below the gun port. If this happens to be the case then unfortunately the gun ports for the are too high and will require lowering. It will also be necessary to attach a piece of wood to the outside lower part of the gun port . This does not appear to be shown on any of the other drawings. Another way to get around this without taking any drastic measures would be to attach the brass bracket on top of the sliding bed rather than underneath as suggested in the instructions.This would then allow the bracket to slide over the sill of the gun port. I know in my heart that this is probably incorrect but it would be a shame to alter the gun ports at this stage of my build. Any thoughts or suggestions as to the best way around this ,if in fact the fighting bolt is in fact fitted on the outside of the gun port sill. Thank you once again for your help and patience. Best regards Dave
Completed planking the upper deck, mainly using 1 x 4 mm Tanganyka strips which came with the kit together with some extra wider strips used for joggling. I also used quite a lot of 1mm Tanganyka sheet which was quite difficult to cut and split along the grain. In the end I temporarily glued a 1.5 mm sheet of ply to the Tanganyka sheet to strengthen the Tanganyka whilst cutting and shaping the waterway . I used the same planking pattern as the lower decks(4) with the length of each plank 180mm and staggered 45mm. Unfortunately there was quite a big difference between the colours of the Tanganyka sheet and the strips but hopefully this will not be too noticeable once the decks are covered with the numerous fittings. I also used the drawings off the AOTS Diana book as to which deck openings had either coamings or scuttles and ended up with a lot of wasted Tanganyika pieces due to attempting to cut this wood along the grain but hopefully I have made a reasonable job of this. I would like to thank Andrew Johnson for giving me the idea of using one of the many Liberon products on offer for trating the deck This time I have tried their superior clear oil which I think shows the Tanganyka wood off quite nicely. Next up will be the hatch coamings, gratings and the numerous upper deck fittings. Still a long way to go as am well past the 18 month mark now and no end in site yet but she is beginning to look a bit like a late 18th century frigate..
Further preparation made for fitting of the forcstle and quarter decks and fitting of additional beams. For some reason several of the deck beams had to b moved so that they did not appear in the middle of the hatch openings and scuttles I also fitted a number of the carlings in-between the deck beams. so as to line up with the edges of the hatch openings. This also would give additional strength to the deck. I also made a frame work for ladders supports and made up a couple of ladders either side of the gangways. I then marked off the forcsle and quarter decks to take the 1 to 4 deck plank pattern which is the same configeration as the lower gun deck planks. I also cut the deck into 4 pieces as I thought it would be easier to handle in smaller section when gluing to the deck. Before fitting the deck I made a final check to everything on the lower decks as they should be and finally fitted the elm tree pumps. I am now going to take a bit of a break and will be off on holiday so it might be sometime for the next update
Excellent rope work Andrew and I really like the look of those dark deadeyes and great looking shrouds.
Secured the bitts into position and made up the chain pumps handles from 0.8mm brass wire and the connection pieces from 2.7mm square boxwood and reduced to 2mm square and shaped Fitted the 18lb Cannon balls into the racks at the sides of the hatch coatings and making a start on fitting the anchor cable (2.1mm tan from Ropes of Scale)and making up a number of stoppers for securing the anchor cable to the lower decks. Finished off the eyebolts and rings for the gun tackle but left off the tackle for withdrawing the gun as I thought this would just clutter up the deck and believe this would be stored away when not in use anyway. made up stantions from the same fittings used for ther chain pumps handle bushes. I have left off the chain pumps until the last in fear of knocking them whilst work on the beams etc. Next up will be the fitting of the deck beams and skid beams prior to fitting the upper deck. A shame to cover a lot of the work over the last few months
