My Fathers Son
Members-
Everything posted by My Fathers Son
I have not been spending much time on CS recently so there is not much to report at the moment. Still only on the Mizzen, after completing the lifts, I set out to complete a set of sails, no problem sewing these but adding the the loops for the Clew, Bunt and Downloads. I tried brass rings on the Royal and top gallant and while I liked these, I thought I should try to do these in rope and tried several methods on the tops and crossjack. The scale is wrong on these, but rhe material is correct. I need to find a process that will do both. I have an idea but have yet to try it. This is my set up for working on the sails. the multi grips in the vice attached to the table brings the whole thing up to a convenient height in front of me so I can work on the small stuff without having to sit awkwardly. I have mounted the Royal and the crossjack. Here is the Royal. i was distracted by Robs wonderful images of Glory and have started recovering one of my boats. I removed to cloth I had made and tried to find a stiff metal rod to use for the brace across the top, the only thing I had was a shirt hanger. Unfortunately, I could not make that work. I could have used brass but instead I went for something a little more subtle, I length of cord I use for stays. I CA'd this to the stem and the stretched this over the stern post as tight as I dared, after giving the glue a short time to set up. I could see this was not going to give me that arch that Rob has but a length of coffee stirrer stretched for and aft sanded to shape and slipped under the cable gives a nice shape to the rope. i then coved it in masking tape, creasing the edges with my fingernails gently to gi e it shape. My method hasn't given that crisp centre ridge but then i haven't painted yet so this might change at that point. Fingers crossed but looking good so far. Simon
Cutty Sark by NenadM
My Fathers Son replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
I must applaud your tenacity NenadM, metal is a much harder (as in difficult) material to work with, and you have produced an excellent end result. Simon- 4,151 replies
- cutty sark
- tehnodidakta
Rob, Thanks for the explanation on the boat covers, I will have a practice on one of my rejects first and if I can make it work for me, then I can bring my Cutty boats up to spec. Simon
- 3,515 replies
- clipper
- hull model
Rob, She has wonderful clean lines and it is so obvious without her masts at this stage. I have been admiring your boat covers, (I have been admiring everything) but specifically, I have been looking at the boat covers as mine are rubbish in comparison. Are these silkspan? Simon
- 3,515 replies
- clipper
- hull model
I am not too far behind you, I have just made my sails for the Mizzen and will be mounting them shortly. I stopped rigging at the lifts, then worked on the sails, planning on installing from top to bottom. Just makes a bit more sense to me. Loving your work so far. Simon
- 521 replies
- cutty sark
- mantua
I see the advantage of the B&D vice over a normal vice, the extra width gives the opportunity to spread the lines at deck level so you can plan their securing points better. Much tidier. Simon
- 3,515 replies
- clipper
- hull model
My attempts at ratlines definitely improved when I started using the guide cards, I mocked up a clamp gluing extensions to a small clamp then when it was in just the right place, clamped it on the opposite side to balance the weight. I know you are working at a much smaller scale and looking to get a result closer to Robs than mine, but I am sure that this is the way to go. You've got this. Simon
I am definitely paying the price of not following this advice and have learned my lesson the hard way. Both yours and Keith's yards are works of art. Simon
Hi, Made these last night for the crossjack bunt lines. I did try with 2mm blocks to start with but they were too small for my fat fingers to handle. I have drilled through the leading edge of the mizzen mast top and these will be glued in place tonight. Keith, I do get what you mean about working in tight spaces, it seems that ever time I work on one thing, I upset another. 😡 this is in part because I have not actually fixed any line in final position and just tied them of as they would the real thing as I want to be able to make adjustments when it's all in place. Oh well, time to go earn a few pennies again, ta ta for now. Simon
Hi all, I am not planning to do any work this evening, other than maybe adjust a few of-the-shelf blocks to suit the purpose of their use, but I thought I would outline how I finally got my head around the thorny problem of when, or not, a block should be used. Firstly, I took on board that what I am working on is "Running Lines" which means these are not Fixed lines like shrouds but are expected to be frequently adjusted by crew members. For each foot above deck the crew member works, the level of risk increases exponenetially so any routine adjustment needs to be at deck level as much as possible. The old joke about "How long is a piece of string" comes to mind but its simple, its the distance between the two ends, and its the two ends that need to be addressed. The best way to simplyfy a system is to ensure that any adjustment is only necessary on one end. So if one end (Point A) is fixed, the the line can pass through as many function blocks (Points F) as necessary to carry out its purpose before going to the other end (Point B ) where it can be temorarily secured, ready to be released and adjusted by a crew member when required. So I came to the conclusion that Points A shoud be Shackles, Points B will be Belaying Pins and Points F will be Blocks of a type appropriate to their function. It might be that the Shackle is attached to the deck, a yard or even to a block when it is part of a block and tackle arrangement, but that is still a Point A shackle as it is permanantly tied off. Points F are for two purposes, either as a multiplier to reduce the load level on a specific line or, to change the direction of a line, or both at the same time and this can only be achieved with Block(s). So that is my rational behind the use of shackles and blocks in my rigging. Simon
Didn't want to take the boat down this evening so spent some time preparing some blocks for the tackle for the Mizzen Crossjack and lower top yard lifts. These started out as basic 5mm blocks which I have shaped so they are more oval. The two with tails will be hooked onto loops at the base of the mast. The upper top will have similar arrangement but will have 4mm blocks treated the same. The topgallant and royals are secured near the backstays, they will have similar block and tackle, longer but the blocks will be in 3mm. Takes time to adjust the blocks and stop them looking like a small brick. Simon
After having a good read through Keith's suggested reading and downloading a few of the plans that were linked, I now have a much better idea of where I am going. I was right about the excessive use of blocks to connect lifts to the spars/yards and am now working on devising proportionally sized anchor points and shackles to connect the cables. Using a combination of the Revell and Cambell plans, I can see where the lifts are anchored on the deck so know what to do next. One thing I am curious about though is, why is the port side equipment given stronger lift capability than starboard, the drawings show the starboard to be on lighter gear? Can't show images just yet as I can't add tension until the sail is fitted and the downhaul takes up the slack as the yard doesn't have enough weight to do this in itself. Simon
I too am confident that you will find your way through this as you have done with your previous hurdles along the way. Simon
Keith, You were right about the last link in you post, the draftee has taken Campbells drawings and made sense of it and the annotated it in colour setting out what equipment goes were and in what order. I have house guests from USA till the weekend but will get to reading as soon as I can. Thanks very much for this. Simon
Hi Keith, Well, I have been modelling my most recent attempts based on your excellent example set out in your build, but when Rob posted his most recent images of his yards, I noticed that he had not installed a block on the top of the Yard, just a Hoop for a Shackle to attach to. This made me look at the Cutty Sark herself and while it is difficult to see above the Yards from the deck level, I cant see any blocks at the ends of the yards. I do understand that she is not fully rigged, there are no bunt or clew lines, or leech lines evident here but the Lifts and Braces are installed. In fact, I suspect that these are the only running lines that are installed. I can see the Blocks on the Braces and those for the lifts close to the Mast, but none on top of the yards. You can see on the Coarse, Lower Top and Upper Top, there are Block and Tackle connecting the yards and that definitely will require blocks but I think that I will omite this on the Top Gallant and above. Simon
Thanks for the likes and I really appreciate the support, it has helped me a lot on my learning curve to restore this model. I have been looing at Yards and how differnt models get fitted out and one thing in particular is puzzling me. How do you connect the Lifts to the end of the yards. Some people mount blocks and attached the lift that way, but looking at Rob's Glory, he has hung a block below for the Clew Line but only has a Shackle above the yard to connect the line for the lift. There is no need for doubling the line to ease the lift, except maybe the Course and Lower Top Yards, so why would there be a need for a block at that point. Please feel free to comment. Simon
Right, that is the Hoover damage remade. I think these things should be a little smaller but I looked for one in Kit form and could only find 2. One was the Mantua 18mm model for Thermopylae but that would be 1:124. The only other one was 50mm which would put it at 1:76 . So my hand made one will have to do. So now it's back to fitting out the Mizzen mast. Simon
There was a minor tragedy over the weekend. After I submitted the last update, I left CS on my table while I went out shopping and my eldest decided to vacuum downstairs. He dropped the handle of the vacuum and it hit CS midships but fortunately there was only one casualty. So now remaking a windlass. One side nearly finished, needs fine tuning and painting then the other side to cut out. Bit out of practice but getting there. Simon
I have been doing more studying than doing lately as I have been trying to get my head around the location of the brace end locations without much success. However, I think I have managed to work it out and while I have a few adjustments to make to correct initial errors, I have recommenced work on the Mizzen mast. Still have the lower top lift blocks to install on the mast and all the brace blocks. Then work out where the bunt, sheet and clew line blocks need to go via the mast down to the various pin rails. Oh, and I am running out of blocks again, do'h. Simon
Not a problem. I bought this set on Amazon. You will see it listed under lots of different manufacturers names but it's the same image every time. The drill bits are not hardened nor have they been ground to a point. So the wander when starting and have a tendency to bend, especially the smaller ones. However, the pun vice has a fairly decent size chuck. The end piece could do with having a bearing but considering how much I paid for this, I can't really complain. This shows the vice with one of the new bits installed. It is close to the limit but it does fit. I have used them a few times and finding that they do bully their way through a bit rather than drill a clean hole. Simon
I am please to report that they do fit in my pin vise which is a bonus. So I now have a micro drill and a pin vise that I can use whichever is best for the circumstances. Made just a little progress tonight sorting out the mount for the Mizzen lower top yard, no picture till I install the preventer and correct a couple of blocks. Simon
I have already been installing preventers but had missed the iron support on the lower top yard on Cutty on the other thread. Simon
