Trond
Members-
Everything posted by Trond
If they are suppose to be venting for the plant, it should be good enough with the two hatches and circulation. I would guess it would be a huge risk of getting sea water inside the ship if they are ventilation. Every time the ship have rough weather and the ship is "leaning over" due to sailing it is a big risk of getting water inside.
Finished the handrail and doing some testing if I'm going to use netting. Next is installing the support pillars for the handrail canons. The ones that was in the kit is terible. They are to big and wrong shape, so I had to make some new ones. I'm so glad I have the Bounty book. Here is the first test of the new pillars. They turned out nice, but a lot of work adjusting. Done 3 and 3 left.
Worked on hinghes, but easier done than said. Bout some 0.12mm brass plate where I cut out a stripps. Bended the stripp and soldered. Then I used CA to glue it to the wood and paint black. I painted it black since I don't know how to use chemical process to make brass blue/black. Does anybody know how to do that?
Couldn't give up that easy. So made a new more accurate jig. Also did some changes to how I cris crossed the thread. Still had the same problem of glueing tocrossing threads with a drop of CA. Ended up with using CA on the hole thing and it got stiff. Hear is it place loosly in place. I'm not sure and it was a lot of work. Need to do some thinking hear. 🤔
I loved you drawin michaelpsutton2 and I would agree that it wouldn't unreasenable to have that on the ship sides. So I tried making one, easier sead that done. Started good But the problem was glueing the treads. I stole some sewingmachine thread from my wife. The threads woulden glue with Medium CA+. So does anybody know what I did wrong??
Well tried a new way of setting up the handrail bars by drilling hole in the deck and shap the bars. Should have done that with the side wals instead of glueing them on top of the deck. I guess part of modeling is the journey from start to finish and what one learn during that trip. 😉 Must admit that I was unsert when drill the hole, scary of drilling so close to the side of the ship.
Until I have the time to travel to my local hobby shop to get plank I started planing/measuring out where to place the other handrailbars on each side, but it didn't add up. When I measured up on the ship and wrote the notes on the copies I've made from the Bounty book it was off a lot. After several control measurement I measered up the total lenght of the deck and compared it the Bount book drawings. Measurement from the shiped showed 53.5cm and drawings in book showed 57.6cm. So I will use the book as reference and place them out from drawings in book. Using hatches etc as reference and try to place them out.
Problem of start looking at your work and comparing,aspecially looking into the Bounty book. Just noticed that the wale or at least some thicker planks are wider that I did. and here is my version I've have just taped on a plank to see how it would look. From the look of it I need to planks. Any comment guys? Also looking at the color. From the picture on the book I should use a kind of dark navy blue on the side... Need to think on that one. In the mean time I will finish up the back rail side, not sure what the correct word for it
