Captain Shaun
About Captain Shaun
  • Birthday 01/16/1955
  • Gender
  • Location
    New London NH
  • Interests
    Maker things. Woodworker, welder, Model building, BBQ smoker cooking
673 profile views
  1. It was a common agent for fire extinguishers until banned. I was a volunteer firefighter for 30 yrs and worked as a propane tech. I always carried a few new ABC extinguishers on my truck and would convince many elderly homeowners to trade me the carbon tetrachloride ones for them. A common one I found were glass balls filled with it that were usually hanging in a holder near a fireplace. The holder had a two piece tab soldered together that would melt in a fire dropping the ball to the floor and (hopefully) put out the fire and maybe you as well since when heated to decomposition it will emit fumes of extremely toxic phosgene and hydrogen chloride.
  2. I have those same ones excellent quality. Cabinet scrapers like those work by filing the edge square and than forming a hook on the edge with a burnishing tool. Any hardened steel rod will work such as a drill bit or you can but tool made for that. It is not as hard as it sounds just find a YouTube video on it.
  3. As an alternative to sanding I prefer to use a scraper for removing excess filler. I use a single edge razor that I have filed the edge a bit to remove the sharpness. Excellent control and little chance of removing too much surrounding material.
  4. I use Famowood Filler. It is water based, dries fast and hard, sands nice and takes stain well. It comes in a bunch of wood types and the 6 oz cans will do a lot of filling. It is available on Amazon and many other online retailers, also available at Ace Hardware and Home Depot.
  5. Hi Bill. I use lead free solder most of the time. I do wear gloves and a respirator when using leaded solder, can't be too safe. Here's a link to a good reference article. https://www.qtsolder.com/what-is-lead-free-solder/ Shaun
  6. I use a Panavise Model 350 with a home made keel clamp. Panavise is not cheap but will last a lifetime and there are many variations available. Keel clamps are just two pieces of wood with nut, bolt and washers to tighten it. I put some scraps in the bottom of the clamp that match the keel thickness to avoid crushing keel.
  7. In Model Railroading we call them rivet counters. As in any hobby enjoy it at whatever level you like, some just like to watch toy trains go round and round in circles and some built museum quality dioramas that never move but both are happy.
  8. I know this is an old thread but I decided not to start a new one. I too have been using a Chopper II for Model Railroading for 20 years and never had a issue with the slight angle of the cuts that is caused by the fact that the razor blades are sharped on both side of the blade coming to a point in the center. I was cutting the short timberheads for my current build of BlueJacket's Bowdoin and decided the solution was a flush trim blade I was not able to locate any for sale and so I made one. I have a series of progressively finer grit diamond plates for sharping my woodworking tools and after grinding the blade edge off I ground in a new one on one side only. Voila! Square smooth cuts. There is a caveat in that I need to cut them a bit long and do a second cut too get the square edge. Works much better than the razor saw/miter box combo. This is the blade I made, Front side is beveled and back side is flat. You can see the difference in the cuts below. Sorry for the bad focus, my camera is out of sorts and my phone camera is not so great.
  9. Thread snips used by seamstresses and quilters work very well. I use my wife's pictured below with the finger loop which allows you too keep them in hand for instant use. As with most tools you get what you pay for.
  10. One advantage is the dark color makes for good looking seams on hand laid decking. 🙂
  11. Titebond has a ready to use out of the container Hide glue. Hide glue has a longer open (set) time and gives you more time for larger glue ups. It also is reversible with heat in case you need to fix it. You need to pay attention to shelf life so I buy small bottles. it dries dark so be aware of that.
  12. Just picked up this Bridge City Toolworks HP-8 (lower one), it comes with adjustable side plates that allow you to use it as a thickness planer for small stock. Upper plane is my old tried and true Lie Nielson low angle block plane that I adore.
  13. Agreed. Manual shows on page 13 that they are for table alignment. If I only owned one power tool it would be a bandsaw.
  14. Welcome Aboard Rod, I too spent some years in SoCal. Drove a cab in LA, lived in Venice and moved to Catalina Island where I had the job of captaining a 1944 LCM 3 with a recycled Budweiser delivery truck on a daily freight run to San Pedro. Loved that weather but love it here in New Hampshire. Your copper work is looking very nice.
  15. "I know they are not perfect, but they are my children and I love them" That's why I build them. Mateusz, witamy w rodzinie , Shaun
