Everything posted by Patrick Matthews
	Thanks. It's actually my understanding that joggling/nibbling has everything to do with allowing a trunnel to be placed near the end of the plank without risk of splitting a narrow end. BTW, for both Decker (an all wood tug) and Brooklyn (a steel tug with a wood deck), the deck planks are laid over beams, with no subdeck. Decker will be fastened with trunnels, and Brooklyn will have counterbored and plugged holes, with bolts fastening the planks to the beams' flanges.
	And why no joggling here? My guess is that the steep angle of approach means the cut plank ends aren't "too" pointy, therefore joggling isn't needed to allow for secure attachment close to the end. A more slender yacht will have a shallower approach & sharper ends, so joggling is called for. I think I've seen a rule-of-thumb for this... anyone have that handy?
	I'm attempting to do a more-correct version of the Dumas Brooklyn tug, and am stuck on the deck. Brooklyn (designed 1910) had a steel hull and steel deck beams, but an all-wood deck. The kit would have us scribe plywood sheet with a straight fore-aft planking pattern. Doesn't seem right. Brooklyn's deck house sides "parallel" the deck edge in plan view, and the one cross section view we have from the original plans show 3x3 pine deck planks between the waterways. (Is the beveled plank adjacent to the deck house also a "waterway"?). Anyway, this suggests that the planking would follow the deck edge curvature over the fore & after decks, which leads to joggling at a central king plank. But I have found no plan or photographic evidence that this was done on tugs of this era. Anyone have better info before I go and joggle a whole bunch of planks in vain?
				Atlantis by Thistle17 - FINISHED - Robbe
Patrick Matthews replied to Thistle17's topic in RC Kits & Scratch building
Sorry I missed your post! Email or PM will get my attention faster. Let me know if help is still needed. -
	Very nice & complete work! Yes, my goal is to document vessels in a manner useful for modelers. I'm not creating 3d printable files. But my documentation includes 2d drawings as well as a 3d CAD model. The cad model can be used directly, or examined to better understand my abbreviated 2d work I do like the DS lines drawings, and that's another area that F360 erects unnecessary roadblocks... But I'm finding ways to work around those too. See my Fire Fighter model for example: https://grabcad.com/library/fire-fighter-fireboat-1
	Nope on the 3D DXF. That results in a mesh not unlike an STL- points joined by straight connectors, resulting in a faceted surface. It is NOT a smooth curvy surface. The IGES export is smooth & curvy... I just don't know if the entire side of my hull with its compound curved surfaces comes out in one patch or not. Why do this? Because while Fusion 360 can be a pain for creating lofted hulls, it's a champ for making all the other details. And it has history, which is priceless in large complex models. So if I can make a correct hull in DS, I'd just export the shape to F360. But as I detail above, that subdivided surface from DS using a control mesh is WRONG, and it requires a lot of tweaking to correct. Now, with much gnashing of teeth, I have been able to create a reasonable lofted hull in F360... so it's just a matter of which path is less headache. My F360 generated hull:
	Thanks! My biggest question regards the IGES output, only available in the Pro version. They told me it can output many, maybe hundreds, of surface patches, which would likely look like a mosaic when used in other CAD software. But if, for example on my tug hull, it comes out as smooth single patch for the main surface, that would be fine. They sent me a sample IGES file, but it was of a simple developable hull, so not really a test of this feature. The transom (port) was fractured, but I stitched the surface patches in Fusion360, and it all merged nicely (stbd).
	Here's an end view showing some of these features: White: Original control points and the control mesh with its straight Tinkertoy connectors. The control points lay on the proper body sections from the lines drawing. Green: Body sections cut through the DS developed hull surface... they miss by a lot. Even at the deck edges. Pink: Nice curvy marker curves that DS draws for the second import of the original control points. These markers are the target, I need to move the green lines to match them. To move any one point: Click on it, and you can enter new numbers or use the little arrow to move the point by set increments, very handy. Move each and every one this way to drag the developed sections around.
	So here's the second most important thing for DS users to know: Lines imported from a lines drawing DO NOT create a hull true to those lines! First most important? It can be fixed. As above: "The developed hull shape does NOT go through the control points, which are input from the original lines drawing... they just INFLUENCE the shape. Fine except it's not, because the developed form no longer matches the original. There must be a work flow that gets the generated shape closer to the desired form." Indeed the DS developed hull cuts corners, it's always well to the inside (concave side) of input curves, except at the "corners". Imagine you have a magnetic rubbery sheet pegged by its 4 corners to the floor, exactly where you want the corners. Then you hang a bunch of magnets from the ceiling, and each magnet is hanging exactly where you want the sheet to stretch and rise to, defining some sort of hill (I'm picturing Richard Dreyfuss building Devil's Tower in his living room). But while the sheet is stretchy, it's not THAT stretchy, and it hovers over the floor but doesn't quite reach the magnets. Oops. That's what we have in DS, with the developed hull not reaching the input points. How to fix it? Just keep raising the magnets until the sheet rises to the proper place. In DS, I did this, though there may be more efficient ways: 1. Import the control points once to define the control mesh and its resultant malformed hull. 2. Import the control points a second time as "marker curves". Markers are static curves, immutable, and they serve as references of where the original control points and desired hull sections are. 3. In an end view, compare the developed body sections (which are wrong) to the desired shape shown by the marker curves. Now start moving control points sideways or vertically to slowly pull the body sections towards their markers. Yes, this modifies the original control points and mesh! 4. Note that this is iterative... moving one point affects the adjacent surface faces, so you'll need to sweep back and forth over all the points to get everything close. 5. Also note that the four edges of your rubber sheet between the corner pegs were also pulled off the floor when the magnets started lifting the center. Same thing in DS- the edges at deck edge and keel also have moved out of place. So the adjusting exercise needs to address those too. I did this for my tugboat hull, and while it still needs some adjustment, it's much closer to the desired shape now (below). More: While you can get close by doing this, you can also turn on curvature displays to better smooth (fair) your new shapes. I haven't done this yet, may not need to for my present purposes. More #2: The Pro version of DS has an "automatic fairing" tool. I'm not sure how this works, but it could be of help.
	I did receive replies from DS HQ: 1. The forum is not broken, new posts are moderated. But still, not so much recent activity, which is curious. 2. Hull surfaces exported as IGES are "smooth parametric surfaces, but please keep in mind that the exported hull can consist of many (sometimes hundreds) of such surfaces." So it's not clear yet whether that would look like a broken mosaic when imported into my CAD.
	Thanks and yes, but a lot of material is a bit dated. I don't see much recent activity, makes me wonder if this is still a popular tool? I sent an email to DS HQ asking why their forum is broken... no answer yet. But I'm wrestling with topics like: - The developed hull shape does NOT go through the control points, which are input from the original lines drawing... they just INFLUENCE the shape. Fine except it's not, because the developed form no longer matches the original. There must be a work flow that gets the generated shape closer to the desired form; - Deck camber- the "Extrude Curved" tool is supposed to generate a nicely cambered deck, except it doesn't... it's generating garbage for me; - You can pop 160 euro for the Pro version which will output the surfaces in IGES format. But what format? A faceted mesh, or a proper smooth surface? The available exports in the free version just give the faceted mesh, which looks terrible when imported into, say, Fusion360 (as seen below). Unusable. The whole reason for me exploring Delftship is its better ability to generate hull shapes, compared to the buggy tools in F360, whadda headache (that area around the sternpost/stern counter is a BEAR to loft). Maybe I should pop for Rhino, $995 ouch.
				Fire Fighter
Patrick Matthews replied to Patrick Matthews's topic in CAD and 3D Modelling/Drafting Plans with Software
Or instead of spending hundreds of hours drawing it, spend a few bucks to get them properly scanned and then post them somewhere for posterity. It's a shame how many drawings are out there that will never get shared... -
				Fire Fighter
You keep saying that! 😆 -
	Years ago I attempted to correct the Revell Fire Fighter kit with a load of 3d printed parts. Now I've finally completed a CAD model of FF, and posted it and a bunch of supporting info on GrabCAD for free download. No printable parts in the file, but I've created a correct shape for the hull and house, and show where all the "ornaments" are hung: https://grabcad.com/library/fire-fighter-fireboat-1 You can spin the model around using GrabCAD's 3d viewer.
				USLSS 36'Lifeboat
The 3D CAD model is complete and available for free download from GrabCAD: https://grabcad.com/library/lifeboat-uslss-1908-mclellen-type-e-36-footer-1 Find the 3D STEP file there, along with reference photos and the original 2D drawings I worked from. Take the model for a spin at GrabCAD! -
	Another update- the entire PILAR 3D model is now on GrabCAD, along with 2D drawings for the cabin structure. I may be adding more 2D detail drawings, but the underlying geometry is all there now in the 3D STEP file. Take the 3D model for a spin at GrabCAD! https://grabcad.com/library/pilar-model-in-1-12-scale-1
	I'm often asked about drawings for my 1:12 scale model of Pilar (Hemingway's boat), and I always reply with my sob story: a) I lost the files when I retired and lost access to my work CAD system (true), and b) it's as much work to create shareable drawings as it is to build the physical model (true). But now I am recovering the CAD model from digital debris I have laying around, and am preparing shareable model files. The first part, the hull framing, is now posted for free download at my GrabCAD page: https://grabcad.com/library/pilar-model-in-1-12-scale-1 The 3D STEP file is there, as well as full (model) size 2D drawings in PDF format. Those print out on ANSI "E" sheets, you need 36" wide paper for that. The images here are reduced! Use the downloadable PDFs instead. Cabin and additional fittings will follow in good time. The JPGs below are reduced, get the full size PDFs at the GrabCAD page.
	One of the highest achievements of research is the publication of your work. I've often been too lazy to share designs-- it seems to take as much work to put one's research into shareable format as it does to build a physical model! But I'm trying to rectify that. I often use CAD to help work out designs and to support the building activity, but I'm also finding it just as rewarding to simply make a CAD model and share that... and the CAD model is much easier to keep the dust off of. I'm posting my CAD models for free download at GrabCAD. Other sites are available, but this works for me: https://grabcad.com/patrick.matthews-1 You can go into each model posting to find additional materials, such as photos, documents, and original drawings, as well as the CAD model itself. The site has a 3D viewer that allows you spin the model around for preview, nice. So far, I have posted: - 1909 San Francisco fireboat - 1945 ATSF RR tugboat - 1908 USLSS lifeboat And now I'm going back and reassembling a mess of a CAD model for my interpretation of "Pilar".
				USLSS 36'Lifeboat
Continuing to add details, including the material appearances which allows for some nice renderings. Much more to do! For example, the couple score of copper air chambers for flotation. By the way, that's not a steering wheel on the aft bulkhead- it operates the reversing mechanism, which normally would just be a lever if you were standing next to the engine. The single crank is for starting the engine, while the T-handle crank is the primary steering tool. The galvanized air tank below the aft bulkhead gets compressed gas directly from the engine cylinder, and is used to operate the whistle seen on that aft bulkhead. The main fuel tank is the copper object below the forward bulkhead. Gunmetal plates riveted through and through the keel members at both ends are used for hauling the boat up the ways.
