chris watton
Everything posted by chris watton
  1. Thank you! I am working on construction drawings right now, so am hoping it will be released within 8 months. I am working on a few different versions thought (for different markets), which is slowing me down....
  2. Cheers The sail is, apparently, the correct size - I had to rely on experts much more knowledgeable than me on this particular subject, they pointed out to me the two triangular 'supparum' sails above the main yard, too.
  3. Cheers I didn't like the all painted hull, and couldn't sleep well until I changed it! The oars don't take too long to make at all - you just cut the dowel to length and simply glue on the laser cut paddle on the end! I can see now why most other commercial kits only show one bank of oars... I think I will have to design a base that's wide enough for the oars, as they will ne quite delicate...
  4. I have quite a few changes to the original model, including re-planking the sides, adding the anti ramming plates and ballistas. I ran out of dowel for the oars, only had enough to make a third of them!
  5. Thank you! I can confirm that this will be an Amati kit, and they want it released as soon as I have finished!
  6. The plans I used were actually drawn years ago and were purchased from the NMM, so I didn't take the lines off the model myself. All you do get is hull lines (including bulkheads) - but for the new designs I did, there weren't enough bulkhead lines in the plans, so I had to add a few myself. The plans were 48th scale, and trust me, the model would be way too big for this scale. At 64th, I find it a perfect size, although perhaps a little too large for some modellers - the hull is a lot larger than say, the Vanguard kit and only smaller than the 64th scale Victory (about the same depth/height, but obviously a little narrower and shorter, with Prince being 100 years older). I don't think the original Prince would have been substantially smaller than Royal William - but also you have to treat with caution the stated scales on older Italian kits - the original Amati Prince was stated as 78th scale, but my new designs have the length almost the same at 64th as the stated 78th scale original (although there's so much wrong with the original it shouldn't even be called Prince - hull shape and profiles are very different). I am sure the Italians used to use 'ballpark figures' for scales...
  7. I actually started off by buying and using the plans from the full size Greek trireme. However, after buying more resource material, I quickly realised that if I were to follow the trireme plans, I would be designing a ship that would be the equivalent of using a set of medieval cog plans as the basis to build a late 18th Century ship of the line! There is almost 500 years difference in age. The more I read, the more I realised just how much these vessels changed, much of it via battle experience. The Quinqueremes at the beginning of the 1st Century AD were the equivalents of the ship of the line, and quite large and built for both offensive and defensive duties (although with the Romans, usually offensive...) - but once Rome conquered the Mediterranean, such large vessels became obsolete (as there were no more real enemies to fight) and only smaller vessels were usually built. I thought it would be good to try and design this type as it represents a Roman warship at its absolute prime, and wouldn't have looked out of place at the battle of Actium.
  8. Thank you! I only design them that way because I want an easy ride, too, when I have to build the prototypes!
  9. The drawings are not mine to fully publish. Amati own them as they paid me for the designs. It would be very unprofessional and reckless in the extreme to publish them without the permission of the owners - and there would be nothing to stop unscrupulous people copying them and then calling them their own.
  10. Cheers I added another pic. All of the curved parts are laser cut - I wouldn't like to try and bend planks to such a curve, and I certainly wouldn't think other modellers would, too - so the front and back is very easy to assemble, as is the main hull sides with the outriggers and oar ports - all pre cut. All of the panels are, too (including the inner and outer bulwarks), so no need to cut and glue lots of thin strip.. The only skills involved are very basic, planking the lower hull with lime strips and then going over the rest with 1x5mm walnut strips - you don't have to paint it, but if you're crap at planking like me, it looks better painted.... I have added a boarding platform at the front, as the cumbersome 'corvus' was used only for a very short length of time during the first Punic wars - where it was found that the centre of gravity was heavily compromised and many ships were lost because of this - it seems a more sensible 'boarding-bridge' was used, instead.
  11. I will ask Amati when I can 'slot' this one in (have got three developments on the go right now..) - it is frustrating for me, as it happens to be my all time favourite ship - I love the lines and curves, and it's not half as 'gaudy' as SOTS - and it has a great history. Just checked my design files - I re did them in 2011, to more or less the same designs as Victory and Bellona, with lower, middle and upper gun decks - and gun port positions that slot into the bulkheads, rather than the old and flawed ply gun port patterns.
  12. Hi Nigel, I actually used the lines taken directly off the original dockyard model - I think these are about as accurate as we're going to get for the Prince. I then used all of the Van De Velde drawings that exist for most of the outer detail and parts which conflicted slightly with the original model (which was probably made before the actual vessel was launched, by which time a few changes were probably made - like the small protruding gallery at the stern) I re designed from the original about 10 years ago, and that is what the model above is based - but a couple of years ago, I re designed it again to take into account newer techniques I use now - I am just waiting for these new designs to be cut for me.
  13. A new version of the Amati Prince will be released one day... Just need Amati to cut my new designs.....
  14. Right, these have just taken ages to type in, as I can't cut and paste.... Latest pics of progress, all the deck stuff is dry fitted and needs more work before gluing in place....
  15. I don't see why not. Just email them. (I haven't got any, being almost 1000 miles away and in another country..)
  16. Thanks, guys Yes, the Vanguard kit could be modified for Bellona, they are both virtually identical in shape and size - the only real differences being superficial, and therefore easily changed. I thought all of the cast stern decoration for Vanguard, Bellerophon and Elephant were now changed to resin! @Fam - very interesting post, thank you ETA - just tried linking some pics of Roman galley, but still won't let me, and I haven't time to type in the whole address manually...
  17. I wouldn't mind doing a Roman merchant vessel in the future, as they seem to be a more conventional hull form.
  18. It is fun and quite rewarding, as you learn a lot more than normal. I think that every model you see from this era is based on 'guess work', but it is educated guess work by interpreting the sources used. Hell, no one really knows and debate still rages about what the Mary Rose really looked like at the time of her capsizing, and that's over a millennium and a half after the Roman Quinquireme - we even have to make educated guesses for some of the decoration used on ships from only 2 centuries ago! So for the Roman ship, I had to rely solely on experts' interpretation of the sources regarding the vessels' likely appearance, taking into account the era, the armament carried, length/breadth rations, rowers and oar configurations - and of course, we still have Roman art and iconography that show these vessels. I could of course just have copied the lines from other kits and 'beef up' the designs, but that's not really what I do - at least doing my own research, I am unlikely to copy (possible) mistakes made by others. I have always preferred to start completely from scratch using my own methods and am not at all interested in how other's do it - and I hope this shows with the stuff I do.
  19. I can't really say too much about this particular development at this stage, but I don't think it's going to replace the Greek warship - this new one is much later, about 4-450 years later and much larger. (180 oars in all) and designed for both long and short range warfare, with a plethora of PE decoration in keeping with its capital ship status. The existing 1:1 trireme plans weren't much use, to be honest, not after researching the differences, so I started completely from scratch, which is a first for me - having to make my own line drawings before even starting the designs.
  20. Lots and lots of research, buying many (expensive) books on the subject and then essentially starting from scratch, based on the research I did. There are no line drawings for this type of vessel so I had to make up my own before even starting the designs. (based on dimensions/length to width ratios etc.). I did secure a full set of plans from the Trireme Trust, but to be honest, they were next to useless for the type of vessel I had in mind - a late Republic capital ship that perhaps Agrippa would recognise.
  21. Cheers TBH, Most of my work has still been on Victory, with the Roman ship on evenings and weekends, to try and not slow anything down.
  22. Can't really say at this point, but I can say there's a lot of pre cut parts, eliminating any need to pull one's hair out...
