Auger
Everything posted by Auger
  1. Apparently the support beam for the side railings there closest to the paddle wheel sagged, causing the top side railing to warp, or straighten up a bit. Maybe the garage workshop got too hot this summer.
  2. Superbe build! I’ve been eyeballing this kit for some time, I believe you’ve nudged me into the purchase. 😉
  3. I like Occre. But agree.
  4. Just curious as to how many of you have had something move with time passage. I’m referring to our models in regards to the building processes used; lessons learned. Here’s my latest: Support beam fatigue. I had installed it with a support treenail but the part still fell-out causing the rails to warp. Maybe the drill hole was a bit too large, or the treenail bent with glue moisture? Too thin of a diameter? I don’t know. But like I said in my build log, we’ll just chalk it up to navigational error. I fear trying to force things back into place will only make matters worse. So, I’ve resigned to just reinforcing the fallen beam with some epoxy in the right places. I try to take into account the extreme temperature differentials within my garage workroom when building through the seasons, but sometimes I get stung. This took place over the course of a year or so. Maybe the top rail had too much tension after drying, unseen builders error? Maybe I could have bent the rail a bit more, but it laid in well when building and I don’t force things. If I have to force it, it isn’t ready to go yet, or I need to do it over. Anyway, I’m keen to see what you all have experienced. Wood moves in permanence, we all know. I have a superb oak table in my salon which never ceases to amaze me at how much it’s planks move.
  5. Well, we’ll just call it a navigational error. Not really sure what happened here, something obviously moved. For the time being everything is solid so, it is what it is. Looks like that support beam closest to the paddle wheel fell-out a bit. I’m just going to reinforce it because I fear forcing things will just put myself into a worse situation. Anyone else ever have something move after time passage?
  6. Gettin’ jiggy with it. Already presented this jig but sometimes something super simple helps enormously. By the way, this is one of the laser cut parts I had to rework.
  7. Thanks for the kind words, Bob and Cleat. I think one thing I’ve taken away from this build is that the directions will lead you astray if you follow the book down to the part. Skip the rail beams and once the second deck rooms have been installed, start looking ahead and thinking about the third deck, stairways, masts, steam stacks and rigging locations. I made the mistake of installing the first deck railing support beams by using the side-view plans because the book showed them being installed, and then worked them bottom-up. But now all of my support beams are a bit off which is causing me to have to get creative with the laser cut railings. I should have waited until the third deck was laid before adding any rail support beams and then moving from the top-down using the deck plan for their placements. And even then, build everything from the inside out before adding them or else the rails will block certain operations like filing out some of the pre-cut holes in the deck or passing rigging. In hindsight, I should have done them last. Oh, well. Next time…
  8. Been a while but still here. Life takes up a lot of time. with that said, I got some work done on the starboard railings.
  9. Totally do what you’ve set out to do. If you don’t like the hub in the end, just take it off!
  10. I think they shorted me the step material as well and gave me an over abundance of light veneer for the bulkheads, so I’ve been using the veneer for the steps. Doesn’t look so bad.
  11. Building ladders. For some reason not my favourite task. Again, some sanding to do…
  12. For those who read this log, install the ladder stairs between the 2nd and 3rd decks before beginning the railings. Work the model from the inside-out.
  13. Thank you very much. For the white railings I used my model rocket fin approach. I use epoxy on either bottom-end of the rails (tiny bit added with a toothpick) then a dab of CA to the bottom center. I place the white rail onto the wood support below with tweezers then hold it with my finger for about 15 seconds or so till the CA holds the railing in place, at the angle I want. When the epoxy sets, they’re quite strong. Just need to go back and sand a little to knock down the epoxy shine. Works well. For the first deck wood railings, you are correct, I used trenails. I did so for added strength because when I manipulate the model I don’t have to worry about popping one of the rails off. They’re way stronger with the trenails.
