Kelp
Posts posted by Kelp
Hello Joe.
Nice job working on this model! I really like how you painted the gold. What is your technique for painting the gold (what size brush, method, etc.)?
Don
Hello Art,
On the kit hull, there appear to be nine portholes between the bottom two full hull length rows of portholes. Are these in fact portholes, or something else? I don't see them on the TRMA sidelight diagram on your build site and can 't see them on photos. I was just wondering if I should drill them out
Thanks,
Don
Hi Allan,
The Danmark is looking great! I look forward to seeing the progress of this model project. With the bowsprit attached, how long is the model?
Don
I need to cut some small brass strips and was wondering if exacto saw blades are used for cutting metal, or wood only? I also have wire cutters I could use. Any other suggestions?
Thanks,
Don
Hello,
I plan on doing a scratch-build of the Eagle some day in the future and am in the research, information gathering stage. Would anyone here happen to know the type of lifeboat that is being used on the Eagle?
Thanks,
Don
Hello,
Thanks,
Don
Nice job painting the stern!
Don
I am marking the locations of the planks for my second planking layer. The midship length gives me a total of 25 planks needed. According to literature, it seems that I'm supposed to divide the total length of each bulkhead by 25 at each bulkhead to get the width needed for the planks at that bulkhead, For instance, a full 7 mm plank width at midship and then tapering in width to bulkhead #1 near the bow. As you can see on the photo, the garboard strake (plank #25) does not naturally seem to reach bulkhead 1. The curve would appear too sharp and unnatural. I'm not sure if I'm measuring the plank widths for bulkhead 1 correctly. Should I have another measuring line at the end of the garboard strake and divde by twenty four along that lline?Any suggestions?Thank you,Don B.
Jaager and Black Viking,
Thank you for your comments. I agree that the three butt shift looks better than a four butt shift , and to me, it looks much better than a two butt shift. Unless I find out that a three shift is definately wrong, that's what I'll use.
Don
Hi Dan,
You got yourself a great deal on the kit! I'll be watching with interest, as I also have this kit in my closet for a future project. As for the keel, I'd probably buy a piece of plywood and cut a new piece, that way it would be good and flat. It might be quite difficult to straighten out the piece you have now. Be careful when cutting the slots on the new piece for the bulkheads because you don't want them to have too much play. The bulkheads should fit snug.
Best of luck with the build,
Don
Hi Tom,
Do you know when the restoration on the Constitution is scheduled to be completed? I remember in 1997 there was a major restoration. Is this the same type of work being done?
Your model is looking fantastic!
Thanks,
Don
Excellent commentary on your progress. I like how you are describing every step as it will make life easier for future Constitution builders. Best of luck on the build! If you have questions along the way, quite a few modelers here have built the same kit and will be glad to help out. Great start!
Don
Stick with the rigging! You're doing a fine job and it would be a shame to give up now. Just do a little rigging at a time and before you know it, you'll have it completed. Nice work. I love the deck paint job-looks like real wood.
Don
- EJ_L and popeye the sailor
- 2
Hello,
I'm building the Heller Royal Louis and can't make out what color is supposed to be used for the gun carriages. What would be a typical color for gun carriages for French ships of this time period (1700's)? I've seen some photos with the carriages red, the same as the interior bulwarks.
Thank you,
Don
Coppering a hull on a plastic kit?
in Building, Framing, Planking and plating a ships hull and deck
Has anyone tried using the adhesive copper tape on plastic kits? How were the results? I was thinking of trying it out on my 1/96 Revell Cutty Sark sometime in the future.
Thanks,
Don
