Some Idea
Everything posted by Some Idea
  1. Fantastic website Chris - easy to navigate and the ships look amazing. I don't know how you make such lovely models for the price - they are a bargain for the result that builders get!
  2. Another update from me - I've now closed off the stern and finished the stern windows. There's not too much to say about this work other than the planking is not straight but curved. I tried bending planks but pretty much got no where with that so in the end I made them from a 13mm wide plank by sanding them to shape. The hinges and closers are blackened brass. I still need to place the nails on the external planks but thats a nice easy job. I think I'm going to make the quarterdeck beams, supports and waterways next. Mark
  3. Fantastic work! When I had a go at Samson posts I thought about using a mill. But actually I found them really nice to make just using a chisel. Maybe I'll try a mill next time as your results are lovely.
  4. The last plank I have found takes the longest to trim but is the easiest to fit. The very last plank I always trim to be an interference fit so that it is tight to get in place. This just takes time and patience and because it's a tight fit I usually use a very small hammer with plastic ends to get it into place. I've never used clamps on the last plank
  5. This is a fantastic observation and you are absolutely correct. Thinking back I used narrower planks on my first planking compared to the second layer. That way the overlap of any seams was minimal 👍
  6. Hi Ian this could easily be made from hardwood and the hole made using a hole cutter. Good luck with your project 👍
  7. Hi John Yea I did exactly that when I made my last model - Its great practice but also time consuming. Its also much easier to line off the second layer as you have the correct rounded shape of the hull without having to deal with bulkheads - good luck Mark
  8. In that case you can put the first layer of planks on just as the picture above shows. This layer will help you get the shape of the hull probably with a bit of filler too. You will only need to line off your second layer of planking as this will obviously be seen.
  9. Hi Ian - Thats a really good question and one that I had thought about too. I was going to use a fly cutter which is perfectly feasible but as I machine in my home I didn't want too much swarf. I cut the hole by using a rotary table with a 4 jaw chuck so the centre came out in one piece. I used a 3mm 2 flute end mill to do this. The wires run directly through the mill head - here's a better picture @Dr PR many thanks for the explanation that makes sense to me now 👍
  10. Hi John is your model double planked or single planked? Also is the hull going to be painted?
  11. Hi Paul - you know what a yellow filter may just calm down the stark colour of white so thanks for that as it's something I may try. As for pulse width modulation - mate is this a name of a new band? Only joking - I'm a bit old now and I don't understand electrics at all. In fact my wiring is probably questionable at best but I do think that people that understand this aspect could easily move this forward as you suggest. In fact if they do let me know in very very simple terms how to do this. I just run the light off of a 12v plug in charging transformer.
  12. Hi JohnWW this is what lining off looks like It's about the planning of the planking strakes (runs) so that you know how every single plank will fit. It will give you the dimensions of each strake too. Some more pictures to help you You can use tape, string, cotton or anything that will follow the lines. Now this may seem like an awful lot of planning and yes it takes a lot of time to get this right - however - if you can draw the strakes you can make them! If you line off your hull it takes all of the guess work out of planking and you have pretty much won the battle before even cutting your first piece of wood. Read the tutorials on here as they will help you through the process. Good luck! Mark
  13. Hi Mark - yep you are spot on they are sold as car accessories. I got two of these lights for £10 delivered You are right about the cold white light. It would also be good if they could be dimmed a little too.
  14. Hi All I know that a few builders on here use a Sherline mill as do I. I have found that my eyesight needs more light as I get older so I have wanted for a while to make a decent ring light for my mill. I found some cheap 60mm ring lights that run on 12/24v that seemed to be about the right size. Unfortunately it couldn't be directly attached to the mill head as it would remove any access to the Tommy bar spindle hole. So a carrier was required and I bashed this up out of 10mm aluminium. The slot allows the wiring to travel up through the mill head which is already there. It keeps the look of it wiring free I milled a small slot each side to allow for the Tommy bar to reach the spindle Its held in place with double sided tape And the wiring is encased in polyester braiding to try and make it look as though it has always been there The results are really good I hope this helps someone or gives a bit of inspiration to make the lighting on your mill a bit better - Anyway I can now get back to ship building instead of filling my workshop with aluminium swarf!! Mark
  15. Love the details on the beams - the dovetails are perfect.
  16. I too have had some very disappointing days during my build and things can get disheartening. Take a few days and it always seems better. I think your build was coming along beautifully. I hope you do get to finish this ship 👍
  17. Keep going mate you’re doing a great job these timbers are particularly difficult to make. 👍👍
  18. That looks great 👍 The transition is very smooth and much better than the step that I arrived at - top job
  19. Very well found my friend - I’m going to leave mine as it is as breaking those shiplap planks out would destroy them all. At least your ship will be spot on 👍
  20. Hi Tobias - I think that you are right and I completely missed that! I have just had a look at Adrians book and he has missed this point as well. It will be interesting to see what Gerard says but either way I think that using these planks to help the transition would look very nice.
  21. Albert your work is truly inspirational - Its not just that - its the way you have your workshop and how you approach your work - fantastic
  22. I've been trying to figure out how best to make the windows as they are a parallelogram in shape but also all of the parts are angled to suit the angle of the stern. I tried a few mock ups using separate parts but they really did not go well at all. So I thought that the best way was to try and mill them out of a single piece. So I marked them up to roughly match the drawing Then I set the required angle and using a 1mm mill bit I cut the windows out. The result actually isn't too bad - sorry about the poor quality pictures and I just balanced it into the ship to give a rough idea of how it looked. One down although it needs tiding up and one to go. I can then complete the window frames and plank the inside to tidy it all up. Mark
  23. So moving forward I have now fitted the stern timbers and generally tidied the stern up. I'm really pleased with the way it looks and I think it's fairly symmetrical too. But as with everything it seems with ship building, I soon discovered that the very rear beam that I fitted maybe 2 years ago is 2mm too low. It's not a problem but it will need a filler piece on the top fitted at some point. I also found that my location of the counter timbers was not as good as it could have been as the windows did not exactly line up with them. Again it's not a problem but I do have to make some extra pieces to hide these errors. The stern windows were my next task - The drawings more hint at their design rather than give a detailed instruction. As such I did what I always do and contacted Gerard Delacroix and asked his opinion. He advised me that their parallelogram shape on the outside followed through to the inside windows. He also went above and beyond and sent me a drawing of how they should look - cheers mate 👍 So to keep the shape I made a couple of false windows to set the window frames. I really want this part of the ship to look correct hence all of the questions and effort. Below you can see the false window in place whist the frame sets. The cheeks of the window frames also require some extra timber but thats ok and I'll sort that out too. I have decided to have them closed but I'm going to make them as best I can anyway. Here's a picture of both windows with the top and bottom parts of the frames in place. So the next jobs are to complete the window cheeks and work out how to make the windows so that they look as near to the drawings as I can. Thanks all for the very nice comments - Mark
  24. Such nice work 👍. If you want to see if you are filing the surfaces flat - just get a pencil and scribble all over the surface. Then file again and see if the marks are removed. This worked for me - keep the updates coming!
