Everything posted by Some Idea
Thanks Tony A bit more work done this week - I have made the 2 beds. One is for the Master of the ship and the other for the Master Gunner who was on board when Le Rochefort carried its cargo of gunpowder. I made the recesses in the door and the lower part of the bed in the same way I made the door into the cabin. I just like the way this method looks when finished. Next was the cupboard walls and the base of the bed The pair of beds and the bulkhead with hinges and handles fitted. The parts now fitted into the hull - it's the fitting that takes the longest time just trying to get a tight a fit to the hull as possible. So I'm pretty sure that once I've made the hatch surround, fitted the beams and made the carlings that will be the quarter deck finished. Those tasks will be my next jobs. Cheers Mark
HMS ANSON 1781 by albert - 1/48 - 64 guns
Some Idea replied to albert's topic in - Build logs for subjects built 1751 - 1800
So many frames in such perfect alignment - wow -
Thanks JacquesCousteau - The shiplap planks are really simple to make on a table saw but I find them difficult to glue together so that they lay flat. I have to be honest the whole assembly did fit better than I thought it would and yea - I did look at it and think you lucky fella that looks nice 🤣 Sorry for the late replies - I'm now starting on the 2 beds which for this ship are quite elaborate in detail and I need to work out how to make them.
Hi all Back from our lovely holiday and straight back onto Le Rochefort I'm now working on the crews quarters below the quarter deck and have started with the bulkhead which has a double entry door. This is quite a feature on this ship so I want to get it as good as possible. I started by making the shiplap planks that form the walls which I then glued together to make the actual walls. Next was to look at the doors themselves - I usually just get a solid piece of wood and then mill out the features to make them look like doors. In this instance I thought that I would try a new exercise for me and make them from individual parts and include all of the relevant joints as they possibly would have been made originally. Each frame is made of 5 pieces which then require 4 inserts in each door. Milling out the rebates to fit the 0.7mm inserts Sorry I should have taken more pictures but here are how the doors turned out. Assembling the parts actually proved to be one of the hardest parts. Next I needed to make the door frame uprights which have 2 rebates cut into them and also the base rebate that the walls slot into. It all took a little bit of fettling to get all of the parts to fit correctly but I'm just about there now. I did have one issue and that was with the door frame uprights which stopped the whole assembly from sitting flush with the beam. This maybe because I miss read the drawings but to get around this issue I cut some rebates into the beam which actually makes the whole thing stronger and more stable It's all still a work in progress but I'm getting there with this particular part of the build. Mark
Gold solder for brass
Some Idea replied to Richard Braithwaite's topic in Metal Work, Soldering and Metal Fittings
Silver solder on brass really needs tight joints to get a good joint. By the time it's been filed or sanded down it's almost invisible anyway. Jewellers use silver solder on gold and you cannot see the joint so I guess the secret is to take your time and have as little silver filler in the joint as possible -
L'Amarante by marsalv - 1:36 - POF
Some Idea replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Simply amazing work - wow -
druxey, dvm27 and SaltyScot - thanks for the comments! It's nice to know that it's not just me that has had to resolve earlier issues. After I built the quarter deck I was surprised just how much it changes the entire look of the ship. It just looks so much more complete and solid which was just another piece of encouragement to move forward. Mark
Thanks Jacques that really means a lot to me - Since starting Le Rochefort I have bought a few monographs which has made me appreciate just how good the monograph by Gerard really is. I also have to remember that this is my first POF build too! My shipyard is obviously on the sketchy side 🤣 but we get things done! Thanks Chris - We fly out next Sunday for a much needed 2 week holiday in the sun.
Hi All I've not posted in a while as I found an issue with my build that began 3 1/2 years ago when my building skills and general ship understanding were very much in their infancy I guess. I first noticed this problem when I fitted the stern timbers and stern windows. I could see that the counter timbers did not go fully to the top of the stern timbers and the quarter deck rear beam seemed far too close to the top of the windows. The issue is - I have set the counter timbers at the wrong angle which to correct at this stage would be very difficult indeed. I felt that this would be the end of the build as I have tried my very best to keep as accurately to the plans as possible. I decided just to have a break and come back to it later with a fresh outlook and see how I felt about the problem. So with a renewed outlook I took loads of measurements of the entire ship. I discovered that everything forward of the stern post is fine. I also discovered that everything rearward of the stern post is 5mm out of spec. So I have a ship that is 5mm longer than it should be and the issues that accompany it. Upwards and onwards - The build continues but first I had to address a couple of problems. I would need to lift the rear beam upwards to the correct height and the quarter deck would have to be bespoke behind the stern post. So firstly the rear beam - Rather than remove the beam I have just made it 1.5mm thicker by adding a piece on. Next I made the beams - here's a few pictures of the process that I use. Just rough cut on the band saw I prefer to sand the inner curve first but I'm sure it makes no difference Then the outer Next I cut the dovetail joints - I really like doing this part its so satisfying Then I cut them into the clamps using a height gauge to make sure that they are at the correct height. I also sense check the alignment with a steel rule as they must be level with the stern post. Then I made the beam supports Finally I made the waterways which sit nicely on the level of the planksheer So although I'm not exactly to the plans anymore I think I've pulled it back enough to get away with it. I do have knock on issues such as the taff rail will be longer etc etc.... but I've got my head around what needs to be done. On the positive side you are getting 5mm more ship for your buck!!! Also stepping away sometimes is a very good thing to do! I'm very much back into it now - A slight delay though as it's my wife's 60th birthday next week so we are off to Crete for a fortnight to celebrate. I can now remove all of the beams and start some of the interior detail. Mark
Albert your work is simply amazing and very inspiring too -
pin vise and drill bits
Some Idea replied to palmerit's topic in Modeling tools and Workshop Equipment
Just my experience but I have tried different types of pin vices and found some to be lacking for my needs. The clamping action in many is just so poor that it makes the whole job so much harder. I settled on the Starrett and they have now given me years of trouble free work so I would recommend these. As for the bits I only buy cobalt bits now - they are strong and stay sharp for ages. They will also plow through brass and stainless steel without any problems. -
Beautiful work the bits could be a stand alone model. I've been watching some tutorials on Vcarve and at some point may take the plunge on trying to learn it better. I was wondering how you take the drawings and transpose them into Vcarve? I'm a total novice with Vcarve and CNC so I expect your answer will give me more questions than answers. -
Fractal vise on kickstarter
Some Idea replied to DavidG's topic in Modeling tools and Workshop Equipment
I really like things like this especially kickstarter projects. I think its got very good potential and fixing it to a mill would be a simple conversion or simply clamping it down. I've decided to back this project so I'll let you know in about 9 months whether it's come to fruition or not so thanks for sharing the project. -
Thats just genius!! -
David do you have a link to this vice? -
Wow congratulations on such a nice build - not only do you have carpentry skills but CAD skill too. Lovely job 👍
