Everything posted by Some Idea
Reading your post reminded me of when I had the exact same problem but mine was on the transom. I too had to build up a piece exactly as you have and at the time I felt as though it would stand out a mile. In fact I even thought about rebuilding the transom completely to resolve the issue. Now a couple of years later I was putting shellac on the transom and I had completely forgot about the repair and unless you knew about it - well it's invisible. A very nice repair on your part.
- 139 replies
- ancre
- Bateau de Lanveoc
Marc what a great post - for me it's about enjoying the journey in all of its forms. The end of the journey for me just means I cannot work on my favourite subject anymore even though hopefully I have crafted a decent enough ship.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Although I wanted to reply to your original post regarding the beams I didn't due to my lack of expertise. However I did think exactly the same as you for the solution as it makes perfect sense as BradNSW has already mentioned - lovely work!
- 99 replies
- ancre
- La Mahonesa
Thank you Michael I have made a start on the main hatches which are a little more tricky than they look. Firstly I made a mistake cutting the notches on the wrong side of the sides of the hatches. I'm sure we've all done something similar; I know that I have. So they were consigned to the scrap bin and I started again. Below is a hatch base with the notches now on the correct side! I found cutting the rebate on the curved ends challenging but I got there in the end. Next I made and fitted the metal corner braces - It was only after I fitted them I looked at the drawings again and they were supposed to be recessed into the base. I have decided to leave them where they are! I also need to get some lightweight wood filler to fill the holes that I drilled all of the way through. Now the fun started - trying to get the hatch tops to match the same curve as the base and also to get an all round tight fit. Then the strengtheners were made and fitted. I like making parts like this as it makes the effort of cutting notches etc worth it when it all fits so nicely together. Further reinforcement is added towards the side of the cover which I managed to glue in the wrong place as I misread the drawings yet again! It's not the end of the world but removing them would cause too mush damage so I will alter the nailing to suit. The lifting handles were next - This is the first time I've tried triangular handles as I've never successfully made them before. I usually make them round as I find this a lot easier but at least I've had a go. They're not great and I would love to know how other builders make these parts? I used a triangular file to bend the brass around but it was so fiddly and I found it difficult to get tight bends with straight sides. I've looked at other builders efforts and they look like a perfect triangle so any help for the future would be greatly appreciated I still need to get the nailing done which always takes me a while and then get them fitted onto the main deck. Thanks for all of the comments - Mark
Some more done on Le Rochefort. Taking the advice given I made some pads for the gudgeons on the un-planked side and also recessed them further into the stern post. Great advice as they definitely look and fit better. I did make a real mess of the recesses though - Now I know what I know I would mill these when making the stern post in the future. It would make the process much easier and tidier. I don't think these pieces are my best work and the rudder does sit slightly high but I've learnt a lot during the process. A picture of the ship with the rudder fitted The next part to make was the tiller arm which is quite a prominent part so it needed to be as accurate as possible. I made the arm and the knob on the end separately and used a treenail to help get a good bond between the two parts. I also straightened up the metal banding around the rudder to make it all look a bit better. Another little milestone in my build is now complete. I am so tempted to now finish off the stern and fit the railings and taff rail but I know that they will get broken at some point. So instead I will resist this and make the main hatches and the pumps. Thanks for the help Mark
L'Amarante by marsalv - 1:36 - POF
Some Idea replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Stunning work mate 😊 Your CNC capabilities are just getting better and better. The transition from plans, to CAD configuration to work holding on such a small mill is inspiring - amazing! -
Awesome job Phil - congratulations on your fantastic build 🎉
- 288 replies
- Card
- Pre-Dreadnought
(and 3 more)
Brass stock in small sections....?
Some Idea replied to Mark Pearse's topic in Metal Work, Soldering and Metal Fittings
Exactly as wefalck says using a slitting blade. I get good results using quite a course 4” diameter blade and attach the brass to a piece of wood. -
Hi Mark I too have found this problem so I now cut my own through my table saw. I'm currently using 2.3mm width x 1mm thickness brass and the only way I could achieve this was by cutting it myself -
Thanks Keith Work continues on the gudgeons - I thought that would be easier than the pintles - I was wrong 🤣 I started in the same way as the pintles by bending them to shape and then silver soldering the parts together. I could show you all of the ones that didn't make the cut that I threw away but it would take too many photos. The tube is 3/32 to accept the 1/16th pin - silver soldering tube needs to be done carefully as if the tube gets too hot it will simply collapse. The 3 gudgeons in their rough state which are pretty much at their final shape but they will need a little fettling to get them tighter to the hull. The monograph explains that the gudgeons require recessing into the stern post to reduce the gap between the rudder. I did this but somehow slightly split the wood each side of the recess. I'm hoping that when I glue them in place I will be able to improve the look a little. How the gudgeons look on the stern post - On the side that is not planked I think I will just leave that side of the gudgeon sitting away from the hull. I will leave the fixing holes without nails too but I would like to know what others think about this. I could bend it over and nail it to the frames but from the stern it would look uneven. Please let me know you opinions So now for a massive moment for me in this build - I put the rudder on with the gudgeons just holding on my friction! AND IT FITTED!!!!! Ok the top gudgeon is very slightly low but I'll take that as a win!!! A couple of photo's from the stern One photo from the poop deck So it's still an ongoing part but sometimes I make a part that just surprises me that I pulled it off - it's just one of those things. So still loads to do before it's finished; I need to recess the gudgeons a little more to get the rudder slightly closer and make the tiller arm. I also need to clean up the gudgeons; drill the fixing holes and chemically blacken them. The next time the rudder is fitted its not coming off again (I hope) Thanks to you all for your support Cheers Mark
Nice job Mike making a deck off of the ship that fits so well is tricky but you’ve got this - that little vice - mmm you’ve just cost me £19 and mine arrives tomorrow 😂
- 969 replies
- hahn
- oliver cromwell
Thanks Marc! Good to hear from you. I've never made pintles before so I did a little research to see how others had made them. I saw examples where the strap was soldered around the front of the pin which was then filed away to move the rudder closer to the stern post. I didn't think this method would work for me as getting the 1mm thick strap to sit exactly around the pin seemed slim so I ruled that out. Frolich in his book says to make them out of a solid piece to get a very good fit. I thought that this was a great idea but struggled to think of a way to hold the piece whilst I was making it so I also ruled this out. I decided to just try and make them exactly the way that Gerard has drawn them in the monograph. The brass used was 1/16" (1.55mm) solid rod for the pin and 1mm x 2.3mm for the strap. I needed to silver solder the strap directly to the side of the pin to achieve the fit that I wanted. As silver solder has virtually no filling properties I needed to make a jig to hold each piece tightly in place whilst soldering. I used a vermiculite block which I drilled a hole for the pin to sit in and then milled a couple of brass blocks to hold the straps. It took me 3 attempts until I found the correct relationship between the pin and straps. The first attempt set the pin slightly too high; the second attempt set the straps a little too high but the third was just about right. Making the other bends was simple - what I did was cut a light line using a saw through the inside of the bend to get a clean result. I also had to make the other fitting on the rear of the rudder that the chains attach to. Once made I cleaned them up and drilled the holes in all of the pieces and also the rudder. Finally all of the parts were blackened and fitted using just small amounts of epoxy resin. So thats another challenge completed and I'm hoping to get a nice close fit to the stern post. The pintles really are solid I just hope I've left enough space to slide them onto the gudgeons - in theory I have! So the gudgeons will be my next job. Thanks Mark
So having discovered that I didn't cut the reliefs for the pintles I thought I'd give it a go. This would have been so much easier when the piece was still square. I got a good result and it needed to be done. The pintles are made out of 1mm x 2.3mm brass so they need to sit flat as trying to force them into shape just will not work and damage the rudder. You can see below the much better beds for them I also have made the iron bands that reinforce the rudder around the tiller hole Thanks for all of the comments and likes they really are inspiring. I'm off to Malta for a week today so I'll catch up with you all when I get back Mark
