Q A's Revenge
Everything posted by Q A's Revenge
  1. That's a shame. We've had several vacuum cleaners over the years and it's certainly nice to have a quiet one for a change!Did you try Miele?
  2. On sale at Lidl for our UK members on Monday. http://www.lidl.co.uk/cps/rde/SID-A5355953-89ED6298/www_lidl_uk/hs.xsl/our-offers-2491.htm?action=showDetail&id=12779&ar=6
  3. We have one of these and it's really quite quiet. http://www.aeg.co.uk/Products/Cleaning/Cylinder_Cleaners/UltraOne/AUO8840UK
  4. Files are normally meant for harder materials than wood so shouldn't loose their edge very quickly. Have you though of trying needle rasps, I bought some of these: http://www.rutlands.co.uk/sp+cabinet-makers-needle-rasp-set-of-6+DK7915?tyah=y
  5. These are nice for fine work. http://www.rutlands.co.uk/sp+woodworking-hand-tools-hand-planes-bull-nose-planes-bull-nose-plane-anant+a77
  6. I thought dry brushing (weathering in particular) was normally done with those blocks of solid colour from the likes of Tamiya? http://www.tamiya.com/english/products/87080weathering/ Any advantage in using wet paint?
  7. It's not just Tung oil either. When oil finishes were more popular many years ago woodworkers would keep their used rags in tins with tight fitting lids.
  8. Someone on here has a very useful looking jig used with a drum sander held in a drill press. Seems like a great idea as a budget thicknesser.
  9. Looks really well made. Thanks for posting the pictures. I love the proper "flick" switch on the side!
  10. Have a look, bound to be something suitable! http://www.shop4glue.com/applicators-nozzles-bottles-sprays-and-caps-38-c.asp
  11. I have a couple of these now. Only issue is that they are probably a bit noisier than premium models?
  12. Martin, Info on how the screwless vice works is near the top of this page: http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices You need cap head socket screws for the clamps, they are tightened with an Allen key. Modeler12, Glad you're enjoying your mill. It would be my choice if I needed one! Vic.
  13. You may need some of these Martin. http://www.littlemachineshop.com/products/product_view.php?ProductID=2675&category=
  14. As Frank said, Fiskars are very good.
  15. Nice job Bill, thanks for posting!
  16. Nice review, should be very useful for folks contemplating buying this lathe. Looks like a very nice machine. Getting marks on work from chuck jaws is a common enough problem for folks. Two immediate remedies spring to mind, either place suitable packing between the jaws and the work. I've used pieces of aluminium drinks cans and card to good effect. Or if funds allow consider using a collet chuck, these are much kinder to the work piece!
  17. Try this. http://www.amazon.de/Scotch-Klebeband-1Rolle-unsichtbares-mattes/dp/B000KJOGI8/ref=sr_1_4?ie=UTF8&qid=1394037053&sr=8-4&keywords=Scotch+magic+tape
  18. I saw one of these today and started to wonder ... http://www.screwfix.com/p/energer-enb522tcb-450w-tile-cutter-240v/61123 Would it make a suitable model makers saw bench if you fitted one of these in place of the diamond blade? http://www.ebay.co.uk/itm/NEW-TCT-SAW-BLADES-WOOD-TIMBER-CUTTING-CIRCULAR-SAW-BLADES-FOR-110MM-TO-350MM-/331118870654 Might need an adaptor washer for the blade but it should work shouldn't it? Speed is about right and so is the price, about £35!
  19. Thanks Hexnut. I did look to see if I could still get the 23ml in the UK but no luck. Update. Just found some online but no difference in the per ml price :-(
  20. Popped in to get a couple of jars of paint today and something didn't seem quite right ... Old jar on the left, new on the right. Ok, I guess it has been a while since I bought any, was 23ml now 10ml. So when did Tamiya downsize their jars of paint? Lol :-)
  21. As drill chucks have been mentioned can I just say that they should only be used for drilling. They are not designed to take sideways loads as in the use of milling cutters. Drill chucks are generally not as accurate as collets either.
  22. If you intend to join lots of boards together on a regular basis then it's probably a handy piece of equipment to have. Personally I think a thicknesser would be more useful. For occasional edge joining a power plane would be a cheaper option.
  23. You could try Camelia oil, bound to be some in your neck of the woods I would have thought Tyrnac.
