Bob Cleek
Members-
Everything posted by Bob Cleek
At the end of the day, I prefer to leave the mast slightly loose and adjust its rake and centering by "eyeball" it, and adjusting it with the standing rigging, the same as is done in full-sized construction. (I bring a lot of my full-sized wooden boat building experience to my modeling work.) A plumb line from the ceiling or wherever provides a handy reference if need be. I prefer also to adjust the masts with wooden wedges in a hole slightly larger than the mast diameter, as in full size practice, but not rigidly so, unless I am lucky enough with a solid block hull to be able to set it up in my drill press and drill a dead-accurate hole. The wedges allow for "fine tuning" with the tap of a small jeweler's hammer on one side or the other and permit further adjustments which may be required as the standing rigging is set up (and if I can still get to them inside the shrouds at that point!) I like to ultimately set up the rake and athwartships alignment of masts conservatively adjusting the tension on the standing rigging with as little tension as is necessary, again as in full sized practice. (When a sailing vessel is underway, the leeward rigging always goes slack while the windward rigging hardens up and so the masts are never exactly plumb in real life except when standing still anyway.) The point of watching the tension on the standing rigging is that the forces generated by the rigging are cumulative as the various elements are added and at the end one can have considerable forces locked into the whole structure. A loosely stepped mast gives you some room to move. Short of an hermetically sealed case, wood always moves with the ambient humidity, to one degree or another, no matter how stable one thinks its environment might be. Structural damage to full size vessels due to overly tight standing rigging is quite common. (Think "bow and arrow" forces where the mast is the arrow, the standing rigging the bowstring and the mast heel is concentrating all that force to one isolated point on the keel causing the adjacent garboard seams to open up or "pant" in heavy weather.) With models, the same principle can result in snapped spars, pulled out eyes and other rigging attachments, chainplates pulled out, and so on, as both the wood and the cordage shrinks and swells. Stretched, saggy rigging is often found in old models (of ships and people!) They weren't built that way. The cordage just stretched over time. Modern synthetic cordage holds up much better with less stretch, but again as with the full sized vessels, the trade-off for longer lasting low-stretch synthetic cordage is that the forces are transferred more efficiently to the model's structure and afford less elasticity as the wood may expand. If I asked for a show of hands of all those who have had the experience of an inexplicably broken bit of rigging on a cased model or upon tightening that last bit of standing rigging on their model, hearing something somewhere go "snap!"... but I won't.
Possible new technique for making sails.
Bob Cleek replied to rckdr's topic in Masting, rigging and sails
Double ditto! If you must, a very fine and light pencil line is a better representation in scales smaller than what permits actual stitching. -
To put a finer point on it, it is the clew pendant tackle. Aft block of the tackle is hooked on the eye as illustrated when the mainsail is not bent to the spar or furled and lashed to the boom. The fall of the tackle is secured to the cleat on the boom, as illustrated. In a model without the sail raised, The after block would be hooked to the eye on the boom, pulled up tight and the fall secured to the cleat on the boom. Neatly done, the remaining fall would be coiled, frapped and hung on the cleat on the boom. In use, the mainsail clew and each reefing clew would have a clew pendant running either from the main clew and each reef clew. Depending on the size of the vessel, the pendents would run from either the boom at the turning block, often tied around the boom with the turning block providing a "stop" to prevent the end from being pulled aft when set, or the end simply secured directly to the clews (with an eye splice, or just a knot.) Secured to the boom and run up to the clews and then back down to the turning blocks provides a further purchase, unlike a direct connection to the clews. The pendents would then be run down from the clews to their respective turning blocks and through the turning blocks. Depending on the size of the vessel, the turning blocks may have sheaves or simply be fairleads. You've referred to the turning blocks as "bees," which is perhaps not the accurate term. (A "bee's seat" or "bees" are longer rails generally fastened on either side of a bowsprit or jib boom to which bowsprit netting is tied.) The plan illustration does not provide the detail to show the sheaves, but the shape of the turning blocks leaves no doubt that they contain sheaves. If they did not contain sheaves and thus were fairleads, they would be shorter and simply consist of a block of wood with a round hole with the edges relieved drilled into them. Beyond the turning blocks, an eye is worked into each clew pendant so that when the sail is raised fully each eye hangs free (without tension) just below the turning block or fairlead. When the sail is set, full or reefed, the clew pendant tackle is hooked to the eye of the respective clew intended to be pulled taunt and hauled up tight (or loosened if more belly is desired to the set of the sail) and tied off to the cleat at the forward end of the boom with the tackle fall coiled and secured to the tackle cleat.
- 15 replies
- Cutter
- Sherbourne
Bob, I'm most impressed with your Hoga/City of Oakland. You did very well under the constraints imposed by the lack of informational resources. Just a brief historical correction: Hoga is the only Navy hull still afloat of any kind which saw combat at Pearl Harbor on December 7, 1941. (The USCG's cutter Roger B. Taney was also present and saw combat that day, she being the only other such US vessel in existence and now an historical memorial.) To my regret, I came across your build log a day late and a dollar short. In 1995, I wrote the original application to the Navy's ship donation program for Hoga's donation as an historical memorial. I had access to technical assistance from the Navy's Sea Systems Command and the Oakland Fire Department crew that had just then returned her to the Navy. Let me assure you that at that time she was hardly a hulk. She had just recently enjoyed a motor rebuild with new platinum contacts and a major servicing of one of her two ALCO diesels and was "good to go." (The supplemental hose manifolds and fire fighting equipment mounted for service as a fireboat were in large measure powered by a couple of large diesel generators and pumps mounted on the after deck and not present in her service configuration.) As politics sometimes have it, Oakland's city council was sold a bill of goods by a vendor in the form of a smaller jet propelled shallow draft fireboat and so, over the objections of the fire department crew, Hoga was declared no longer needed. I would expect that you would have been able to secure line drawings from NAVSEASYS or the Navy Historical Department at the Washington Navy Yard, which I believe retain copies of everything the Navy has ever owned, but that's water under the bridge now. She was at that time surveyed in detail by Tri-Coastal Marine in Berkeley, CA, a well-known vessel surveying firm and I also had their reports. The application I wrote for a local yacht club and for the purpose of securing Hoga for restoration to her 12-7-41 configuration for use as an operating tug serving the Liberty Ship Memorial vessel, Jeremiah O'Brien, in San Francisco. The application had wide-spread support in all the right places, but ran onto the rocks when, at a certain level, a Navy bureaucrat refused to waive the usual requirement that memorial vessels be essentially "gutted" and rendered entirely non-operational, which, of course was a ridiculous proposition in this instance. She'd been meticulously maintained by the OFD since Oakland had obtained her on a post-war surplus dollar-a-year lease right after WWII. That was "game over" for our proposal. We had no interest in rendering Hoga non-operational. We wanted to see her sailing. (The legalities of all this are fascinating, if one has an interest in them. The Jeremiah O'Brien is fully operational because as a Merchant Marine vessel, she was obtained from the Maritime Administration's ("MARAD") "mothball fleet," not from the Navy. The carrier Hornet now on display in Alameda, CA, was preserved only at the last minute because a group was able to buy it from the winner of the auction when she was sold as scrap. The Navy wouldn't sell or donate her for memorial purposes, but insisted she be sold for scrap, although once sold, the scrapper could do whatever he wanted with her... go figure!) Actually, as it turned out, we turned over a rock at NAVSEASYS that nobody ever saw coming. Although it was originally thought that Oakland's "return" of the leased surplus vessel would make our obtaining it, also as surplus, an easy task, it was, supposedly to everyone in Washington's amazement, ascertained upon our application that Hoga had never been stricken from the Navy roll and had been carried on the Navy roll and funded as an active USN vessel in the Navy budget since the end of the war! While I wasn't a "fly on the wall," it seems there must have been a lot of fancy dancing and dust swept under the rug to correct that paperwork. Who knows what it cost for crew, fuel allotments, maintenance and the rest, year after year, and where did that money really go? Your tax dollars at work, no doubt! Pretty amazing that the Navy wouldn't have noticed they were "missing" a 100 foot tug for fifty plus years, no? Once the Navy got Hoga stricken from the rolls, they sent her up to the MARAD "mothball fleet" in Suisun Bay where MARAD preserved her, after a fashion, as they do with various surplus vessels such as Howard Hughes' Glomar Explorer. A group in Honolulu applied to take her as a memorial at Pearl Harbor, hoping to operate her in conjunction with the BB Missouri memorial. I heard that they were unable to justify the expense of shipping her out to Pearl from SF because the Navy had by then decided that she was a "treasure" which could not be risked on making the trip on her own bottom. The last I heard, she was supposedly donated to a group in Arkansas, IIRC, who wanted to display her in a local park up some river there, but they had run out of money and she was languishing again. The last time I was up at the "mothball fleet," which I guess was maybe a year ago, she was still there, covered in seagull poop. I have no idea what justification the Navy had for giving Hoga to a group in Arkansas which has not the remotest connection with the vessel's long and illustrious history. She spent her entire working life at Pearl Harbor, "for the duration" and then as the City of Oakland. One or the other... but Arkansas? Well, I guess at least the seagulls won't be using her for their head. And to provide a further ironic finish to the whole sad story, the Oakland Fire Department found upon taking delivery of their new jet propelled shallow draft fireboat, that when they cut loose with the monitors, the "recoil" from their flow of water pushed the lightweight shallow draft bucket all over the place, so much so as to pretty much render it useless. It might have been faster than City of Oakland getting to a fire, but it wasn't much help when it got there! The old City of Oakland was like a rock and indeed no lightweight. Last I heard, Oakland had sent their new fireboat back for modifications to try to cure the problem. At least that was the rumor.
This from the New York Times last year: Gibson Guitar Settles Claim Over Imported Ebony By JAMES C. MCKINLEY JR. 7:25 p.m. | Updated Gibson Guitar Corporation has agreed to pay $350,000 in penalties to settle federal charges that it illegally imported ebony Madagascar to use for fret boards, ending a criminal investigation that had drawn fire from conservatives as an example of over-reaching by the government, the Justice Department announced on Monday. The guitar maker agreed to pay a $300,000 fine and to donate $50,000 to the National Fish and Wildlife Foundation to promote the protection of endangered hardwood trees, like ebony and rosewood. In return, the government deferred prosecution of the company for criminal violations of the Lacey Act, which since May 2008 has made it illegal to import wood that was harvested and exported illegally under another country’s laws. “Gibson has acknowledged that it failed to act on information that the Madagascar ebony it was purchasing may have violated laws intended to limit over-harvesting and conserve valuable wood species from Madagascar, a country which has been severely impacted by deforestation,” said Ignacia S. Moreno, an assistant attorney general. Henry E. Juszkiewicz, Gibson’s chief executive, said the company still maintains the ebony from Madagascar was exported legally under that country’s laws. But he agreed to the settlement, he said, because it frees the guitar maker to continue importing wood from India, which, unlike Madagascar, is the major supplier of rosewood used in many fretboards. For the last year, he said, the criminal proceedings in court had effectively cut off Gibson from sources of hardwood in both Madagascar and India, and its luthiers were forced to make guitars with laminated fret-boards or fingerboards made of woods not traditionally used in guitars, which some customers did not like. “The alternative was pretty onerous,” he said. “We would have had to have gone to trial and we would have been precluded from buying wood from our major source country. For the ability to carry on with the business and remove this onerous Sword of Damocles, if you will, we feel this is about as good a settlement as we can get.” The federal investigation drew fire from conservatives after agents raided Gibson offices and factories in Nashville on Aug. 24 last year and seized pallets of fretboard blanks imported from India. That raid came two years after more than a dozen agents with automatic weapons burst into a Gibson factory in Nashville to seize ebony fingerboards from Madagascar. The raids became a cause for Tea Party activists and some Republican lawmakers, including House Speaker John A. Boehner, who questioned whether the government was overstepping its bounds. Gibson said the shipments were legal and disputed the government’s interpretation of Indian and Madagascar laws, which the company maintains allow the exportation of “fingerboard blanks,” which are in essence a piece of hardwood cut to the dimensions of a guitar fret board. But federal officials defended the raids, saying the company had failed to comply with the Lacey Act and its officials had willfully turned a blind eye to evidence the exports were in fact illegal. The settlement announced on Monday is a compromise that frees Gibson from the criminal charges as long as the company doesn’t violate the agreement over the next year and a half. As part of the deal, Gibson agreed to withdraw a suit seeking to recover about $261,000 worth of ebony and rosewood that was seized during the investigation. Mr. Juszkiewicz said the government had also agreed to return the Indian fingerboard blanks it had seized last year and to allow future imports of the blanks from India. “We entered into the settlement voluntarily,” he said. “It allows us to continue on with life and manufacture guitars.” Keep the Lacey Act in mind when considering the use of various exotics. Even if you have a stash of ebony that's been gathering dust since long before May 2008 when the embargo on "illegally harvested" woods went into effect, you'll pay hell producing the required paperwork proving that the ebony, rosewood, ivory or whatever on the endangered list is legally possessed. The burden to prove the embargoed material was imported prior to May 2008 or was otherwise obtained legally, is on the person in possession. The fines a worse than for drug possession. Be advised! You don't want to end up like Gibson guitar company. It cost them $300,000 and probably several times that much simply because they didn't have the paperwork to prove the ebony they'd imported was "legal." It isn't like the cops are going to be kicking down your door anytime soon looking for ebony and rosewood, but if you ever want to sell the model, that may likely become an issue unless you can prove the model was built before May 2008.
