Everything posted by kiwiron
Thanks, I'll dry fit the eyelets to see if I need to blacken them. I failed on the Birchwood Casey brass black for the barrels. It did'nt like to stick very well after 30 seconds and that's with the Birchwood Casey cleaning solution as well. I'll have another go with it on the barrels for the quarter deck.
Lol, I tried Auckland for a short time, hated the traffic jams. All dry here too. Trunnion nails were missing but I found some from a previous kit that work. Out of the 30 cannons for this deck you can only see 10, that will do for full rigging. The lower decks are dummy barrels, no carriages. Quarter deck has visible cannons but not many. The eyelets part 480 nearly need a microscope to see. Not a lot of work to go on these cannons. The breach ropes you used would be a perfect size. Take care. Ron.
Thanks for the likes. I'll do this half of the keel, rudder then the other side then see how much I've got left for the gaps. Not bad so far, you will get gaps between plates as the angles change and offset of 50 percent changes. Some stick together or bond instantly. not the first time I have gone to work with a plate stuck to my shirt.
Thanks for the info, I also found doing my Endeavour a lot of things were not accurate or just someone's best guess of how things looked. I think with kit parts they do what they can to get close to reality. With the current plates over lapping they would stick up a lot, like you say they should be really very thin. The kit calls for 4 gun port linings. If someone else hasn't got that far they could be left out. Any comments welcome thanks.
