Thanks, yes they are straightforward MPGs. Windows Media Player or RealPlayer should work without a problem. I am actually working from a MAC.
What program do I need to see you're movies.  I use windows 7.
Bob
Bob, try Media Player Classic.  That opens almost anything.  Plus it is a free download.
David B
For some reason My windows media player will not play them.
Bob
Current build:  SS_ Mariefred
Sorry for that ...
Testing the diefiler in anger requires a suitable power supply with enough ampères and the right voltage. After my large Proxxon transformer blew out, I constructed from mainly scavenged parts a unit that would fit into the worktable. From the estate of my late father I had a large transformer, a rectifier, and a nice 'antique' volt- and ampère-meter each plus various kinds of sockets and a radio knob. I bought an electronic speed-controller and two switches from Chinese sources.
One switch allows to change between the two voltage ranges and the other is set up as a reversing switch. Depending on the size of leads, I am either using small Japanese-type power-supply plugs or 3.5 mm mono-plugs and sockets for both are provided. In addition, I provided sockets for 4 mm laboratory banan-plugs, one going through the speed-controller, the other directly to the rectifier.
The power supply is connected via a foot-switch to the mains. This allows to work with hands free and as the transformer is not constantly connected, the energy consumption is reduced and, hence, the waste heat, which is necessary, as the ventilation of the unit in the workbench is not very good.
Edited by wefalck
I think, when you build old-time ship models, the workshop should match this - somehow building old ships with modern plasticie tools looks out of place  ;)
Wefalck,
Beautiful work and well described with photos and videos.
Thanks,
Bill
Bill
Kate Cory Scratch Built
Previous Builds:
Benjamin W. Latham Scratch Built
H A Parks Skipjack Scratch Built
Charles W. Morgan Model Shipways Kit
Rattlesnake Model Shipways Kit
Diligence Model Shipways Kit
