Does anyone have and use a Unimat.  These things are not hard to find and replacement bearings are easily available if you have one in rough conditions.  For a shop with limited space, I can't imagine a more useful tool.  I have bigger and better tools but they are out of service until I get my new shop finished.  My Unimat has been with me for years and It is NOT for sale
You will never know if you can do something until you try... and even then you may not be sure.
I have had mine since about 1972.  Had to replace the motor.  Burned it out using it as a table saw.  I have replaced that function with single purpose machines.
I got an additional aluminum bed on line with the intention of isolating the post holder portion and positioning it about 1/2 way down the bed to have a mill with more work movement options,  but I have not gotten up the courage to wreck a part that is no longer being made.
Where do you get your belts?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I had to replace my motor as well.  I was not worried about the historical accuracy so instead of an OEM part, I went with a slightly larger Baldor motor from Blue Ridge Machinery.  I haven't had to replace belts for a while but I think I get them from Blue Ridge too.  There seems to be a lot of sources.
At the moment, the drill function is way more useful than the lathe and since the lathe bed takes up a lot of space on my small worktable, I made a clamp on base that gives me what i need.  Used this way, i don't have use of the X/Y positioning but that has not been a  problem.  I can fabricate any special holding fixture that I need and eye ball positioning has been good enough.
I also get a lot of use from this setup as a holding device or a convenient rotating spindle that is easier to use than when it is mounted on the bed.
You would be amazed at the Unimat lathes and parts that appear on eBay. You could replace almost anything you need from that source.
From Longridge extolling the virtue of the Midget Universal, I went looking for a similar machine and found the Unimat SL.  I in no way regret it.  It is a well built machine.  It is a joy to work with.
I used the lathe function to produce shaft adapters using cold rolled steel stock.  It was a total PITA to tear down the ways and slide table to remove the steel shavings. Everything comes apart and back together just like the precise machine that it is.  I coated the ways with Renaissance Wax, which seems to be a good thing - protection from rust,  waxing the threaded rod - not so wise.   The tolerances are so close that it took a lot of cranking to remove enough to make the feed wheel turn easily again.
It is nice to be able to use it to make other machines.
I got the lathe duplicator (the generic one) from Penn State for turning cannon but have not tried it yet.
NRG member 50 years
Current:
NMS
Other
I bought a second hand Unimat SL in 1978 for $180, it came with almost every accessory available at the time so it was a brilliant buy, which is good because I was 15 at the time and that was lots of weeks pocket money and chores to put towards it.
I still have it and use it regularly, though I've since bought purpose built equipment to replace the jigsaw/scrollsaw and table saw accessories.
I've found this gent very helpful with spares, I've bought replacement brushes, bearings and  belts:
http://unimat.homestead.com/
He also included the original diagrams for the bearing setup so I was able to discover that I'd had them arranged all wrong for the last 35 or so years...
