Mike,
I just realized your were talking apples and I was talking oranges.
I am considering the disc maker for flat disks, such as those used in sheaves.  For rivet heads I have been turning brass into short nails using the methods described by others on the site. I tried to use a set of miniature rivet heads that came on a sticky backing, but found them hard to control.  That was earlier in my experience and I was not able to control them very well.
The punch looks like it would do well if the coloring issue could be resolved.  I have had been using Blacken-it which took a lot of abuse and kept its look, but blacken it is no longer manufactured.  I will be trying Liver of Sulfur next.
Richard
Richard
Member: The Nautical Research Guild
Sorry, hit send too soon.
I had looked at the decals but did not like the flat look.  The brass miniature rivet heads had dimension and I may try those again.  In my attempts with it, I did not have the problem with glue interfering with the blackening.  Either I was able to use really small drops of CA or I was just lucky.
Richard
Richard
Richard - I would love to use a blackener rather than paint. I am using the Blue Jacket product which works well (they also have a product for britannia) but it does come off. If I hold a blackened piece between thumb and finger they will pick up some of the black. I was under the impression that this was just a common issue with blackened parts. Maybe some products don't do this. That is the big reason I put a coat of lacquer on any blackened part. It helps seal up the black.
I have not personally seen the decals, but I am in your camp on this. Whatever is used needs to have some dimension or relief. That is catches my eye when I look at a part with rivets.
Richard,
Liver of sulfur only works on copper.  It won't do brass.
The choices are getting fewer.....
Another company from mostly model railroading is Grandt Line. They list nut/bolt/washers, rivets, turnbuckles, hinges and much more: Check them out at: http://grandtline.com/products/mrr/mrr%20details/augmentables.html
Ken
Started: MS Bounty Longboat,
I've all the mentioned bookmarked. My order from SpecialShapes arrived yesterday. I now have more brass strips than I will ever know what to do with.
